This camera is in the hardware compatibility list in the wiki. I am using the info from the wiki to add this to ZoneMinder 1.23.3 and I get nothing but a black screen, and I do get a authentication error and a shared memory error, but my other camera DCS-6620 I get picture just fine. I am using this username:password@ipaddress format. Anyone used this model before with success? I assume so its in the wiki, thats why I bought it.
Any help would be muchly appreciated, here is the log message.
Feb 3 16:30:40 cameras zms[25345]: INF [Got signal (Terminated), exiting]
Feb 3 16:30:41 cameras zmwatch[12810]: ERR [Can't get shared memory id '7a6d0006', 6: No such file or directory]
Feb 3 16:30:41 cameras zmwatch[12810]: INF [Restarting capture daemon for IK-WD01A, shared memory not valid]
Feb 3 16:30:41 cameras zmdc[12763]: INF ['zmc -m 6' starting at 09/02/03 16:30:41, pid = 25355]
Feb 3 16:30:41 cameras zmdc[25355]: INF ['zmc -m 6' started at 09/02/03 16:30:41]
Feb 3 16:30:41 cameras zmc_m6[25355]: INF [Debug Level = 0, Debug Log = <none>]
Feb 3 16:30:41 cameras zmwatch[12810]: INF ['zmc -m 6' starting at 09/02/03 16:30:41, pid = 25355]
Feb 3 16:30:41 cameras zmc_m6[25355]: INF [Starting Capture]
Feb 3 16:30:41 cameras zmc_m6[25355]: ERR [Invalid response status 400: Bad Request]
Feb 3 16:30:41 cameras zmc_m6[25355]: ERR [Unable to get response]
Feb 3 16:30:41 cameras zmc_m6[25355]: ERR [Failed to post-capture monitor 0]
Feb 3 16:30:41 cameras zmdc[12763]: ERR ['zmc -m 6' exited abnormally, exit status 255]
Feb 3 16:30:42 cameras zms[25363]: INF [Debug Level = 0, Debug Log = <none>]
Feb 3 16:30:42 cameras zms[25363]: WAR [Shared memory not initialised by capture daemon, some query functions may not be available or produce invalid results]
Feb 3 16:30:42 cameras zms[25363]: ERR [Got signal (Floating point exception), crashing]
Feb 3 16:30:42 cameras zms[25363]: ERR [Signal address is 0x10256, no eip ]
Feb 3 16:30:42 cameras zms[25363]: ERR [Backtrace: /lib64/libc.so.6 [0x33d26301b0]]
Feb 3 16:30:42 cameras zms[25363]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x41ee6e]]
Feb 3 16:30:42 cameras zms[25363]: ERR [Backtrace: /var/www/cgi-bin/nph-zms(cos+0xa1f) [0x404edf]]
Feb 3 16:30:42 cameras zms[25363]: ERR [Backtrace: /lib64/libc.so.6(__libc_start_main+0xf4) [0x33d261d8b4]]
Feb 3 16:30:42 cameras zms[25363]: ERR [Backtrace: /var/www/cgi-bin/nph-zms(cos+0xc9) [0x404589]]
Feb 3 16:30:42 cameras zms[25363]: INF [Backtrace complete]
Feb 3 16:30:44 cameras zmc_m5[25320]: ERR [Invalid JPEG file structure: two SOI markers]
Feb 3 16:30:44 cameras zmc_m5[25320]: ERR [Unable to decode jpeg]
Feb 3 16:30:44 cameras zmc_m5[25320]: ERR [Failed to post-capture monitor 0]
Feb 3 16:30:44 cameras zmdc[12763]: ERR ['zmc -m 5' exited abnormally, exit status 255]
IK-WD01A Help!
Re: IK-WD01A Help!
Means the camera did not under stand the request.deadsoulz wrote: Feb 3 16:30:41 cameras zmc_m6[25355]: INF [Starting Capture]
Try switching ZM_HTTP_VERSION under the network tab to 1.0400 - Bad Request
The syntax of the request was not understood by the server.
I switched this to 1.0 and I still get :
Feb 5 08:09:37 cameras zmc_m6[26986]: ERR [Invalid response status 400: Bad Request]
Feb 5 08:09:37 cameras zmc_m6[26986]: ERR [Unable to get response]
Feb 5 08:09:37 cameras zmc_m6[26986]: ERR [Failed to post-capture monitor 0]
Feb 5 08:09:37 cameras zmdc[26334]: ERR ['zmc -m 6' exited abnormally, exit status 255]
Feb 5 08:09:39 cameras zmu[26991]: INF [New Debug Level = 1, New Debug Log = /tmp/zm_debug.log.26991]
Feb 5 08:09:44 cameras zmu[26997]: INF [New Debug Level = 1, New Debug Log = /tmp/zm_debug.log.26997]
Feb 5 08:09:44 cameras zmu[26997]: WAR [Shared memory not initialised by capture daemon, some query functions may not be available or produce invalid results]
Feb 5 08:09:47 cameras zmwatch[26386]: ERR [Can't get shared memory id '7a6d0006', 6: No such file or directory]
Feb 5 08:09:47 cameras zmwatch[26386]: INF [Restarting capture daemon for IK-WD01A, shared memory not valid]
Feb 5 08:09:47 cameras zmdc[26334]: INF ['zmc -m 6' starting at 09/02/05 08:09:47, pid = 27005]
I tested in my browser the username:password@ip-address/video2.mjpg works great in Firefox with the camera.
Output from zmwatch.log
2/05/2009 08:27:37.032881 zmwatch[28055].INF ['zmc -m 7' starting at 09/02/05 08:27:37, pid = 28370]
02/05/2009 08:27:47.035663 zmwatch[28055].ERR [Can't get shared memory id '7a6d0007', 7: No such file or directory]
02/05/2009 08:27:47.035993 zmwatch[28055].INF [Restarting capture daemon for Toshiba, shared memory not valid]
02/05/2009 08:27:47.191866 zmwatch[28055].INF ['zmc -m 7' starting at 09/02/05 08:27:47, pid = 28388]
02/05/2009 08:27:57.194434 zmwatch[28055].ERR [Can't get shared memory id '7a6d0007', 7: No such file or directory]
02/05/2009 08:27:57.194763 zmwatch[28055].INF [Restarting capture daemon for Toshiba, shared memory not valid]
02/05/2009 08:27:57.354388 zmwatch[28055].INF ['zmc -m 7' starting at 09/02/05 08:27:57, pid = 28405]
02/05/2009 08:28:07.357040 zmwatch[28055].ERR [Can't get shared memory id '7a6d0007', 7: No such file or directory]
02/05/2009 08:28:07.357353 zmwatch[28055].INF [Restarting capture daemon for Toshiba, shared memory not valid]
02/05/2009 08:28:07.513073 zmwatch[28055].INF ['zmc -m 7' starting at 09/02/05 08:28:07, pid = 28428]
02/05/2009 08:28:17.515822 zmwatch[28055].ERR [Can't get shared memory id '7a6d0007', 7: No such file or directory]
02/05/2009 08:28:17.516160 zmwatch[28055].INF [Restarting capture daemon for Toshiba, shared memory not valid]
02/05/2009 08:28:17.672641 zmwatch[28055].INF ['zmc -m 7' starting at 09/02/05 08:28:17, pid = 28445]
02/05/2009 08:28:27.675388 zmwatch[28055].ERR [Can't get shared memory id '7a6d0007', 7: No such file or directory]
02/05/2009 08:28:27.675724 zmwatch[28055].INF [Restarting capture daemon for Toshiba, shared memory not valid]
02/05/2009 08:28:27.831142 zmwatch[28055].INF ['zmc -m 7' starting at 09/02/05 08:28:27, pid = 28463]
