Ping Long
ilababy
Ping Long
Post by ilababy »
Hallo, I've do new server with Ubuntu Server 8.04.1 and zoneminder 1.22.3.
It's all ok but when i view from remote the streaming is very slow and the ping to the server is 3000/5000 ms.
How can resolve this problem?
Thanks.
coke
Post by coke »
Prior to installing ZoneMinder, did you try a ping test to the machine? Stop ZM and see if your pings are still so long. I'm guessing either your server or remote location has a horrible internet connection.
ilababy
Post by ilababy »
Thanks coke.
When zm is stopping i've a good ping to my server (60-70 ms).
If i start zm the ping is again good but when i view stream (http://ip-server/zm) the ping increase to 2000-5000 ms. When I close the browser the ping is again good.
Lee Sharp
Post by Lee Sharp »
What are the stats on the server? If it is heavily loaded, the network will slow down before the capture will.
ilababy
Post by ilababy »
I've try with IE and the ping with the streaming is ok.
The problem is only with Firefox 3.0 on Ubuntu.
Why?
Thanks.
ilababy
Post by ilababy »
Can you help me please?
Thanks.
Lee Sharp
Post by Lee Sharp »
mjpeg streaming is broken in FF3.0 and leaves connections open. Get FF2, or Opera. (Or the latest bleeding edge beta where they may have fixed it.)
ilababy
Post by ilababy »
Thank you very much.
Now, after ff3 update to 3.05 is all right.
