Authentication
Posted: Tue Feb 10, 2009 6:12 pm
Hi everyone!
I'm trying to access the ZM server from another web server. The ZM server is in authenticated mode. When I try to access the stream, I generate the auth key and I use it in the stream URL:
This works.
On the other hand, if I try to access the event table using the same auth key, it doesn't work:
Why doesn't the authentication work in the second case? The only difference I can see is that the first URL is calling the CGI script, and the second is calling directly the index.php.
I'd really appreciate your help....
http://localhost/cgi-bin/nph-zms?mode=mpeg&monitor=4&scale=100&bitrate=25000&maxfps=5&format=swf&auth=63a6d3b80abd79f1979542843e7ad0e3
http://localhost/zm/index.php?filter[terms][0][val]=2&filter[terms][0][attr]=MonitorId&auth=63a6d3b80abd79f1979542843e7ad0e3&filter[terms][0][op]==&page=1&view=events
