zmc exited abnormally, exit status 255
Posted: Wed Jan 14, 2009 9:37 am
I installed the zm 1.23.3 in a Ubuntu 8.10 (intrepid ibex) on a Acer Aspire with a CrystalEye web cam. The cam works fine with xawtv but it doesn't with zm (the source appears in red in the zm console).
In the zmdc.log the first error I can get is:
zmc -d /dev/bus/usb/004/004' exited abnormally, exit status 255
First I suposed thats it was because the source config params are wrong and I try to query it using
sudo zmu -q -d /dev/bus/usb/004/004 -v
but I the error: "Error, username and password or auth string must be supplied"
I check that the device has perms and it seems ok.
Any ideas ?
TIA,
blas
Any ideas ?
TIA,
blas
