Xlib_shm crashes and uses lots of CPU
Posted: Mon Nov 24, 2008 9:22 am
Hi everyone,
I've Ubuntu 8.04 and ZM 1.23 on a P4 3.0Ghz with 1 gb of RAM.
--> first problem:
when I start xlib_shm the CPU usage goes to 80% (the PC is very slow). Is it normal?
--> second problem:
I use cron to switch the zm state
but after changing the state xlib_shm crashes, I must kill the process and restart it.
Is there another way? how can I solve it?
thanks Paolo[/code]
--> first problem:
sudo xlib_shm-gl -m1 -m3 -m4 -m6 -k 0x7a6d0000
sudo /usr/bin/zmpkg.pl modect
sudo /usr/bin/zmpkg.pl monitor
thanks Paolo[/code]
