I'm using kodicom 8800r on Centos 5.2 and Zoneminder 1.23.With xawtv i can watch all channels. If i setup only 1 cam on zm are ok, when add a second cam zm stop and show this log
Jan 19 10:23:30 localhost zms[27525]: ERR [Got signal (Floating point exception), crashing]
Jan 19 10:23:30 localhost zms[27525]: ERR [Signal address is (nil), from 0x806785f ]
Jan 19 10:23:30 localhost zms[27525]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x806785f]]
Jan 19 10:23:30 localhost zms[27525]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x804aebf]]
Jan 19 10:23:30 localhost zms[27525]: ERR [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x9d8dec]]
Jan 19 10:23:30 localhost zms[27525]: ERR [Backtrace: /var/www/cgi-bin/nph-zms(__gxx_personality_v0+0x225) [0x804a331]]
Jan 19 10:23:30 localhost zms[27525]: INF [Backtrace complete]
Jan 19 10:23:30 localhost zmc_dvideo0[27523]: ERR [Failed to get camera source 1: Invalid argument]
Jan 19 10:23:30 localhost zmc_dvideo0[27523]: ERR [Failed to pre-capture monitor 1]
Jan 19 10:23:30 localhost zmdc[27423]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Jan 19 10:23:30 localhost zms[27530]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 10:23:30 localhost zms[27530]: ERR [Got signal (Floating point exception), crashing]
Jan 19 10:23:30 localhost zms[27530]: ERR [Signal address is (nil), from 0x806785f ]
Jan 19 10:23:30 localhost zms[27530]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x806785f]]
Jan 19 10:23:30 localhost zms[27530]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x804aebf]]
Jan 19 10:23:30 localhost zms[27530]: ERR [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x9d8dec]]
Jan 19 10:23:30 localhost zms[27530]: ERR [Backtrace: /var/www/cgi-bin/nph-zms(__gxx_personality_v0+0x225) [0x804a331]]
Jan 19 10:23:30 localhost zms[27530]: INF [Backtrace complete]
Jan 19 10:23:33 localhost zmu[27533]: WAR [Shared memory not initialised by capture daemon, some query functions may not be available or produce invalid results]
Jan 19 10:23:38 localhost zmwatch[27460]: ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
Jan 19 10:23:38 localhost zmwatch[27460]: INF [Restarting capture daemon for Cam0, shared memory not valid]
Jan 19 10:23:38 localhost zmdc[27423]: INF ['zmc -d /dev/video0' starting at 09/01/19 10:23:38, pid = 27539]
Jan 19 10:23:38 localhost zmdc[27539]: INF ['zmc -d /dev/video0' started at 09/01/19 10:23:38]
Jan 19 10:23:38 localhost zmc_dvideo0[27539]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 10:23:39 localhost zmc_dvideo0[27539]: INF [Starting Capture]
Jan 19 10:23:39 localhost zmwatch[27460]: INF ['zmc -d /dev/video0' starting at 09/01/19 10:23:38, pid = 27539]
#addr2line -e /var/www/cgi-bin/nph-zms 0x806785f 0x804aebf
/root/ZoneMinder-1.23.3/src/zm_monitor.cpp:3140
/root/ZoneMinder-1.23.3/src/zm_monitor.h:350
line 3140
Warning(( "Unable to store frame as timestamp invalid" ));
else
Warning(( "Unable to store frame as shared memory invalid" ));
frame_count++;
[b] usleep( (1000000 * ZM_RATE_BASE)/(base_fps*abs(replay_rate*2)) );[/b]
if ( ttl )
if ( (now.tv_sec - stream_start_time) > ttl )
break;
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102
options i2c_algo_bit bit_test=1
02:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 3
Memory at dc00b000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
02:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 225
Memory at dc00c000 (32-bit, prefetchable) [size=4K]
02:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 5
Memory at dc00d000 (32-bit, prefetchable) [size=4K]
02:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 201
Memory at dc00e000 (32-bit, prefetchable) [size=4K]
02:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 11
Memory at dc00f000 (32-bit, prefetchable) [size=4K]
kernel.shmmax = 486604800
kernel.shmall = 486604800
Can anyone help me?
