is there an easy way to upgrade to 1.23?
I got ZM on an Ubuntu 8.04 server machine running. I'd like to upgrade to ZM 1.23 without loosing settings or data. Is there an easy way?
Serenity is not freedom from storm; it's peace within the storm
I'm running 1.22.3 (the version I got from the Ubuntu 8.04 LTS server installation with "apt-get install zoneminder").shoetick wrote:what version of ZM are you running now? The zmupdate.pl script will update your database while leaving your events and monitors untouched.
Where do I get and how do I run zmupdate.pl ?
zmupdate.pl is covered here
But is basic as you just enter the version your upgradng from as an argument.
And backup your database before hand and DO NOT START ZM untll after you are sure everything else is working correctly.
zmupdate.pl –version=<from> [--user=<database> --pass=<database>]
Where can I find "Peter's newer deb". I haven't found it in "downloads" and the wiki.Lee Sharp wrote:If you installed with the deb from the repos, you can install Peters newer deb, and it will upgrade you. You may need to redo the links, and suid zmfix again.
The first link in "Other on the ZM download page is ftp://www.northern-ridge.com.au/zoneminder/ and I think you can find it from there.cyrulution wrote:Where can I find "Peter's newer deb". I haven't found it in "downloads" and the wiki.Lee Sharp wrote:If you installed with the deb from the repos, you can install Peters newer deb, and it will upgrade you. You may need to redo the links, and suid zmfix again.
