I noticed recently if I change the buffers, and the mmap file size is changing zm doesn't work correctly anymore.
I have to remove the /dev/shm/.zm.mmap.1 file manually after it zm generates the new file with a correct size...
mmap and changing buffers
- zoneminder
- Site Admin
- Contact:
I have restarted ZM from web interface, but the mmap file didn't change only if I have deleted it and restarted ZM.zoneminder wrote:Generally speaking if you change buffers etc you should restart ZM to make sure everything picks up the new values. Lots of things attach to the shared memory and it cannot be resized if anything is using it.
- zoneminder
- Site Admin
- Contact:
