# lspci
01:06.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
01:06.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
But I am getting this image...
I have tried it in both Gentoo 2.6 with the driver compiled into the Kernel, and in Ubuntu Server 8.10 which I assume its default install uses a module. Same image for both, camera works fine when plugged directly into a monitor.
I have searched around here, and the resolution I am running at is 320x240, I have played around with others. Higher resolutions 640 etc the image just "breaks" in the control panel.
I have put my options line (as above), in /etc/modprobe.d/bttv etc (and its copied into /etc/modprobe.conf automatically at boot).
Camera is PAL, tested set to PAL, NTSC and Auto.
I have no X setup so I cannot test in some graphical interface. I tested with camsource previously and it has the same image (also it doesn't select the channels properly).
Suggestions?
