Page 1 of 2
Ubuntu 8.10, ZM 1.23.3-3 and no image --Now Bad image
Posted: Thu Dec 04, 2008 12:05 am
by Cartsy
I'm using Ubuntu 8.10 and Zoneminder 1.23.3-3 and can't get an image out of it.
When I type:
~$ zmu -d /dev/video1 -q -v
Aborted
But if I use sudo:
~$ sudo zmu -d /dev/video1 -q -v
Video Capabilities
Name: USB Camera (046d:08a2)
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 640
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 640
Height: 480
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 8
Brightness: 32896
Hue: 0
Colour :0
Contrast: 32768
Whiteness: 39321
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
I don't have rights for zmu? For example:
~$ zmu -l
Aborted
~$ sudo zmu -l
Id Func State TrgState   LastImgTim RdIdx WrIdx LastEvt FrmRate
/var/log/syslog.log says:
Dec 4 00:06:41 cath-laptop zmwatch[5841]: ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
Dec 4 00:06:41 cath-laptop zmwatch[5841]: INF [Restarting capture daemon for testi, shared memory not valid]
Dec 4 00:06:42 cath-laptop zmdc[5809]: INF ['zmc -d /dev/video1' starting at 08/12/04 00:06:42, pid = 9260]
Dec 4 00:06:42 cath-laptop zmdc[9260]: INF ['zmc -d /dev/video1' started at 08/12/04 00:06:42]
Dec 4 00:06:42 cath-laptop zmwatch[5841]: INF ['zmc -d /dev/video1' starting at 08/12/04 00:06:42, pid = 9260]
Dec 4 00:06:42 cath-laptop zmc_dvideo1[9260]: INF [Debug Level = 0, Debug Log = <none>]
Dec 4 00:06:42 cath-laptop zmc_dvideo1[9260]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Dec 4 00:06:42 cath-laptop zmdc[5809]: ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
http://img254.imageshack.us/img254/9337 ... chmie6.png
http://img132.imageshack.us/img132/1614 ... estdy1.png
My webcam works fine with other programs but not with Zoneminder..
What should I do?
Posted: Thu Dec 04, 2008 12:14 am
by cordel
Check that zmfix has the setuid and if not:
Posted: Thu Dec 04, 2008 10:02 am
by Cartsy
Thanks, but no help. Source stays red.
Should I try an older version of ZM?
Edit: I think I have rights to /dev/video1 because "cat /dev/video1" works fine.
Edit2: I did nothing and the source seems to be yellow now. Still no picture.
Posted: Thu Dec 04, 2008 5:08 pm
by Lee Sharp
As a user, try 'zmfix' and tell me what it returns. After it runs, try 'ls /dev/vid* -lah' and tell me what that returns.
Posted: Fri Dec 05, 2008 6:06 pm
by Cartsy
zmfix returns nothing.
ls /dev/vid* -lah returns:
crw-rw----+ 1 root video 81, 0 2008-12-05 20:00 /dev/video0
crw-rw-rw-+ 1 root video 81, 0 2008-12-05 20:00 /dev/video1
I did that shared memory thing and now /var/log/syslog.log says:
Dec 5 20:10:26 cath-laptop zmwatch[5465]: INF [Restarting capture daemon for New, time since last capture 9 seconds (1228500626-1228500617)]
Dec 5 20:10:26 cath-laptop zmdc[5431]: INF ['zmc -d /dev/video1' starting at 08/12/05 20:10:26, pid = 7396]
Dec 5 20:10:26 cath-laptop zmdc[7396]: INF ['zmc -d /dev/video1' started at 08/12/05 20:10:26]
Dec 5 20:10:26 cath-laptop zmwatch[5465]: INF ['zmc -d /dev/video1' starting at 08/12/05 20:10:26, pid = 7396]
Dec 5 20:10:26 cath-laptop zmc_dvideo1[7396]: INF [Debug Level = 0, Debug Log = <none>]
Dec 5 20:10:26 cath-laptop zmc_dvideo1[7396]: INF [Starting Capture]
Dec 5 20:10:27 cath-laptop zmc_dvideo1[7396]: ERR [Sync failure for frame 1 buffer 2(1): Invalid argument]
Dec 5 20:10:27 cath-laptop zmdc[5431]: ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
Edit: And suddenly it starts working. I did nothing. Just few clicks with those zone things in Watch window. Sometimes source is red, sometimes it might be yellow..
This is how it "works": http://e.imagehost.org/view/0288/eiei It takes this crappy image every 10 seconds.
Edit2: Doesn't help if I change the resolution of the cam.
Edit3: My cam is Labtec webcam pro. Any suggestions of cheap cams that should work with ZM?
Posted: Thu Dec 18, 2008 3:28 pm
by alexm
Hello Cartsy,
Did you get you webcam to work in the end? I have experienced what looks like exactly the same problem except that my webcams used to work. I had Zoneminder running perfectly under openSuse but have just migrated to Ubuntu 8.10 and now I get the same error messages as you.
The cameras work when using other programs e.g. xawtv.
The cameras I have came in the "Creative - Webcam Vista Skype Dual Pack" from PC World (lsusb shows it as 041e:405f Creative Technology, Ltd).
Posted: Thu Jan 29, 2009 12:47 pm
by liviab
We're three with the same problem. :shock:
My log file is showing the same messages that the Cartsy's is.
My camera also works fine with other programs, such as cheese and xawtv.
By the way, I'm using ZoneMinder-1.24.0 and Fedora 10.
Anyone can help us? ^^
Posted: Thu Jan 29, 2009 1:35 pm
by wisekki
I'm joining this club.. in case you didn't see my previous posts :D
Posted: Thu Jan 29, 2009 1:42 pm
by liviab
so, we're four. heheh
:o
Posted: Thu Jan 29, 2009 1:48 pm
by wisekki
Because I'm out of ideas i'm just going to ask what modules you are using for your cams? Could a faulty module do all this?
I tried to compile gspca from a source but it didn't work because it can't find semaphore.h for some reason.
Posted: Thu Jan 29, 2009 1:59 pm
by liviab
The command dmesg is showing:
Linux video capture interface: v2.00
gspca: main v2.2.0 registered
gspca: probing 041e:4051
zc3xx: Sensor Tas5130 (VF0250)
gspca: probe ok
usbcore: registered new interface driver zc3xx
zc3xx: registered
So I think that it is gspca with the module zc3xx.
Posted: Thu Jan 29, 2009 2:12 pm
by kylejohnson
Looks like a permission issue. I usually have to add the user that ZoneMinder is running as (www-data) to the video group. Have you tried this?
sudo usermod -a -G video www-data
Posted: Thu Jan 29, 2009 2:17 pm
by liviab
It doesn't work... :(
[root@livia ~]# usermod -a -G video www-data
usermod: user www-data does not exist
Posted: Thu Jan 29, 2009 3:38 pm
by kylejohnson
liviab wrote:It doesn't work... :(
Ergh. The original poster is using Ubuntu, on which apache runs as www-data. Which distro are you using? Just substitute www-data for the user that apache (or ZoneMinder) is running as.
Posted: Thu Jan 29, 2009 4:36 pm
by wisekki
liviab wrote: So I think that it is gspca with the module zc3xx.
Yeah same here and the same errors as you...
[32054.304018] usb 3-1: new full speed USB device using uhci_hcd and address 3
[32054.495438] usb 3-1: configuration #1 chosen from 1 choice
[32054.498216] gspca: probing 046d:08d7
[32056.148100] zc3xx: probe 2wr ov vga 0x0000
[32056.192097] zc3xx: probe sensor -> 11
[32056.192101] zc3xx: Find Sensor HV7131R(c)
[32056.198599] gspca: probe ok
[32056.198638] gspca: probing 046d:08d7
So it could have something to do with the module.. ?
