Hi guys,
All of our servers run FreeBSD (6.2 or 7) and I was wondering what the process of installing ZoneMinder is. I know that there is a port for 1.23, is there one out yet for 1.24? I did a search but couldnt find anything.
Thanks in advance
Ryan
BSD Port
Hey there,
Im not sure - I haven't had the time to be able to try, I looked breifly at what was involved in porting 1.23 and it wasn't "easy". I figure 1.24 would be just as involved if not more so.
Because our servers are mostly in production, changing them really isnt an option.
Also - I am using IP cameras = no capture cards.
This does not solve your Freebsb problem, but if you really need something going right away I can offer Hosted VPS Zoneminder servers with full root access and static ip's. This would allow you to keep your production servers in place and have the option for remote Zoneminder servers inside dedicated Co-location servers.
You can take a look at a live dedicated demo and try out your camera's on it if you want. The demo is running 1.24.0 at the moment and will be upgraded to fix some of the recent bugs. See if it suits your needs and we can go from there. Log in with test/test and you will be able to edit a couple monitors.
http://67.210.200.98/
Re: BSD Port
Not being someone who is much more than aware of what FreeBSD is, I can't tell you exactly how to go about getting ZM-1.24 up and running on FreeBSD. The process for various Linux based OS's is pretty much the same, albeit as different as the distros themselves are since all have their own quirks.rjfjohnson wrote:Hi guys,
Thanks in advance
Ryan
As simple as I can put it, ensure that you have whatever perl dependencies are required, get ffmpeg installed and running and then install ZoneMinder. Whether you use prebuilt packages or build from source all depends on what is available. At this point in time it's a safe bet that you'll be building and installing ZM-1.24 from source. Don't let any of this deter you. If I can do it, anybody can.
Re: BSD Port
Unfortunately BSD is not as simple as the libraries are very different as rjfjohnson is already aware. It's more of a unix OS.nuck wrote: The process for various Linux based OS's is pretty much the same, albeit as different as the distros themselves are since all have their own quirks.
- zoneminder
- Site Admin
- Contact:
