ffmpeg problem [SOLVED]
Hii!!
I'm having problem with ffmpeg. I have it installed at /usr/include/ffmpeg.
(The directories libavformat, libavutil, and so on, are at /usr/include/ffmpeg/include).
I'm doing:
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr/include/ffmpeg ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass --enable-debug=yes
I'm getting:
checking for ffmpeg... yes
checking for ffmpeg... /usr/bin/ffmpeg
checking for pnmscale... no
checking libavutil/avutil.h usability... no
checking libavutil/avutil.h presence... no
checking for libavutil/avutil.h... no
checking ffmpeg/avutil.h usability... no
checking ffmpeg/avutil.h presence... no
checking for ffmpeg/avutil.h... no
checking libavcodec/avcodec.h usability... no
checking libavcodec/avcodec.h presence... no
checking for libavcodec/avcodec.h... no
checking ffmpeg/avcodec.h usability... no
checking ffmpeg/avcodec.h presence... no
checking for ffmpeg/avcodec.h... no
checking libavformat/avformat.h usability... no
checking libavformat/avformat.h presence... no
checking for libavformat/avformat.h... no
checking ffmpeg/avformat.h usability... no
checking ffmpeg/avformat.h presence... no
checking for ffmpeg/avformat.h... no
checking libswscale/swscale.h usability... no
checking libswscale/swscale.h presence... no
checking for libswscale/swscale.h... no
checking ffmpeg/swscale.h usability... no
checking ffmpeg/swscale.h presence... no
checking for ffmpeg/swscale.h... no
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
The makefile is generated. When I do "make", I get:
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include/ffmpeg/include -Wall -Wno-sign-compare -fno-inline -frepo -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_mpeg.h:23,
from zm_stream.h:27,
from zm_event.h:39,
from zm_zone.h:27,
from zm_monitor.h:27,
from zmc.cpp:28:
zm_ffmpeg.h:33:2: error: #error "No location for avutils.h found"
zm_ffmpeg.h:40:2: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:47:2: error: #error "No location for avformat.h found"
zm_ffmpeg.h:55:2: error: #error "No location for swscale.h found"
Why is it occuring? The ZoneMinder is search for the files in the wrong directory?
Am I doing something wrong?
I'm doing:
I'm getting:
from zm_event.h:39,
from zm_zone.h:27,
from zmc.cpp:28:
Yup, you are. You've got your include directories all messed up. By default (if I'm not mistaken) ffmpeg will install it's header files into separate directories just where from the look of the output of your configure run, the configure script is looking for them.
Solution? Reinstall ffmpeg and allow it to put the headers in their default location, _or_ manually put the header files where (create the directories) the configure script expects to find them.
Secondly, until you get a clean configure run there is no point in trying to run make. Even if you do get a successful build it'll likely be broken anyway.
[resolved] ffmpeg problem
The ZoneMinder was searching for the files in a directory that they weren't. So I created links and it find them.
Thanks nuck!!
Thanks nuck!!
which folder ?
Hi, could you explain me what do you exactly did?
It seems that zoneminder can't find that files as you wrote up here.
my question is, where is zoneminder searching for this files? in which folder?
thanks in advance.
J.
thanks in advance.
J.
Hi Johnny,
I don't remember clearly how I did it, but I will try to help you.
Firstly, the ZoneMinder shows where it is searching the files during the beginning of the compilation, if I'm not wrong, in the first line:
About the link, I used the command ln. I created the folder include in the folder ffmpeg, and, after that, I created the links in this way:
ln -s /usr/include/ffmpeg/libavcodec /usr/include/ffmpeg/include
You have to create links to all folders that are in the folder ffmpeg (libavcodec, libavdevice, ....)
Try to do it and tell me if it works.
no way
I did the ln -s and i got the same, see you:
checking libavcodec/avcodec.h usability... yes
checking libavcodec/avcodec.h presence... yes
checking for libavcodec/avcodec.h... yes
checking libavformat/avformat.h usability... yes
checking libavformat/avformat.h presence... yes
checking for libavformat/avformat.h... yes
checking libswscale/swscale.h usability... yes
checking libswscale/swscale.h presence... yes
checking for libswscale/swscale.h... yes
horrible BUUGG !! its the second day i am around it.
Thanks for you reply.
J.
J.
But Johnny, did you stop the compilation because this no's? This is not an error. When you do make, does the compilation stop anytime?
Moreover, the ZoneMinder found the library files. These no's is because it searchs in two different places, and, in your case, it found it in one, but not in the other.
recompilation
i got this errors with my MAKE:
make[2]: *** [zmc] Error 1
make[2]: Leaving directory `/usr/share/zoneminder/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/share/zoneminder'
make: *** [all] Error 2
thank you one more time.
J.
J.
so long
sorry
zm_signal.cpp: In function âvoid zm_die_handler(int, sigcontext)â:
zm_signal.cpp:112: warning: format not a string literal and no format arguments
zm_signal.cpp:126: warning: format not a string literal and no format arguments
mv -f .deps/zm_signal.Tpo .deps/zm_signal.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_stream.o -MD -MP -MF .deps/zm_stream.Tpo -c -o zm_stream.o zm_stream.cpp
mv -f .deps/zm_stream.Tpo .deps/zm_stream.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_thread.o -MD -MP -MF .deps/zm_thread.Tpo -c -o zm_thread.o zm_thread.cpp
mv -f .deps/zm_thread.Tpo .deps/zm_thread.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_time.o -MD -MP -MF .deps/zm_time.Tpo -c -o zm_time.o zm_time.cpp
mv -f .deps/zm_time.Tpo .deps/zm_time.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_timer.o -MD -MP -MF .deps/zm_timer.Tpo -c -o zm_timer.o zm_timer.cpp
mv -f .deps/zm_timer.Tpo .deps/zm_timer.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_user.o -MD -MP -MF .deps/zm_user.Tpo -c -o zm_user.o zm_user.cpp
mv -f .deps/zm_user.Tpo .deps/zm_user.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_utils.o -MD -MP -MF .deps/zm_utils.Tpo -c -o zm_utils.o zm_utils.cpp
mv -f .deps/zm_utils.Tpo .deps/zm_utils.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_zone.o -MD -MP -MF .deps/zm_zone.Tpo -c -o zm_zone.o zm_zone.cpp
mv -f .deps/zm_zone.Tpo .deps/zm_zone.Po
g++ -frepo -g -O2 -L/usr/lib -L/usr/lib/mysql -o zmc zmc.o zm_box.o zm_buffer.o zm_camera.o zm_comms.o zm_config.o zm_coord.o zm.o zm_db.o zm_debug.o zm_event.o zm_exception.o zm_file_camera.o zm_ffmpeg_camera.o zm_image.o zm_jpeg.o zm_local_camera.o zm_monitor.o zm_ffmpeg.o zm_mpeg.o zm_poly.o zm_regexp.o zm_remote_camera.o zm_remote_camera_http.o zm_remote_camera_rtsp.o zm_rtp.o zm_rtp_ctrl.o zm_rtp_data.o zm_rtp_source.o zm_rtsp.o zm_signal.o zm_stream.o zm_thread.o zm_time.o zm_timer.o zm_user.o zm_utils.o zm_zone.o -lbz2 -lswscale -lavformat -lavcodec -lavutil -lpcre -lgnutls-openssl -lmysqlclient -lpthread -ldl -lz -ljpeg
collect: recompiling zm_utils.cpp
collect: recompiling zm_rtsp.cpp
zm_rtsp.cpp: In constructor âRtspThread::RtspThread(int, RtspThread::RtspMethod, const std::string&, const std::string&, const std::string&, const std::string&, const std::string&, const std::string&)â:
zm_rtsp.cpp:183: warning: âAVFormatContext* av_alloc_format_context()â is deprecated (declared at /usr/local/include/libavformat/avformat.h:787)
collect: recompiling zm_thread.cpp
collect: recompiling zm_rtp_source.cpp
collect: recompiling zm_rtp_ctrl.cpp
collect: recompiling zm_monitor.cpp
collect: recompiling zm_local_camera.cpp
collect: recompiling zm_event.cpp
collect: recompiling zm_comms.cpp
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
zm_ffmpeg_camera.o: In function `FfmpegCamera::Capture(Image&)':
/usr/share/zoneminder/src/zm_ffmpeg_camera.cpp:172: undefined reference to `av_free_packet'
collect2: ld returned 1 exit status
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
collect: relinking
Jonny,
the "real" error is:
and, unfortunately, I can't help you. I've never seen this error and I don't know so much about ffmpeg.
Verify if your ffmpeg is updated or if there is some version indicated for the ZoneMinder you are installing.
version 2
here i did the MAKE with the original src/zm_rtsp.cpp (avformat_alloc_conterxt() )the post before was with :av_alloc_format_context()
http://www.zoneminder.com/forums/viewtopic.php?p=49597
- mFormatContext = avformat_alloc_context();
+ mFormatContext = av_alloc_format_context();
here the new log, still with errors:
o zm_signal.o zm_signal.cpp
thanks.
J.
thanks.
J.
SOLVED!
error : av_free_packet not found !
add in end file src/zm_ffmpeg_camera.cpp to resolve problem.
void av_free_packet(AVPacket *pkt)
if (pkt) {
if (pkt->destruct) pkt->destruct(pkt);
pkt->data = NULL; pkt->size = 0;
[/u]
if (pkt) {
[/u]
