Page 1 of 1
Capture card identification
Posted: Wed Jan 28, 2009 9:35 pm
by ludri
Can someone tell me what card is this? Is it supported?
It is one chip 878A.
Regards
Posted: Sat Jan 31, 2009 8:49 pm
by cordel
What do you get if you plug it in a box and run
lspci -vv
dmesg
Posted: Mon Feb 23, 2009 4:57 pm
by ludri
This is what I get:
lspci -vv
00:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32 (4000ns min, 10000ns max)
Interrupt: pin A routed to IRQ 10
Region 0: Memory at e6003000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data <?>
Capabilities: [4c] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: bttv
Kernel modules: bttv
00:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Latency: 32 (1000ns min, 63750ns max)
Region 0: Memory at e6000000 (32-bit, prefetchable) [size=4K]
dmesg
[ 15.364122] Linux video capture interface: v2.00
[ 15.381539] input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 15.420116] ACPI: Power Button (FF) [PWRF]
[ 15.420362] input: Power Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input5
[ 15.460136] ACPI: Power Button (CM) [PWRB]
[ 15.615362] bttv: driver version 0.9.17 loaded
[ 15.615373] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 15.615488] bttv: Bt8xx card found (0).
[ 15.616520] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
[ 15.616529] PCI: setting IRQ 10 as level-triggered
[ 15.616539] bttv 0000:00:0a.0: PCI INT A -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 15.616559] bttv0: Bt878 (rev 17) at 0000:00:0a.0, irq: 10, latency: 32, mmio: 0xe6003000
[ 15.630774] bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 15.630852] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 31.630042] tveeprom 1-0050: Huh, no eeprom present (err=-6)?
[ 31.630055] bttv0: tuner type unset
[ 31.630063] bttv0: i2c: checking for MSP34xx @ 0x80... not found
[ 47.630039] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[ 63.630039] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[ 79.630428] bttv0: registered device video0
[ 79.630538] bttv0: registered device vbi0
xawtv did not bring me picture under zmlarch live cd.
host system is ubuntu server 8.10 with 1.24.0 compiled from svn.
Posted: Wed Feb 25, 2009 9:33 am
by ludri
Still no luck.
I have added this line into /etc/modprobe.d/options
options bttv card=77 tuner=4 radio=0 triton1=0 vsfx=0 autoload=0 pll=1
No picture. But only blue picture in xawtv / tvtime. In ZM I get darkness without timestamp.
When switching between video sources in tvtime, terminal tells this:
videoinput: Can't get tuner info: Invalid Argument.
with card=77 option in the modprobe
dmesg | grep bttv
[ 16.954148] bttv: driver version 0.9.17 loaded
[ 16.954159] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 16.954261] bttv: Bt8xx card found (0).
[ 16.954291] bttv 0000:00:0b.0: found PCI INT A -> IRQ 12
[ 16.954328] bttv 0000:00:0b.0: sharing IRQ 12 with 0000:00:0b.1
[ 16.954350] bttv0: Bt878 (rev 17) at 0000:00:0b.0, irq: 12, latency: 32, mmio: 0xe6001000
[ 16.955385] bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 16.955441] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 16.955555] bttv0: tuner absent
[ 16.955863] bttv0: registered device video0
[ 16.955955] bttv0: registered device vbi0
[ 16.955979] bttv0: PLL: 28636363 => 35468950 .. ok
lspci -vv
00:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Interrupt: pin A routed to IRQ 12
Region 0: Memory at e6001000 (32-bit, prefetchable) [size=4K]
00:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Region 0: Memory at e6002000 (32-bit, prefetchable) [size=4K]
I have disabled ACPI in bios.
Here are some more images: http://lionservers.com/kmc7016d
Model KMC7016D, Conexant 878A Fusion chip.
