DBD::mysql::db error
Posted: Fri Feb 13, 2004 5:36 am
I'm starting a new thread as I decided that it would be best to re-install the latest version
of ZM.
I started fresh, ./configure... runs fine but when running 'perl ./zmconfig.pl', I get the following
error:
Saving config to 'zmconfig.txt'
Saving config to DB
DBD::mysql::db do failed: Table 'zm.Config' doesn't exist at ./zmconfig.pl line 1270, <> line 74.
Can't do 'delete from Config': Table 'zm.Config' doesn't exist at ./zmconfig.pl line 1270, <> line 74.
Looks like it's not creating zm.Config [?] and it didn't create the schema file to import into the db.
I tried installing 1.17.1 again with the same error so I must be doing something wrong as I had
1.17.1 basically running.
Any help is appreciated greatly,
TIA
Kevin
of ZM.
error:
Saving config to DB
TIA
Kevin
