Page 1 of 1
AXIS PTZ Video + Controls Fedora 9 64 Bit ZM 1.23.3 (Solved)
Posted: Sun Nov 23, 2008 12:40 pm
by nivlek
Hello everyone,
back with a new environment:
Fedora 9 (64 bit)
ZM 1.23.3
Apache 2.2.8
PHP 5.2.5 with Socket Support Enabled
Previous environment
RHEL 5 WS Client
I have to say I have spent many hours attempting to get ZM working complete with Controls for a AXIS 215 PTZ
I gave up with the RHEL 5 WS Client. I found myself fetching half the Internet to install.
With Fedora 9. I still found a lot of additional code is required.
Is there a definitive list ?
Also, although I specified Apache Group and User during the ZM build. I seem to still have many permission issues. Is there a Howto for this anywhere ?
I would welcome any guidance.
Present Situation is
The PTZ appears to be capturing data, but "stills".
The Control GIFs appear but not respond.
I will make a donation once I'm able to demonstrate a running PTZ.
Nivlek
So there are not many Axis PTZ 215 Users
Posted: Mon Dec 01, 2008 3:26 pm
by nivlek
Hello All,
I would like to correct my statement about producing still pictures. ZoneMinder is capturing motion correctly.
The Controls situation has me baffled. I have turned up Debugging and so far I have not seen anything on the critical list. I did notice a number of *.sock files being created with 0 bytes though. I will scan the logs again.
The PTZ works well using Firefox, so it appears I've done something wrong setting up ZM.
Nivlek
Control Log messages found
Posted: Fri Dec 05, 2008 2:20 am
by nivlek
some positive news. I found the following
12/05/2008 04:51:58.638570 zmcontrol[26741].INF [Starting control server 2/AxisV2]
12/05/2008 04:51:58.645458 zmcontrol[26784].INF [Control server 2/AxisV2 starting at 08/12/05 04:51:58]
12/05/2008 04:51:59.646988 zmcontrol[26784].FAT [Can't access wake member of object of class ZoneMinder::Control::AxisV2]
12/05/2008 04:52:30.885329 zmcontrol[3976].INF [Starting control server 2/AxisV2]
12/05/2008 04:52:30.887299 zmcontrol[4024].INF [Control server 2/AxisV2 starting at 08/12/05 04:52:30]
12/05/2008 04:52:31.889731 zmcontrol[4024].FAT [Can't access reset member of object of class ZoneMinder::Control::AxisV2]
12/05/2008 04:54:46.327935 zmcontrol[8583].INF [Starting control server 2/AxisV2]
12/05/2008 04:54:46.329897 zmcontrol[8586].INF [Control server 2/AxisV2 starting at 08/12/05 04:54:46]
12/05/2008 04:54:47.332360 zmcontrol[8586].FAT [Can't access move_abs_left member of object of class ZoneMinder::Control::AxisV2]
I am not sure what to do next!
I got the messages when entering commands using a terrminal and zmcontrol.pl
nivlek
Break through - the PTZ moved !!
Posted: Sun Dec 07, 2008 9:28 am
by nivlek
A minor miracle (for me at least)
the following caused the camera to move
zmcontrol.pl --id 2 --command=moveConLeft
:D
Solution
Posted: Tue Dec 09, 2008 4:57 am
by nivlek
Hello viewers,
I have found a combination of parameters that work for me.
8) :D
Everything appears to be working after I removed the DVR(Beta) option.
Nivlek
