I thought I had ffmpeg working ok as it will generate files for download in mpg, wmv, avi formats just fine.
Out of interest I thought I'd try mpeg streaming - no success. found this in the logs
[Mon Feb 16 20:32:05 2009] [notice] Apache/2.2.9 (Ubuntu) PHP/5.2.6-2ubuntu4.1 with Suhosin-Patch configured -- resuming normal operations
[Mon Feb 16 20:33:36 2009] [error] [client 192.168.1.10] socket_sendto( /tmp/zms-221004s.sock ) failed: Connection refused, referer: http://192.168.1.228/html/zm/index.php?view=watch&mid=4
[Mon Feb 16 20:33:36 2009] [error] [client 192.168.1.10] array (\n 0 => \n array (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-221004s.sock ) failed: Connection refused',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.228/html/zm/index.php?view=watch&mid=4
Using latest everything - maybe a permission error ?
Tim
Streaming with ffmpeg ?
Re: Streaming with ffmpeg ?
Safe bet. The log is reporting connection refused.timf wrote:maybe a permission error ?
Tim
Permission error...
that's what I thought , but the permissions for the tmp directory are ok.
So not sure where else to look for permission issues.
Will dig around a bit more - in the meantime any suggestions gratefully accepted
I have this issue too. I compiled 2 nights ago the latest ffmpeg and recompiled the released 1.24.0... With no lucktimf wrote: [Mon Feb 16 20:32:05 2009] [notice] Apache/2.2.9 (Ubuntu) PHP/5.2.6-2ubuntu4.1 with Suhosin-Patch configured -- resuming normal operations
Timf,
Just had to wipe what I said and start over, had it confused on what you were saying. I'll get back with you if I find it works for me.
Ok, looks like the same issue here but the strange thing is I know this worked a couple builds ago on my DVD. I actually used it with IE7 and it worked fine, now it looks like something got changed up in ffmpeg or Zoneminder that's not allowing to it work.
Now I have the latest ffmpeg (17530) and zoneminder (2785)
The video stream seems to work at least with "&format=avi"
But I had a lot of other trouble:
I use mediaplayerconnectivity plugin for ff and my media player was vlc. I got a message Unable to open stream. After I run vlc with the url from console I got TLS errors
because my zoneminder is behind https
but I didn't have a certificate to check the sites's own.
I was able to switch off the vlc's cert-checking (~/.vlc/vlcrc - tls-check-cert=0) after that the situation changed. There was stream but
So I went on by mplayer
But I don't know that is it possible to play stream from https by mplayer at all.
At the end I got working streaming with:
It works for me
avi demuxer error: avi module discarded (invalid file)
wget --no-check-certificate "https://<domain.tld>/zm-cgi-bin/zms?mode=auto&monitor=1&scale=100&bitrate=75000&maxfps=10&format=avi" -q -O- | mplayer -cache 100 -noconsolecontrols file://-
