Page 1 of 1
Color got lost
Posted: Tue Jan 13, 2009 7:21 am
by cyrulution
How can I find settings to activate the color of my cameras again?
After I added a new user (and perhaps changed something else in options) all pictures come now in black and white. The setting for brightness, color, hue are all 32768 - I haven't found any other place to edit color settings.
Posted: Fri Jan 16, 2009 10:50 am
by jaume85
Click down in column "Source" in device that camera change color, and show new window, click in second tab "Source" and change option "Capture Palette".
I hope you will help!!
Posted: Fri Jan 16, 2009 4:25 pm
by cyrulution
jaume85 wrote:I hope you will help!! :)
It helped, I tried all options without success. And then I changed "device format" from NTSC to AUTO and finally to PAL - and PAL shows colors.
Tanks a lot!
Another question: do you perhaps know which resolutions I could try? I still have 320 x 240 , and when I try just other numbers I get strange results.
Posted: Fri Jan 16, 2009 8:13 pm
by jaume85
Yes, is normal that you will use some resolutions have problems.
If 320x240 works correctly, test multiply resolution as 640x480 you should work.
If you don't function can be problem of shared memory, visit FAQ :
http://www.zoneminder.com/wiki/index.ph ... esolutions.
