Anyone - help me solve this problem. I have already tried to change any checkbox, parametres etc. If i change Function camera from Mocord to Record - events have length of 10 minutes.
Sorry my language. It's not my native language.
What was the value it was set to originally? Did you remember to completely restart ZM?dinyasoft wrote:I try any variant. But is not solved my trouble.zoneminder wrote:Check what Options->Config->ZM_EVENT_CLOSE_MODE is set to. If it is set to Alarm you will probably want it to be Time or Idle. I will check what the default setting for this is.
