Advice for ZM compatiable Camera with follwing sepcs
bisana
Post by bisana »
Hi
I would like to query about a network camera which is compatiable with ZM . The specs for the camera are
  • Built-in MPEG-4 and JPEG digital signal output at VGA image size with up to 30 fps
    Power over Ethernet (PoE)
    Internet Protocol: TCP/IP, UDP/IP, HTTP, FTP, DHCP, NTP and SNMP.
    Built-in network interface (10Base-T / 100Base-TX) for remote monitoring by PC.
    Operating condition up to 40 degree centigrade
Could you advice on which camera I should select .
Joseph John
A Linux User
curtishall
Re: Advice for ZM compatiable Camera with follwing sepcs
Post by curtishall »
Indoor or outdoor? Infrared or not?
bisana wrote:Hi
Joseph John
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
bisana
Indoor
Post by bisana »
Hi Curtishall
Thanks for the reply
It is for indoor use . but the environment is of dust and of high temperature . Infrared option is not needed
Joseph John
A Linux User
