event export doesn't work
szimszon
Post by szimszon »
If I click on Export I got a white page, and firebug say:
6 <link rel="shortcut icon" href="graphics/favicon.ico"/>
7 <link rel="stylesheet" href="css/reset.css" type="text/css"/>
8 <link rel="stylesheet" href="skins/classic/css/skin.css" type="text/css" media="screen"/>
9 <link rel="stylesheet" href="skins/classic/views/css/export.css" type="text/css" media="screen"/>
10 <script type="text/javascript" src="tools/mootools/mootools.js"></script>
11 <script type="text/javascript" src="js/mootools.ext.js"></script>
12 <script type="text/javascript">
13 var AJAX_TIMEOUT = 50000;
14
15 var currentView = 'export';
16 var thisUrl = "https://192.168.55.2/zm/index.php";
17 var skinPath = "skins/classic";
18
19 var canEditSystem = true;
20 var canViewSystem = true;
21
22 var refreshParent = false;
23
24 var focusWindow = true;
25 </script>
26 <script type="text/javascript">
27<br />
28<b>Parse error</b>: syntax error, unexpected T_FOREACH in <b>/srv/www/zoneminder/skins/classic/views/js/export.js.php</b> on line <b>5</b><br />
zoneminder
Site Admin
Post by zoneminder »
Thanks for this. Fixed now and will be in next release which will be very shortly or via SVN.
Phil
zoneminder
Site Admin
Fix now on SVN.
Phil
mcg
event export issues
Post by mcg »
Hi - first post .. ZM 1.24.1 just blows me away!
However, have experienced 3 issues and fixed two (Vista, IE7, ZM 1.24.1)
js/mootools.js: innerHTML not supported in IE7 - no fix; this.fireEvent naffed too... impacts zone editing.
fixed several items to export events (excuse php 4 programming):
ajax/event.php: mods:
if ( (isset($_REQUEST['id']) && empty($_REQUEST['id'])) || (isset($_REQUEST['eids']) && empty($_REQUEST['eids'])))
ajaxError( "No event id(s) supplied" );
if ( $exportFile = exportEvents( $_REQUEST['eids'],$exportDetail, $exportFrames, $exportImages, $exportVideo, $ex
portMisc, $exportFormat ) )
skins/classic/views/js/export.js:
skins/classic/views/js/video.js:
change
parms += '&'+form.toQueryString();
to
parms += '&'+$(form).toQueryString();
Mootools issues with IE7 real bummer, guess I'll have to edit zones on IE 6
mcg
missed one change
Post by mcg »
skins/classic/includes/export_functions.php
in exportEvents:
if ( is_array( $eids ) )
foreach ( $eids as $eid )
$exportFileList = array_merge( $exportFileList, exportFileList( $eid,
$exportDetail, $exportFrames, $exportImages, $exportVideo, $exportMisc ) );
zoneminder
Site Admin
Thanks for taking the time to come back with such a useful post including fixes. I have implemented them (or similar) here and they should be on SVN later.
I hadn't noticed the IE7 mootools issues so will have a bit of a dig around at that to see if there are any workarounds that might work. Alternatively ZM is using mootols v 1.11 and I have been looking for an excuse to migrate it up to v1.21 so this might be that excuse, especially if it fixes the issues.
Phil
zoneminder
Site Admin
The SVN version of ZM 1.24.1 is now using mootools 1.2.1. As far as I can tell it works correctly now in IE7 etc.
Phil
zoneminder
Site Admin
A few further migration tweaks have gone in today also.
Phil
mcg
Updates?
Post by mcg »
Hi - thanks for the updates.
Would you be able to forward the offical updates... I seem to have missed something - export fails when clicked from filter window, but works from the Event Viewer window [ IE 6 sp3 browser ]
I should test on IE 8 now too.
pvanthony
Re: Updates?
Post by pvanthony »
mcg wrote:I seem to have missed something - export fails when clicked from filter window, but works from the Event Viewer window
Using version 1.24.2 and not able to export from the filter window. Is there a patch that can be downloaded to solve this problem?
Please advise.
By the way, 1.24.2 is awesome.
P.V.Anthony
pvanthony
Re: Updates?
Post by pvanthony »
pvanthony wrote: Using version 1.24.2 and not able to export from the filter window. Is there a patch that can be downloaded to solve this problem?
Following the post on this thread and made some changes on the code and it works. The export works.
Here is the patch for 1.24.2.
------------ start -------------------------
# diff -ruN ./ajax/event.php.org ./ajax/event.php
--- ./ajax/event.php.org 2009-07-29 01:13:50.073354656 +0800
+++ ./ajax/event.php 2009-07-29 01:16:48.713354123 +0800
@@ -1,6 +1,6 @@
<?php
-if ( empty($_REQUEST['id']) && empty($_REQUEST['eids']) )
+if ((isset($_REQUEST['id']) && empty($_REQUEST['id'])) || (isset($_REQUEST['eids']) && empty($_REQUEST['eids'])) )
--------------- end -----------------------
--------------- start ----------------------
diff -ruN ./skins/classic/includes/export_functions.php.org ./skins/classic/includes/export_functions.php
--- ./skins/classic/includes/export_functions.php.org 2009-07-29 01:26:17.430355432 +0800
+++ ./skins/classic/includes/export_functions.php 2009-07-29 01:28:05.624354257 +0800
@@ -252,7 +252,7 @@
- $exportFileList = array_merge( $exportFileList, exportFileList( $eid ), $exportDetail, $exportFrames, $exportImages, $exportVideo, $exportMisc );
+ $exportFileList = array_merge( $exportFileList, exportFileList( $eid, $exportDetail, $exportFrames, $exportImages, $exportVideo, $exportMisc ));
else
----------------end -----------------------
Hope this is useful to others.
P.V.Anthony
calexguest
How to patch
Post by calexguest »
I've never patched a file before. I tried creating a file call 'event.diff' with the code between start and end in my zoneminder directory. Then, I ran 'patch event.diff' as root and it just sits there until I escape out.
Help! Anyone!
Thanks,
Alex
estranged1977
Post by estranged1977 »
Can you please tell us how to use this patch???
Fitch
Post by Fitch »
Would the above patch help my problem?
http://www.zoneminder.com/forums/viewtopic.php?t=16110
and if so, I also have to ask the same question as estranged...
Fitch
Post by Fitch »
O.K, I've read up on how to patch, and I've downloaded patch (seemed a good idea at the time).
I've gone to what I hope is the correct directory, but didn't get very far (line 6 to be exact)
brafferton@cameras:~$ cd /usr/share/zoneminder/ajax
brafferton@cameras:/usr/share/zoneminder/ajax$ patch event.php event.diff
patching file event.php
patch: **** malformed patch at line 6: <?php
And is it going to help my specific problem - as per previous post?
