For remote host path , do use the "Presets"
Posted: Tue Dec 16, 2008 6:00 am
Hi All
This post is for new comers , who like me would like to try ZM , and will spend time in finding the correct path parameters for the remote host for the camera
I could have saved lots of time , If I had knew about the presets function in monitor setup
Setting up parameters for the monitors is very simple , just select the presets button and select the camera type . U can find the "Presets" link on the top right hand side of monitor editing/define screen
On adding or editing the source you can select the presets link for the parameters for the specified camera . In version 1.23 presets for BTTV,Axis,Panasonic,GadSpot,VEO, and BlueNet are available . Selecting the preset ZM fills up the required value for the remote path variable
Joseph John
Joseph John
