1.24 DVD and Grand IP Camera II
I'm trying to get the above combination working, I've got a new PC and I've installed the 1.24 DVD (thanks for that, by the way, very simple and straightforward for us non-Linux people).
I've set an IP address on the camera, found some settings to set the path correctly, and I'm not getting video in the 'feed' window. If I set to 320x240 and 8-bit greyscale, I get a black rectangle instead of video. If I set to anything else, I don't get any image, just the Cambozola message text.
I've tried just connecting directly to the cam with IE from another PC, and also from Firefox on the ZM server itself, and using the link shows the image.
Any suggestions would be appreciated.
If you have any way of sending me a PM with the server address I can take a look at it. I've setup multiple remote cam's while testing out my custom build Wireless Router's and Linksys SLUG's. I'm sure it's something simple, try and switch it from simple to regexp or visa versa. I'm curious what is the path your putting in when setting up the cam? I'm sure we can get it working. I'll check back this evening.
Hi, thanks for your replies, sorry I couldn't reply over the weekend.
I also found that post with the URL and path, and have set the config to those values but to no avail. I also played with the HTTP 1.0/1.1 flag, and simple vs. regexp, and a couple of other settings. If I connect directly to the camera using that path, it shows an image as expected.
I will play some more today, if I can't figure it out I may well take you up on your kind offer of accessing the box remotely to see if you can see what's up. I've used ZM before, but with a USB camera and some time ago.
Success! I now have this working, though I don't seem to have changed much. I have the maximum FPS set at 15, the source details are:
HTTP / simple
user:password@myhostaddress
Port: 80
Path: /still.jpg?nocache
24 bit colour, 640 x480
The last thing I changed was on "buffers", I had increased the image buffer size (frames) from the default to 70, now I have decreased to 10 and it jumped into life.
Now it's showing around 13 fps, though it does give a black screen from time to time, just for a second or so.
HTTP / simple
Port: 80
Well, it "kind of" works. I keep getting events claiming to be dated 1970-01-01 01:00:00, with very large negative number of seconds duration. Also the on-screen display is very erratic - I can open the view window and maybe the display will show, and maybe it won't.
I'm playing some more with the maximum fps to see if it's just overloading the camera.
I know the cam is in general working order as I downloaded a windows app called "Vision GS Private Edition" which accesses the camera without any trouble. But most of the good stuff on that is disabled.
I can't tell whether there's a problem with the camera, or the build, but I keep getting no activity (for example it's showing nothing now, but the config has not changed since 7:15 this morning when it recorded some footage), also I keep getting events of very-large negative number duration, for example :
When selected, these strangely-sized events do not play at all (which I guess is not surprising).
If I can find it, I'll rebuild with my old USB camera and see if it's any better.
Id Name Time Secs Frames Score
847 Event-847 1970-01-01 01:00:00 -11203965.27 82/34 50/100 X
- zoneminder
- Site Admin
- Contact:
What do you get if you go into mysql and type for example?
select * from Frames where Id = 847;
Phil
I've noticed when running remote cams switching between Simple and Regexp on Remote Method options seems to bring the picture back. I'm not familiar with what each option is doing or what would cause one or the other to display the picture. I do remember while building the dvd I added in something that regexp was complaining in a log about, so that should be good.
- zoneminder
- Site Admin
- Contact:
I get a list of 82 frames, the first ten have a blank timestamp, 0.00 Delta and Score 0. The remainder have a proper timestamp, delta of -999999.99 and various scores.zoneminder wrote:What do you get if you go into mysql and typefor example?Code: Select all
(I translated the query to use "EventId" as it complained about "Id". Hope that's what you meant.)
- zoneminder
- Site Admin
- Contact:
Very odd. I notice earlier that you mentioned you dropped the 'buffers' setting to 10, which setting did you mean? That is probably not really big enough for the ring buffer especially if the pre-alarm count is the same. Either increase the ring buffer size to 20 or so, or drop the pre-event count to 5 or so, the post-event one can be as long as you like.
Phil
