Zoneminder 1.24 + Ethernet camera Sony SNC-RZ30P
caladeira
Post by caladeira »
Hello!
I have a network camera Sony SNC-RZ30P and I'd like to be able to control it with ZoneMinder.
I've been following this post http://www.zoneminder.com/forums/viewtopic.php?t=10995 but it's not for the current ZoneMinder version.
Unfotunately the wiki wasn't much helpfull, so I'd like some help seting it up with ZoneMinder 1.24.
Since I have one camera, I can build the script from scratch, but for that I need some guidelines how it's supposed to work.
Appreciate any help.
christophe_y2k
SNC-RZ30P with zonemind v1.23.3 under linux gentoo 64
Post by christophe_y2k »
Hello
i search to use ptz function on this sony ip cam SNC-RZ30P
i try to use sony visca with
Remote Host Path: /image?speed=5
with no success, i have image but no ptz working....
any idea?
i found doc about sony visca function on this modele
http://www.cs.unc.edu/Research/stc/FAQs ... 2.00EN.pdf
caladeira
Post by caladeira »
Hello!
I've seen that document already.
Unfortunately I don't have enough skills to develop a script and the information on how to do it isn't very helpful if you don't know already the steps involved.
As soon as I have some time, I'll try something and post the results on this thread.
Thanks.
christophe_y2k
SONY PTZ LAN
Ok i try to adapt the PanasonicIP.pm script for sony ptz cam
Scripts are in this folder on my Gentoo 64 server :
/usr/lib64/perl5/site_perl/5.8.8/ZoneMinder/Control
AxisV2.pm
Ncs370.pm
PanasonicIP.pm
PelcoD.pm
Visca.pm
ok that work now my sony cams move !!!!
i need to adapt the script ...
after i send script for this ip cam
Storm
Post by Storm »
I have several SNC-RZ50N cameras. Did somebody manage to make any of the sony cameras to have PTZ?
At the moment I'm using the cameras on ubuntu 9.10 and they work with no problems but I can't make them to be controllable.
christophe_y2k
Hello, script for sony lan ptz cam RZ30
Hello i send my script is not 100% workable, i need to add preset function
but i think you're probably happy to use it
move with control icon ok
move with click on image seem to work but need some adjust ( that work with 640 or 720 large pixel image)
zoom ok
in my linux gentoo64 server the script is here :
/usr/lib64/perl5/site_perl/5.8.8/ZoneMinder/Control/SONY_SNC_RZ30.pm
# ZoneMinder SONY_SNC_RZ30 API Control Protocol Module, $Date: 2009-10-29 08:55:00 +0100 (Tue, 04 Oct 2009) $, $Revision: 2229bis $
# Copyright (C) 2003, 2004, 2005, 2006  Philip Coombes
# Copyright (C) 2009 Christophe DAPREMONT
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module contains the implementation of the SONY_SNC_RZ30 API camera control
# protocol
package ZoneMinder::Control::SONY_SNC_RZ30;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# SONY_SNC_RZ30 Control Protocol
use Time::HiRes qw( usleep );
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    #print( "http://$address/$cmd\n" );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub cameraReset
    my $self = shift;
    Debug( "Camera Reset" );
    my $cmd = "/";
    $self->sendCmd( $cmd );
sub moveMap
    my $self = shift;
    my $params = shift;
    my $xcoord = $self->getParam( $params, 'xcoord' );
    my $ycoord = $self->getParam( $params, 'ycoord' );
    Debug( "Move Map to $xcoord,$ycoord" );
#   my $cmd = "nphControlCamera?Direction=Direct&NewPosition.x=$xcoord&NewPosition.y=$ycoord&Width=".$self->{Monitor}->{Width}."&Height=".$self->{Monitor}->{Height};
    my $cmd = "command/ptzf.cgi?directPT=$xcoord,$ycoord";
sub moveConUp
    my $self = shift;
    Debug( "Move Up" );
    my $cmd = "command/ptzf.cgi?relative=0803";
#    my $cmd = "command/ptzf.cgi?visca=8101060109070302FF";
sub moveConDown
    my $self = shift;
    Debug( "Move Down" );
    my $cmd = "command/ptzf.cgi?relative=0203";
sub moveConLeft
    my $self = shift;
    Debug( "Move Left" );
    my $cmd = "command/ptzf.cgi?relative=0403";
sub moveConRight
    my $self = shift;
    Debug( "Move Right" );
    my $cmd = "command/ptzf.cgi?relative=0603";
sub moveConUpRight
    my $self = shift;
    Debug( "Move Up/Right" );
    my $cmd = "command/ptzf.cgi?relative=0903";
sub moveConUpLeft
    my $self = shift;
    Debug( "Move Up/Left" );
    my $cmd = "command/ptzf.cgi?relative=0703";
sub moveConDownRight
    my $self = shift;
    Debug( "Move Down/Right" );
    my $cmd = "command/ptzf.cgi?relative=0303";
sub moveConDownLeft
    my $self = shift;
    Debug( "Move Down/Left" );
    my $cmd = "command/ptzf.cgi?relative=0103";
sub zoomConTele
    my $self = shift;
    Debug( "Zoom Tele" );
    my $cmd = "command/ptzf.cgi?relative=1103";
sub zoomConWide
    my $self = shift;
    Debug( "Zoom Wide" );
    my $cmd = "command/ptzf.cgi?relative=1003";
sub zoomRelTele
    my $self = shift;
    my $params = shift;
    my $step = $self->getParam( $params, 'step' );
    my $cmd = "command/ptzf.cgi?relative=11$step";
sub zoomRelWide
    my $self = shift;
    my $params = shift;
    my $cmd = "command/ptzf.cgi?relative=10$step";
sub focusConNear
    my $self = shift;
    Debug( "Focus Near" );
    my $cmd = "command/ptzf.cgi?relative=1203";
sub focusConFar
    my $self = shift;
    Debug( "Focus Far" );
    my $cmd = "command/ptzf.cgi?relative=1303";
sub focusAuto
    my $self = shift;
    Debug( "Focus Auto" );
    my $cmd = "/";
sub focusMan
    my $self = shift;
    Debug( "Focus Manual" );
    my $cmd = "/";
sub irisRelOpen
    my $self = shift;
    my $params = shift;
    Debug( "Iris Open" );
#    my $cmd = "/axis-cgi/com/ptz.cgi?riris=$step";
    my $cmd = "/";
sub irisRelClose
    my $self = shift;
    my $params = shift;
    Debug( "Iris Close" );
#    my $cmd = "/axis-cgi/com/ptz.cgi?riris=-$step";
    my $cmd = "/";
sub irisAuto
    my $self = shift;
    Debug( "Iris Auto" );
#    my $cmd = "/axis-cgi/com/ptz.cgi?autoiris=on";
    my $cmd = "/";
sub irisMan
    my $self = shift;
    Debug( "Iris Manual" );
#    my $cmd = "/axis-cgi/com/ptz.cgi?autoiris=off";
     my $cmd = "/";
sub presetClear
    my $self = shift;
    my $params = shift;
    Debug( "Clear Preset $preset" );
#    my $cmd = "/axis-cgi/com/ptz.cgi?removeserverpresetno=$preset";
    my $cmd = "/";
sub presetSet
    my $self = shift;
    my $params = shift;
#    my $cmd = "/axis-cgi/com/ptz.cgi?setserverpresetno=$preset";
    my $cmd = "/";
sub presetGoto
    my $self = shift;
    my $params = shift;
#    my $cmd = "/axis-cgi/com/ptz.cgi?gotoserverpresetno=$preset";
    my $cmd = "command/presetposition.cgi?PresetSet=$preset,zmPresetNumber$preset";
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
    my $cmd = "command/ptzf.cgi?directPT=320,240";
    my $cmd = "command/ptzf.cgi?relative=1010";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
  use ZoneMinder::Database;
  blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
Christophe DAPREMONT, E<lt>christophe@gh-pc.comE<gt>
=head1 COPYRIGHT AND LICENSE
Copyright (C) 2005 by Philip Coombes
Copyright (C) 2009 by Christophe DAPREMONT
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
yackerena
Post by yackerena »
How can i split one Ethernet cable off a router connected to a modem? How can i do this to have 2 active connections off that one cable at once. Can i attach another router to the cable off the previous router?
bcromwell
Post by bcromwell »
You can buy adapters or DIY if you know what you are doing. Firefold.com is where I bought mine. This one is designed for a wall plate, if you want to split just the cable (male ends) then you will need two adapters and two rj45 couplers.
You can see the pinout on the side of the adapter if you diy it.
kingofkya
Post by kingofkya »
Just a FYI Also note when using these adapters you reduce you network speed if you go past 10 ft because you are now allowing outside interfernace because you removed the ground wires.
