Help Setup ZM & Webcam
roundhay
Post by roundhay »
I want to test a zoneminder setup on a headless server
I am running ubuntu server 8.10 and have a logitech quickcam fusion webcam that i would like to use the test zm before buy cam to put ourside my property.
I have install zm using apt-get install zone mider but I can't seem to get the webcam to work.
I have been through various how-to but don't seem to be getting anywhere.
Before I do anything else I would like to now how I can see if the webcam is installed and the O/S recognizes it
Any help would be appreciated
50cc
Post by 50cc »
what output does the CLI tool dmesg give?
roundhay
Post by roundhay »
dmesg output below:
[    0.000000] PERCPU: Allocating 45852 bytes of per cpu data
[    0.000000] NR_CPUS: 64, nr_cpu_ids: 4, nr_node_ids 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1036751
[    0.000000] Kernel command line: root=UUID=368686ba-f405-43ca-b9d8-74dc0d3ee466 ro quiet splash
[    0.000000] Enabling fast FPU save and restore... done.
[    0.000000] Enabling unmasked SIMD FPU exception support... done.
[    0.000000] Initializing CPU#0
[    0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[    0.000000] TSC: PIT calibration confirmed by PMTIMER.
[    0.000000] TSC: using PMTIMER calibration value
[    0.000000] Detected 3400.067 MHz processor.
[    0.010000] Console: colour VGA+ 80x25
[    0.010000] console [tty0] enabled
[    0.010000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.010000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.010000] Memory: 4131672k/5242880k available (2628k kernel code, 60548k reserved, 1201k data, 436k init, 3275968k highmem)
[    0.010000] virtual kernel memory layout:
[    0.010000]     fixmap  : 0xffc78000 - 0xfffff000   (3612 kB)
[    0.010000]     pkmap   : 0xff800000 - 0xffa00000   (2048 kB)
[    0.010000]     vmalloc : 0xf8800000 - 0xff7fe000   ( 111 MB)
[    0.010000]     lowmem  : 0xc0000000 - 0xf8000000   ( 896 MB)
[    0.010000]       .init : 0xc04c3000 - 0xc0530000   ( 436 kB)
[    0.010000]       .data : 0xc0391026 - 0xc04bd800   (1201 kB)
[    0.010000]       .text : 0xc0100000 - 0xc0391026   (2628 kB)
[    0.010000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.010000] CPA: page pool initialized 1 of 1 pages preallocated
[    0.010000] SLUB: Genslabs=12, HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.010016] Calibrating delay loop (skipped), value calculated using timer frequency.. 6800.13 BogoMIPS (lpj=34000670)
[    0.010041] Security Framework initialized
[    0.010053] SELinux:  Disabled at boot.
[    0.010083] AppArmor: AppArmor initialized
[    0.010099] Mount-cache hash table entries: 512
[    0.010348] Initializing cgroup subsys ns
[    0.010354] Initializing cgroup subsys cpuacct
[    0.010358] Initializing cgroup subsys memory
[    0.010381] CPU: Trace cache: 12K uops, L1 D cache: 16K
[    0.010384] CPU: L2 cache: 1024K
[    0.010387] CPU: Physical Processor ID: 0
[    0.010392] using mwait in idle threads.
[    0.010407] Checking 'hlt' instruction... OK.
[    0.052630] ACPI: Core revision 20080609
[    0.055489] ACPI: Checking initramfs for custom DSDT
[    0.352443] ENABLING IO-APIC IRQs
[    0.352624] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.452638] CPU0: Intel(R) Xeon(TM) CPU 3.40GHz stepping 01
[    0.460000] Booting processor 1/6 ip 6000
[    0.010000] Initializing CPU#1
[    0.010000] Calibrating delay using timer specific routine.. 6800.49 BogoMIPS (lpj=34002461)
[    0.010000] CPU: Trace cache: 12K uops, L1 D cache: 16K
[    0.010000] CPU: L2 cache: 1024K
[    0.010000] CPU: Physical Processor ID: 3
[    0.610358] CPU1: Intel(R) Xeon(TM) CPU 3.40GHz stepping 01
[    0.610372] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[    0.620115] Booting processor 2/1 ip 6000
[    0.010000] Initializing CPU#2
[    0.010000] Calibrating delay using timer specific routine.. 6800.45 BogoMIPS (lpj=34002283)
[    0.010000] CPU: Physical Processor ID: 0
[    0.780388] CPU2: Intel(R) Xeon(TM) CPU 3.40GHz stepping 01
[    0.780415] checking TSC synchronization [CPU#0 -> CPU#2]: passed.
[    0.790165] Booting processor 3/7 ip 6000
[    0.010000] Initializing CPU#3
[    0.010000] Calibrating delay using timer specific routine.. 6800.53 BogoMIPS (lpj=34002665)
[    0.950289] CPU3: Intel(R) Xeon(TM) CPU 3.40GHz stepping 01
[    0.950314] checking TSC synchronization [CPU#0 -> CPU#3]:
[    0.960000] Measured 94 cycles TSC warp between CPUs, turning off TSC clock.
[    0.960000] Marking TSC unstable due to check_tsc_sync_source failed
[    0.960011] Brought up 4 CPUs
[    0.960016] Total of 4 processors activated (27201.61 BogoMIPS).
[    0.960047] CPU0 attaching sched-domain:
[    0.960051]  domain 0: span 0,2 level SIBLING
[    0.960054]   groups: 0 2
[    0.960062]   domain 1: span 0-3 level CPU
[    0.960065]    groups: 0,2 1,3
[    0.960072] CPU1 attaching sched-domain:
[    0.960074]  domain 0: span 1,3 level SIBLING
[    0.960077]   groups: 1 3
[    0.960081]   domain 1: span 0-3 level CPU
[    0.960084]    groups: 1,3 0,2
[    0.960090] CPU2 attaching sched-domain:
[    0.960092]  domain 0: span 0,2 level SIBLING
[    0.960095]   groups: 2 0
[    0.960099]   domain 1: span 0-3 level CPU
[    0.960102]    groups: 0,2 1,3
[    0.960108] CPU3 attaching sched-domain:
[    0.960112]  domain 0: span 1,3 level SIBLING
[    0.960115]   groups: 3 1
[    0.960119]   domain 1: span 0-3 level CPU
[    0.960122]    groups: 1,3 0,2
[    0.960251] net_namespace: 840 bytes
[    0.960251] Booting paravirtualized kernel on bare hardware
[    0.960349] Time: 17:55:35  Date: 12/04/08
[    0.960387] NET: Registered protocol family 16
[    0.960418] EISA bus registered
[    0.960418] ACPI: bus type pci registered
[    0.960418] PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=4
[    0.960418] PCI: Using configuration type 1 for base access
[    0.960873] ACPI: EC: Look up EC in DSDT
[    0.977458] ACPI: Interpreter enabled
[    0.977462] ACPI: (supports S0 S1 S4 S5)
[    0.977483] ACPI: Using IOAPIC for interrupt routing
[    0.990182] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    0.990182] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[    0.990186] pci 0000:00:02.0: PME# disabled
[    0.990234] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[    0.990238] pci 0000:00:03.0: PME# disabled
[    0.990348] PCI: 0000:00:1d.0 reg 20 io port: [a880, a89f]
[    0.990401] PCI: 0000:00:1d.1 reg 20 io port: [ac00, ac1f]
[    0.990437] PCI: 0000:00:1d.4 reg 10 32bit mmio: [dedffc00, dedffc0f]
[    0.990615] HPET not enabled in BIOS. You might try hpet=force boot option
[    0.990623] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
[    0.990628] pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH4 GPIO
[    0.990648] PCI: 0000:00:1f.1 reg 10 io port: [0, 7]
[    0.990655] PCI: 0000:00:1f.1 reg 14 io port: [0, 3]
[    0.990663] PCI: 0000:00:1f.1 reg 18 io port: [0, 7]
[    0.990670] PCI: 0000:00:1f.1 reg 1c io port: [0, 3]
[    0.990677] PCI: 0000:00:1f.1 reg 20 io port: [fc00, fc0f]
[    0.990684] PCI: 0000:00:1f.1 reg 24 32bit mmio: [0, 3ff]
[    0.990736] PCI: 0000:00:1f.3 reg 20 io port: [400, 41f]
[    0.990803] PCI: bridge 0000:00:02.0 io port: [b000, bfff]
[    0.990863] PCI: 0000:02:00.0 reg 10 64bit mmio: [deef0000, deefffff]
[    0.990909] pci 0000:02:00.0: PME# supported from D3hot D3cold
[    0.990914] pci 0000:02:00.0: PME# disabled
[    0.990955] PCI: bridge 0000:00:03.0 io port: [c000, cfff]
[    0.990959] PCI: bridge 0000:00:03.0 32bit mmio: [dee00000, deefffff]
[    0.991020] PCI: bridge 0000:00:1c.0 io port: [d000, dfff]
[    0.991071] PCI: 0000:04:03.0 reg 10 32bit mmio: [df000000, dfffffff]
[    0.991079] PCI: 0000:04:03.0 reg 14 io port: [e000, e0ff]
[    0.991087] PCI: 0000:04:03.0 reg 18 32bit mmio: [defff000, deffffff]
[    0.991109] PCI: 0000:04:03.0 reg 30 32bit mmio: [defc0000, defdffff]
[    0.991124] pci 0000:04:03.0: supports D1
[    0.991126] pci 0000:04:03.0: supports D2
[    0.991177] PCI: 0000:04:04.0 reg 10 64bit mmio: [defe0000, defeffff]
[    0.991219] pci 0000:04:04.0: PME# supported from D3hot D3cold
[    0.991224] pci 0000:04:04.0: PME# disabled
[    0.991258] pci 0000:00:1e.0: transparent bridge
[    0.991263] PCI: bridge 0000:00:1e.0 io port: [e000, efff]
[    0.991267] PCI: bridge 0000:00:1e.0 32bit mmio: [def00000, dfffffff]
[    0.991291] bus 00 -> node 0
[    0.991300] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.991683] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR14._PRT]
[    0.991897] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIX._PRT]
[    0.992070] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EPA0._PRT]
[    0.992177] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EPA1._PRT]
[    0.992475] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[    0.992475] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[    0.992475] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[    0.992475] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[    0.992475] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[    0.992475] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *7 9 10 11 12 14 15)
[    0.992475] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[    0.992475] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[    0.992475] ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - B2, should be A7 [20080609]
[    0.992475] Linux Plug and Play Support v0.97 (c) Adam Belay
[    0.992475] pnp: PnP ACPI init
[    0.992475] ACPI: bus type pnp registered
[    1.001347] pnp: PnP ACPI: found 13 devices
[    1.001347] ACPI: ACPI bus type pnp unregistered
[    1.001347] PnPBIOS: Disabled by ACPI PNP
[    1.001347] PCI: Using ACPI for IRQ routing
[    1.030019] NET: Registered protocol family 8
[    1.030022] NET: Registered protocol family 20
[    1.030052] NetLabel: Initializing
[    1.030052] NetLabel:  domain hash size = 128
[    1.030052] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.030052] NetLabel:  unlabeled traffic allowed by default
[    1.031236] tracer: 772 pages allocated for 65536 entries of 48 bytes
[    1.031239]    actual entries 65620
[    1.031404] AppArmor: AppArmor Filesystem Enabled
[    1.031424] ACPI: RTC can wake from S4
[    1.050046] system 00:06: ioport range 0x680-0x6ff has been reserved
[    1.050051] system 00:06: ioport range 0x290-0x297 has been reserved
[    1.050062] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
[    1.050066] system 00:07: ioport range 0x800-0x87f has been reserved
[    1.050070] system 00:07: ioport range 0x480-0x4bf has been reserved
[    1.050075] system 00:07: iomem range 0xfec10000-0xfec1ffff has been reserved
[    1.050083] system 00:07: iomem range 0xfed20000-0xfed8ffff has been reserved
[    1.050087] system 00:07: iomem range 0xffb00000-0xffbfffff could not be reserved
[    1.050095] system 00:08: iomem range 0xfec00000-0xfec00fff has been reserved
[    1.050099] system 00:08: iomem range 0xfee00000-0xfee00fff has been reserved
[    1.050108] system 00:0b: iomem range 0xe0000000-0xefffffff could not be reserved
[    1.050117] system 00:0c: iomem range 0x0-0x9ffff could not be reserved
[    1.050120] system 00:0c: iomem range 0xc0000-0xdffff could not be reserved
[    1.050124] system 00:0c: iomem range 0xe0000-0xfffff could not be reserved
[    1.050127] system 00:0c: iomem range 0x100000-0xbfffffff could not be reserved
[    1.050130] system 00:0c: iomem range 0xfff00000-0xffffffff could not be reserved
[    1.085972] pci 0000:00:02.0: PCI bridge, secondary bus 0000:01
[    1.085977] pci 0000:00:02.0:   IO window: 0xb000-0xbfff
[    1.085982] pci 0000:00:02.0:   MEM window: disabled
[    1.085986] pci 0000:00:02.0:   PREFETCH window: disabled
[    1.085993] pci 0000:00:03.0: PCI bridge, secondary bus 0000:02
[    1.085997] pci 0000:00:03.0:   IO window: 0xc000-0xcfff
[    1.086002] pci 0000:00:03.0:   MEM window: 0xdee00000-0xdeefffff
[    1.086007] pci 0000:00:03.0:   PREFETCH window: disabled
[    1.086013] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:03
[    1.086017] pci 0000:00:1c.0:   IO window: 0xd000-0xdfff
[    1.086022] pci 0000:00:1c.0:   MEM window: disabled
[    1.086026] pci 0000:00:1c.0:   PREFETCH window: disabled
[    1.086034] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:04
[    1.086038] pci 0000:00:1e.0:   IO window: 0xe000-0xefff
[    1.086044] pci 0000:00:1e.0:   MEM window: 0xdef00000-0xdfffffff
[    1.086049] pci 0000:00:1e.0:   PREFETCH window: 0x000000c2000000-0x000000c20fffff
[    1.086071] pci 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    1.086077] pci 0000:00:02.0: setting latency timer to 64
[    1.086086] pci 0000:00:03.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    1.086091] pci 0000:00:03.0: setting latency timer to 64
[    1.086103] pci 0000:00:1e.0: setting latency timer to 64
[    1.086108] bus: 00 index 0 io port: [0, ffff]
[    1.086111] bus: 00 index 1 mmio: [0, ffffffffffffffff]
[    1.086113] bus: 01 index 0 io port: [b000, bfff]
[    1.086116] bus: 01 index 1 mmio: [0, 0]
[    1.086118] bus: 01 index 2 mmio: [0, 0]
[    1.086120] bus: 01 index 3 mmio: [0, 0]
[    1.086122] bus: 02 index 0 io port: [c000, cfff]
[    1.086124] bus: 02 index 1 mmio: [dee00000, deefffff]
[    1.086126] bus: 02 index 2 mmio: [0, 0]
[    1.086128] bus: 02 index 3 mmio: [0, 0]
[    1.086130] bus: 03 index 0 io port: [d000, dfff]
[    1.086132] bus: 03 index 1 mmio: [0, 0]
[    1.086134] bus: 03 index 2 mmio: [0, 0]
[    1.086136] bus: 03 index 3 mmio: [0, 0]
[    1.086138] bus: 04 index 0 io port: [e000, efff]
[    1.086141] bus: 04 index 1 mmio: [def00000, dfffffff]
[    1.086143] bus: 04 index 2 mmio: [c2000000, c20fffff]
[    1.086145] bus: 04 index 3 io port: [0, ffff]
[    1.086147] bus: 04 index 4 mmio: [0, ffffffffffffffff]
[    1.086161] NET: Registered protocol family 2
[    1.090019] Switched to high resolution mode on CPU 0
[    1.090057] Switched to high resolution mode on CPU 1
[    1.090449] Switched to high resolution mode on CPU 2
[    1.099993] Switched to high resolution mode on CPU 3
[    1.120109] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    1.120484] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    1.121225] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    1.121763] TCP: Hash tables configured (established 131072 bind 65536)
[    1.121768] TCP reno registered
[    1.140187] NET: Registered protocol family 1
[    1.140346] checking if image is initramfs... it is
[    1.759579] Freeing initrd memory: 8327k freed
[    1.762753] audit: initializing netlink socket (disabled)
[    1.762787] type=2000 audit(1228413335.760:1): initialized
[    1.768207] highmem bounce pool size: 64 pages
[    1.768223] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.772433] VFS: Disk quotas dquot_6.5.1
[    1.772616] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.772798] msgmni has been set to 1689
[    1.773005] io scheduler noop registered
[    1.773009] io scheduler anticipatory registered
[    1.773012] io scheduler deadline registered (default)
[    1.773029] io scheduler cfq registered
[    1.773114] pci 0000:04:03.0: Boot video device
[    1.773282] pcieport-driver 0000:00:02.0: setting latency timer to 64
[    1.773311] pci_express 0000:00:02.0:pcie00: allocate port service
[    1.773469] pcieport-driver 0000:00:03.0: setting latency timer to 64
[    1.773498] pci_express 0000:00:03.0:pcie00: allocate port service
[    1.774282] isapnp: Scanning for PnP cards...
[    2.128798] isapnp: No Plug & Play device found
[    2.195176] Serial: 8250/16550 driver4 ports, IRQ sharing enabled
[    2.195362] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    2.195565] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    2.196603] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    2.197053] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    2.200803] brd: module loaded
[    2.200943] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[    2.201328] PNP: No PS/2 controller found. Probing ports directly.
[    2.203534] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.203544] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.234023] mice: PS/2 mouse device common for all mice
[    2.234291] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    2.234316] rtc0: alarms up to one month
[    2.234615] EISA: Probing bus 0 at eisa.0
[    2.234661] EISA: Detected 0 cards.
[    2.234666] cpuidle: using governor ladder
[    2.234670] cpuidle: using governor menu
[    2.235391] TCP cubic registered
[    2.235428] Using IPI No-Shortcut mode
[    2.235782] registered taskstats version 1
[    2.235931]   Magic number: 4:32:946
[    2.235958] tty ttya1: hash matches
[    2.236061] tty tty3: hash matches
[    2.236126] rtc_cmos 00:02: setting system clock to 2008-12-04 17:55:37 UTC (1228413337)
[    2.236130] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    2.236132] EDD information not available.
[    2.236556] Freeing unused kernel memory: 436k freed
[    2.236680] Write protecting the kernel text: 2632k
[    2.236742] Write protecting the kernel read-only data: 956k
[    2.339961] fuse init (API version 7.9)
[    2.368164] ACPI: SSDT BFF342A0, 02FC (r1    AMI   CPU1PM        1 INTL  2002026)
[    2.368587] processor ACPI0007:00: registered as cooling_device0
[    2.368593] ACPI: Processor [CPU1] (supports 8 throttling states)
[    2.368744] ACPI: SSDT BFF345A0, 02FC (r1    AMI   CPU2PM        1 INTL  2002026)
[    2.369159] processor ACPI0007:01: registered as cooling_device1
[    2.369328] ACPI: SSDT BFF348A0, 0292 (r1    AMI   CPU3PM        1 INTL  2002026)
[    2.369688] processor ACPI0007:02: registered as cooling_device2
[    2.369915] ACPI: SSDT BFF34B40, 0292 (r1    AMI   CPU4PM        1 INTL  2002026)
[    2.370306] processor ACPI0007:03: registered as cooling_device3
[    2.390986] device-mapper: uevent: version 1.0.3
[    2.391443] device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: dm-devel@redhat.com
[    2.699182] usbcore: registered new interface driver usbfs
[    2.699238] usbcore: registered new interface driver hub
[    2.699330] usbcore: registered new device driver usb
[    2.705048] USB Universal Host Controller Interface driver v3.0
[    2.705198] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    2.705225] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    2.705233] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    2.705360] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[    2.705423] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000a880
[    2.705978] usb usb1: configuration #1 chosen from 1 choice
[    2.706053] hub 1-0:1.0: USB hub found
[    2.706080] hub 1-0:1.0: 2 ports detected
[    2.724499] No dock devices found.
[    2.746871] SCSI subsystem initialized
[    2.785330] libata version 3.00 loaded.
[    2.923232] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    2.923251] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    2.923258] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    2.923313] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[    2.923356] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000ac00
[    2.923608] usb usb2: configuration #1 chosen from 1 choice
[    2.923668] hub 2-0:1.0: USB hub found
[    2.923685] hub 2-0:1.0: 2 ports detected
[    3.034381] tg3.c:v3.94 (August 14, 2008)
[    3.034417] tg3 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    3.034435] tg3 0000:02:00.0: setting latency timer to 64
[    3.042604] usb 1-1: new full speed USB device using uhci_hcd and address 2
[    3.079787] eth0: Tigon3 [partno(BCM95721) rev 4101 PHY(5750)] (PCI Express) 10/100/1000Base-T Ethernet 00:13:d4:69:fe:d4
[    3.079796] eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] WireSpeed[1] TSOcap[1]
[    3.079802] eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[    3.079886] tg3 0000:04:04.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[    3.173828] eth1: Tigon3 [partno(BCM95705A50) rev 3003 PHY(5705)] (PCI:33MHz:32-bit) 10/100/1000Base-T Ethernet 00:13:d4:69:fe:d5
[    3.173834] eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] WireSpeed[0] TSOcap[1]
[    3.173838] eth1: dma_rwctrl[763f0000] dma_mask[64-bit]
[    3.178683] ata_piix 0000:00:1f.1: version 2.12
[    3.178710] ata_piix 0000:00:1f.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    3.178775] ata_piix 0000:00:1f.1: setting latency timer to 64
[    3.179100] scsi0 : ata_piix
[    3.179321] scsi1 : ata_piix
[    3.182662] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[    3.182667] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[    3.346609] usb 1-1: configuration #1 chosen from 1 choice
[    3.551253] ata1.00: ATA-5: WDC WD400BB-00CLB0, 05.04E05, max UDMA/100
[    3.551259] ata1.00: 78165360 sectors, multi 16: LBA
[    3.551290] ata1.01: ATAPI: LITE-ON DVDRW SHW-1635S, YS0N, max UDMA/66
[    3.592393] ata1.00: configured for UDMA/100
[    3.630253] ata1.01: configured for UDMA/66
[    3.831438] ata2.00: ATA-6: WDC WD1200BB-00DWA0, 15.05R15, max UDMA/100
[    3.831443] ata2.00: 234441648 sectors, multi 16: LBA48
[    3.831690] ata2.01: ATA-7: ExcelStor Technology J8080, P21OA60A, max UDMA/133
[    3.831694] ata2.01: 160836480 sectors, multi 16: LBA48
[    3.871348] ata2.00: configured for UDMA/100
[    3.910478] ata2.01: configured for UDMA/100
[    3.910659] scsi 0:0:0:0: Direct-Access     ATA      WDC WD400BB-00CL 05.0 PQ: 0 ANSI: 5
[    3.911656] scsi 0:0:1:0: CD-ROM            LITE-ON  DVDRW SHW-1635S  YS0N PQ: 0 ANSI: 5
[    3.911855] scsi 1:0:0:0: Direct-Access     ATA      WDC WD1200BB-00D 15.0 PQ: 0 ANSI: 5
[    3.912015] scsi 1:0:1:0: Direct-Access     ATA      ExcelStor Techno P21O PQ: 0 ANSI: 5
[    3.926683] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[    3.926732] scsi 0:0:1:0: Attached scsi generic sg1 type 5
[    3.926778] scsi 1:0:0:0: Attached scsi generic sg2 type 0
[    3.926825] scsi 1:0:1:0: Attached scsi generic sg3 type 0
[    3.949370] Driver 'sr' needs updating - please use bus_type methods
[    3.954059] sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[    3.954071] Uniform CD-ROM driver Revision: 3.20
[    3.954261] sr 0:0:1:0: Attached scsi CD-ROM sr0
[    3.955109] Driver 'sd' needs updating - please use bus_type methods
[    3.955290] sd 0:0:0:0: [sda] 78165360 512-byte hardware sectors (40021 MB)
[    3.955328] sd 0:0:0:0: [sda] Write Protect is off
[    3.955332] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.955391] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.955520] sd 0:0:0:0: [sda] 78165360 512-byte hardware sectors (40021 MB)
[    3.955553] sd 0:0:0:0: [sda] Write Protect is off
[    3.955556] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.955613] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.955618]  sda: sda1 sda2 <sda5>
[    3.999223] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.999330] sd 1:0:0:0: [sdb] 234441648 512-byte hardware sectors (120034 MB)
[    3.999363] sd 1:0:0:0: [sdb] Write Protect is off
[    3.999366] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    3.999440] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.999542] sd 1:0:0:0: [sdb] 234441648 512-byte hardware sectors (120034 MB)
[    3.999572] sd 1:0:0:0: [sdb] Write Protect is off
[    3.999575] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    3.999629] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.999634]  sdb: sdb1
[    4.019034] sd 1:0:0:0: [sdb] Attached SCSI disk
[    4.019193] sd 1:0:1:0: [sdc] 160836480 512-byte hardware sectors (82348 MB)
[    4.019242] sd 1:0:1:0: [sdc] Write Protect is off
[    4.019247] sd 1:0:1:0: [sdc] Mode Sense: 00 3a 00 00
[    4.019327] sd 1:0:1:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.019470] sd 1:0:1:0: [sdc] 160836480 512-byte hardware sectors (82348 MB)
[    4.019516] sd 1:0:1:0: [sdc] Write Protect is off
[    4.019521] sd 1:0:1:0: [sdc] Mode Sense: 00 3a 00 00
[    4.019595] sd 1:0:1:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.019604]  sdc: sdc1
[    4.032335] sd 1:0:1:0: [sdc] Attached SCSI disk
[    4.275657] PM: Starting manual resume from disk
[    4.275663] PM: Resume from partition 8:5
[    4.275665] PM: Checking hibernation image.
[    4.275837] PM: Resume from disk failed.
[    4.333529] kjournald starting.  Commit interval 5 seconds
[    4.333546] EXT3-fs: mounted filesystem with ordered data mode.
[    7.072899] udevd version 124 started
[    7.525701] intel_rng: FWH not detected
[    7.614993] iTCO_vendor_support: vendor-support=0
[    7.619033] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.03 (30-Apr-2008)
[    7.619157] iTCO_wdt: Found a 6300ESB TCO device (Version=1, TCOBASE=0x0860)
[    7.619344] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    7.631600] input: PC Speaker as /devices/platform/pcspkr/input/input1
[    7.649091] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    7.666232] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    7.693082] EDAC MC: Ver: 2.1.0 Oct 24 2008
[    7.776792] EDAC e752x: tolm = c0000, remapbase = 100000, remaplimit = 13c000
[    7.776896] EDAC MC0: Giving out device to 'e752x_edac' 'E7320': DEV 0000:00:00.0
[    7.776994] EDAC PCI0: Giving out device to module 'e752x_edac' controller 'EDAC PCI controller': DEV '0000:00:00.0' (POLLED)
[    7.999943] input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    8.142799] ACPI: Power Button (FF) [PWRF]
[    8.143005] input: Power Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3
[    8.302775] ACPI: Power Button (CM) [PWRB]
[    8.475809] Linux video capture interface: v2.00
[    8.597334] uvcvideo: Found UVC 1.00 device <unnamed> (046d:08ca)
[    8.644770] input: UVC Camera (046d:08ca) as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1:1.0/input/input4
[    8.735525] usbcore: registered new interface driver snd-usb-audio
[    8.735547] usbcore: registered new interface driver uvcvideo
[    8.735568] USB Video Class driver (v0.1.0)
[   10.118171] loop: module loaded
[   10.178038] lp: driver loaded but no devices found
[   10.535923] Adding 1646620k swap on /dev/sda5.  Priority:-1 extents:1 across:1646620k
[   11.024148] EXT3 FS on sda1, internal journal
[   11.492029] kjournald starting.  Commit interval 5 seconds
[   11.492245] EXT3 FS on sdc1, internal journal
[   11.492255] EXT3-fs: mounted filesystem with ordered data mode.
[   11.518726] kjournald starting.  Commit interval 5 seconds
[   11.519205] EXT3 FS on sdb1, internal journal
[   11.519213] EXT3-fs: mounted filesystem with ordered data mode.
[   12.284264] type=1505 audit(1228413347.281:2): operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" name2="default" pid=4053
[   12.284602] type=1505 audit(1228413347.281:3): operation="profile_load" name="/usr/sbin/cupsd" name2="default" pid=4053
[   12.326167] type=1505 audit(1228413347.318:4): operation="profile_load" name="/usr/sbin/mysqld" name2="default" pid=4057
[   12.380915] type=1505 audit(1228413347.368:5): operation="profile_load" name="/usr/sbin/named" name2="default" pid=4061
[   12.645362] ip_tables: (C) 2000-2006 Netfilter Core Team
[   13.811721] NET: Registered protocol family 10
[   13.812365] lo: Disabled Privacy Extensions
[   13.813433] ADDRCONF(NETDEV_UP): eth1: link is not ready
[   14.629983] tg3: eth1: Link is up at 100 Mbps, full duplex.
[   14.629988] tg3: eth1: Flow control is off for TX and off for RX.
[   14.630175] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   16.051980] warning: `avahi-daemon' uses 32-bit capabilities (legacy support in use)
[   18.391096] type=1503 audit(1228413350.142:6): operation="capable" name="sys_resource" pid=4522 profile="/usr/sbin/named"
[   18.391457] type=1503 audit(1228413350.142:7): operation="inode_permission" requested_mask="::r" denied_mask="::r" fsuid=104 name="/proc/4521/net/if_inet6" pid=4522 profile="/usr/sbin/named"
[   24.993776] eth1: no IPv6 routers present
[   26.605320] ppdev: user-space parallel port driver
[   27.815249] Bridge firewalling registered
[   27.816198] vnet0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
[   27.847030] vnet0: starting userspace STP failed, starting kernel STP
[   28.370782] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   28.371113] CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Plase use
[   28.371118] nf_conntrack.acct=1 kernel paramater, acct=1 nf_conntrack module option or
[   28.371123] sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
[   38.683775] vnet0: no IPv6 routers present
[ 1727.504363] process `miniserv.pl' is using deprecated sysctl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.retrans_time_ms instead.
[ 1727.580499] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1727.580507] CSLIP: code copyright 1989 Regents of the University of California.
[ 1727.580511] SLIP linefill/keepalive option.
[ 1727.689349] PPP generic driver version 2.4.2
[ 1727.795283] NET: Registered protocol family 3
[ 1727.816869] mkiss: AX.25 Multikiss, Hans Albas PE1AYX
[ 1727.884413] AX.25: 6pack driver, Revision: 0.3.0
[ 1727.960047] r3964: Philips r3964 Driver $Revision: 1.10 $
[ 1728.067296] irda_init()
[ 1728.067319] NET: Registered protocol family 23
[ 1728.175941] HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
[ 1728.175951] N_HDLC line discipline registered.
[ 1728.274805] Bluetooth: Core ver 2.13
[ 1728.274965] NET: Registered protocol family 31
[ 1728.274971] Bluetooth: HCI device and connection manager initialized
[ 1728.274977] Bluetooth: HCI socket layer initialized
[ 1728.293709] Bluetooth: HCI UART driver ver 2.2
[ 1728.293717] Bluetooth: HCI H4 protocol initialized
[ 1728.293721] Bluetooth: HCI BCSP protocol initialized
[ 1728.293726] Bluetooth: HCILL protocol initialized
[ 1728.368009] ISDN subsystem Rev: 1.1.2.3/1.1.2.3/1.1.2.2/1.1.2.3/1.1.2.2/1.1.2.2 loaded
[ 1728.399775] gigaset: Hansjoerg Lipp <hjlipp>, Tilman Schmidt <tilman>, Stefan Eilers
[ 1728.399785] gigaset: Driver for Gigaset 307x
[ 3618.397534] type=1503 audit(1228416950.149:8): operation="inode_permission" requested_mask="::r" denied_mask="::r" fsuid=104 name="/proc/4521/net/if_inet6" pid=4524 profile="/usr/sbin/named"
[ 7218.397568] type=1503 audit(1228420550.149:9): operation="inode_permission" requested_mask="::r" denied_mask="::r" fsuid=104 name="/proc/4521/net/if_inet6" pid=4524 profile="/usr/sbin/named"
[10818.397622] type=1503 audit(1228424150.141:10): operation="inode_permission" requested_mask="::r" denied_mask="::r" fsuid=104 name="/proc/4521/net/if_inet6" pid=4523 profile="/usr/sbin/named"
50cc
Post by 50cc »
Uh oh.... Just remembered I don't have any real experience with USB video in Linux.
All that I can make out (you probably found this yourself) is that this part is the USB video:
Looking at the timing stamp from the dmesg output you had USB camera connected at boot up. It looks like the camera has been detected, and seems like all is ok.
I started out with a bunch of USB cameras we had lying around, what I remember from this is that USB is hard to get going correctly. Some of the cameras I used did get recognised similar to yours but I was not able to get them going and gave up.
what do you get from:
sudo ls -l /dev/vid*
roundhay
Post by roundhay »
crw-rw-rw- 1 root video 81, 0 2008-12-04 17:55 /dev/video0
