RTSP with AVTECH AI 203
cdbao
Post by cdbao »
Yess, I already setup 1.24 on Ubuntu.
I can view live via RTSP of camera by link : rtsp://admin@admin@192.168.1.216/live/h264 (with Quicktime Player)
Now I add this camera into ZM by :
Remote Protocol : RTSP
Remote Host Name : admin:admin@192.168.1.216
Remote Host Port : 80
Remote Host Path : live/h264
Remote Host SubPath :
but I cant get images , help me check this error
newvisionantenna
Post by newvisionantenna »
I'm sure it's probably something to do with your version of ffmpeg. I know up until lately when I was building Zoneminder it would complain about h264 in one of the config files. When I compiled the newest ffmpeg and Zoneminder this morning that error was gone. I'm just taking a guess at this point, but try and build everything again with the latest ffmpeg and see what you get.
cdbao
Post by cdbao »
thanks guy!!
info config is it right?
I dunt know where I will begin to track this problem!!
newvisionantenna
No problem, but you'll probably need Cordel or one of those guys to answer the question about the config file. I just thought from the look of the h264 type that it might require something special with ffmpeg. I could be wrong so don't hold it to me. If you can put the cam on a public IP and send me a PM I can check it here with my current DVD and update I'm about to put out. If you don't want to do that I should have a test server setup for people sometime today or tomorrow if you want to go in at anytime and see if you can get it working. I guess that would help determine if it's your server or something with the config file.
cdbao
Post by cdbao »
okay guy !!
I will contact my staff to public this camera
It is AVTECH camera AI 202 : www.avtech.com.tw
thank you
cordel
Post by cordel »
Heh, RTSP and un-ventured cams. all I can say is Wireshark will be getting allot of use as will as ffplay. I will add instructions to the wiki as I find them and there are no promises that it will work not unlike mjpeg as different vendors do different things.
cdbao
Post by cdbao »
yes, need more information for Intructions RTSP with 1.24.x
I'm testing with more Camera H264 - Mpeg4 such as.
dyu
Post by dyu »
err, the port should be 554.
Changing the rtsp port though is not configurable with these avi20x cameras
