I have read in the forums how to do this with a 4 port card/with one chip, so does it follow I can do the same with a single connection?
That being: use /dev/video1...4 or more in the ZM configuration for monitors.
I hacked the php script for channel selection to add up to 65 cameras, but this did not work. I did get it working by using channel 0 and then changing the actual channel on the card with tvtime.
Do I need to dump the "stuck" camera or the card (for a multi port)?
