1.24.0 rc1-2740 make errors on zm_ffmpeg_camera
Hi all, I am having trouble building ZM 1.24.0 rc1-2740.
I appoligize that I am fairly new to linux, but I have programmed in that other OS longer than I care to talk about <G>...
I am running Fedora 10 on a new machine with Core 2 Quad Q9400 pc. I have installed all of these:
mysql-server mysql-devel php-mysql
pcre-devel perl-DateManip perl-libwww-perl perl-Device-SerialPort perl-MIME-Lite perl-Archive-Zip
video4linux libv4l-devel video4linux-kmdl-2.6.27.12-170.2.5.fc10
ffmpeg ffmpeg-devel
FFmpeg version SVN-r17042, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration:
libavutil 49.14. 0 / 49.14. 0
libavcodec 52.14. 0 / 52.14. 0
libavformat 52.25. 0 / 52.25. 0
libavdevice 52. 1. 0 / 52. 1. 0
built on Feb 8 2009 08:53:03, gcc: 4.3.2 20081105 (Red Hat 4.3.2-7)
Appache and MySQL are running and the "ZM" database has records in it...
I used this ./configure line, and it has an exit 0 at the end...
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-libarch=lib64 ZM_SSL_LIB=openssl --with-ffmpeg=/usr/local
When I run make I get the following errors.
[zoneminder@localhost ZoneMinder-1.24.0]$ make
make all-recursive
make[1]: Entering directory `/home/zoneminder/Development/ZM/ZoneMinder-1.24.0'
Making all in src
make[2]: Entering directory `/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/local/include -Wall -Wno-sign-compare -fno-inline -I/usr/local/include -frepo -g -O2 -MT zm_ffmpeg_camera.o -MD -MP -MF .deps/zm_ffmpeg_camera.Tpo -c -o zm_ffmpeg_camera.o zm_ffmpeg_camera.cpp
zm_ffmpeg_camera.cpp: In member function ‘virtual int FfmpegCamera::PrimeCapture()’:
zm_ffmpeg_camera.cpp:125: error: ‘SWS_BICUBIC’ was not declared in this scope
zm_ffmpeg_camera.cpp:125: error: ‘sws_getCachedContext’ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function ‘virtual int FfmpegCamera::Capture(Image&)’:
zm_ffmpeg_camera.cpp:156: error: ‘sws_scale’ was not declared in this scope
make[2]: *** [zm_ffmpeg_camera.o] Error 1
make[2]: Leaving directory `/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/zoneminder/Development/ZM/ZoneMinder-1.24.0'
make: *** [all] Error 2
I have searched but I can't find where anybody else has posted a similar error.
Can somebody point me in the right direction?
Thanks, Keith
ffmpeg ffmpeg-devel
configuration:
make all-recursive
Making all in src
Thanks, Keith
I'm still not getting there...
Thanks Cordel, I tried that and it still won't make. I know I must be doing something stupid... I saw in another post from you where you said:
Thanks, Keith
I tried building ffmpeg using both sets of options and neither works. Here is the current result of make after rebuilding ffmpeg and rebooting, then trying to build ZM. I even deleted everything for both ffmpeg and ZM and extracting everything fresh.Looks good.
A working config for ffmpeg is --enable-shared --enable-swscaler --enable-pthreads --enable-gpl
ZM does not require any of the extra libraries you have compiled in but it certainly shouldn't hurt to have them
Thanks, Keith
- make all-recursive
Making all in src
g++ -frepo -g -O2 -L/usr/local/lib64 -L/usr/lib64/mysql -o zmc zmc.o zm_box.o zm_buffer.o zm_camera.o zm_comms.o zm_config.o zm_coord.o zm.o zm_db.o zm_debug.o zm_event.o zm_exception.o zm_file_camera.o zm_ffmpeg_camera.o zm_image.o zm_jpeg.o zm_local_camera.o zm_monitor.o zm_ffmpeg.o zm_mpeg.o zm_poly.o zm_regexp.o zm_remote_camera.o zm_remote_camera_http.o zm_remote_camera_rtsp.o zm_rtp.o zm_rtp_ctrl.o zm_rtp_data.o zm_rtp_source.o zm_rtsp.o zm_signal.o zm_stream.o zm_thread.o zm_time.o zm_timer.o zm_user.o zm_utils.o zm_zone.o -lbz2 -lswscale -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -lpthread -ldl -lz -ljpeg
zm_comms.o: In function `Select::calcMaxFd()':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:596: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:596: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:596: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:596: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator!=(std::_Rb_tree_const_iterator<CommsBase> const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:597: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:598: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:599: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:599: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:599: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:599: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator!=(std::_Rb_tree_const_iterator<CommsBase> const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:600: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:601: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
zm_comms.o: In function `Select::addWriter(CommsBase*)':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:641: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::insert(CommsBase* const&)'
zm_comms.o: In function `Select::deleteWriter(CommsBase*)':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:650: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::erase(CommsBase* const&)'
zm_comms.o: In function `Select::clearWriters()':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:660: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::clear()'
zm_comms.o: In function `Select::clearReaders()':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:635: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::clear()'
zm_comms.o: In function `Select':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:563: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::set()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:563: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::vector()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:566: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::~vector()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:558: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::set()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:558: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::vector()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:561: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::~vector()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:553: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::set()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:553: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::vector()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:556: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::~vector()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:549: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::set()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:549: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::vector()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:551: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::~vector()'
zm_comms.o: In function `Select::deleteReader(CommsBase*)':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:625: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::erase(CommsBase* const&)'
zm_comms.o: In function `Select::addReader(CommsBase*)':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:611: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::insert(CommsBase* const&)'
zm_comms.o: In function `Select::wait()':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:672: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::clear()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:674: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:675: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:674: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:674: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:674: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator!=(std::_Rb_tree_const_iterator<CommsBase> const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:677: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::clear()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:679: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:680: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:679: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:679: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:679: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator!=(std::_Rb_tree_const_iterator<CommsBase> const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:693: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:693: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:693: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:693: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator!=(std::_Rb_tree_const_iterator<CommsBase> const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:694: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:695: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:695: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::push_back(CommsBase* const&)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:696: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:696: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:696: undefined reference to `std::set<CommsBase*, std::less<CommsBase>, std::allocator<CommsBase> >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:696: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator!=(std::_Rb_tree_const_iterator<CommsBase> const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:697: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:698: undefined reference to `std::_Rb_tree_const_iterator<CommsBase>::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_comms.cpp:698: undefined reference to `std::vector<CommsBase*, std::allocator<CommsBase> >::push_back(CommsBase* const&)'
zm_comms.o: In function `~set':
/usr/lib/gcc/x86_64-redhat-linux/4.3.2/../../../../include/c++/4.3.2/bits/stl_set.h:93: undefined reference to `std::_Rb_tree<CommsBase*, CommsBase*, std::_Identity<CommsBase>, std::less<CommsBase>, std::allocator<CommsBase> >::~_Rb_tree()'
zm_event.o: In function `Event::createNotes(std::basic_string<char, std::char_traits<char>, std::allocator<char> >&)':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:184: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::begin()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:184: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::_Rb_tree_const_iterator(std::_Rb_tree_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > const&)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:184: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::end()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:184: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator!=(std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:186: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator->() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:188: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator->() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:189: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:193: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:189: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:189: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:189: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator!=(std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:191: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:191: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator!=(std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:184: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator++(int)'
zm_event.o: In function `Event::updateNotes(std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > const&)':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:361: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::size() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:363: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::size() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:365: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::operator=(std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > const&)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:370: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:381: undefined reference to `std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >::pair(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:381: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::insert(std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > const&)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:370: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:370: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:370: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator!=(std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:372: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator->() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:373: undefined reference to `std::_Rb_tree_const_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator->() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:375: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::size() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:377: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::find(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:378: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::end()'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:378: undefined reference to `std::_Rb_tree_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator==(std::_Rb_tree_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:386: undefined reference to `std::_Rb_tree_iterator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >::operator->() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:388: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::begin() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:388: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator++(int)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:388: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:388: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator!=(std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:390: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator*() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:391: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::find(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:392: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::end() const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:392: undefined reference to `std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >::operator==(std::_Rb_tree_const_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&) const'
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:394: undefined reference to `std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::insert(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
zm_event.o: In function `Event':
/home/zoneminder/Development/ZM/ZoneMinder-1.24.0/src/zm_event.cpp:55: undefined reference to `std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::map(std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > const&)'
zm_event.o: In function `~map':
/usr/lib/gcc/x86_64-redhat-linux/4.3.2/../../../../include/c++/4.3.2/bits/stl_map.h:92: undefined reference to `std::_Rb_tree<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::_Select1st<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::~_Rb_tree()'
zm_event.o: In function `~set':
/usr/lib/gcc/x86_64-redhat-linux/4.3.2/../../../../include/c++/4.3.2/bits/stl_set.h:93: undefined reference to `std::_Rb_tree<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::_Identity<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::~_Rb_tree()'
zm_local_camera.o: In function `LocalCamera':
Re: 1.24.0 rc1-2740 make errors on zm_ffmpeg_camera
Appology accepted, and you can consider yourself forgiven.kwire wrote:Hi all, I am having trouble building ZM 1.24.0 rc1-2740.
Tsk, tsk, tsk... All the "exit 0" means is that configure didn't crash during the run. Welcome to the Linux world where looking beyond the obvious for answers is the norm.I used this ./configure line, and it has an exit 0 at the end...
I see that cordel has given you the answer to your concern in a later post but I just thought I'd offer up a bit of insight as to how the GNU build tools work just the same. If you run into a failed build (make) and change anything that you did prior to that time you have to run a make clean as well as reconfigure everything you've built since or you'll run into problems. In other words, if you rebuilt ffmpeg you'll have to reconfigure ZM also, including running make clean.
In answer to your last post, did you run make clean?
Hi, nuck...
OK, you guessed it, I don't know what I'm doing...
Looking at the config.log ( even though it says "exit 0"
) I see something must still be wrong with my ffmpeg path.
Here is one example:
configure:11016: checking ffmpeg/avutil.h usability
configure:11033: g++ -c -g -O2 -I/usr/local/include conftest.cpp >&5
conftest.cpp:131:27: error: ffmpeg/avutil.h: No such file or directory
I used --with-ffmpeg=/usr/local on the ./confgure and I find the file in the /usr/local/include/libavutil folder.
So where did I go wrong?
Thanks, Keith
Thanks, Keith
There are actually several tests for ffmpeg looking in various places as ffmpeg has installed it's self in several places over the years. You only need one set of tests to come back as found. I assume you have done a "make install-libs" for ffmpeg?
I don't actually recognize what the build is looking for which makes me wonder if it's not a more common library that you need like libstdc++ or glibc
- zoneminder
- Site Admin
- Contact:
This may also be related to the ccache issue in this thread. This has the effect of suppressing template recompilations and the build logs show not attempt to recompile.
Phil
Just a shot in the dark here, but did you have a previously installed version of ffmpeg installed? If so, take a minute to double check and make sure that you don't still have ffmpeg (or parts of it) installed in the /usr tree. When you configured ffmpeg did you use --prefix=/usr/local ?? ffmpeg, by default will install in /usr (where it should be).kwire wrote:I used --with-ffmpeg=/usr/local on the ./confgure and I find the file in the /usr/local/include/libavutil folder.
Thanks, Keith
Shouldn't issuing ccache -C accomplish the same goal without having to uninstall it? Granted, the debate rages on as to the overall usefulness of ccache.zoneminder wrote:This may also be related to the ccache issue in this thread. This has the effect of suppressing template recompilations and the build logs show not attempt to recompile.
- zoneminder
- Site Admin
- Contact:
Cordel: "Hi Keith,
You need to rebuild ffmpeg and configure with --enable-swscale and that should sort you all out.
Corey"
I tried to build with that configure option and it said it wasn't valid. I saw when configuring though that ffmpeg/libswscale.so.0 was not found, or some variation of swscale. I saw another post about linking and I have no idea how to do that. I'm having issues with ffmpeg and swscale is the only think left that I haven't messed with. Is there anyway you can help me this? Thanks.
Corey"
-Zach
