I just started trying out zoneminder on ubuntu desktop 8.10
After a while i finally figured out how to set the program up, allthough i am not sure everything is done correctly
But my question at hand, is that I got two USB webcams, which I would like to use, as the security cameras. At first I could not get eny picture from either one of them, but after some time i discovered, that I could use one of my cams, if I set the capture width to 160 and capture height to 120, but if I make the command
zmu -d /dev/video0 -q -v
Video Capabilities
Name: QCM USB Camera
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 320
Maximum Height: 240
Minimum Width: 160
Minimum Height: 120
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 32768
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
And for my second camera /dev/video1 I'll get this info:
Video Capabilities
Name: CIF Single Chip
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 352
Maximum Height: 288
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 352
Height: 288
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 8
Brightness: 1028
Hue: 0
Colour :0
Contrast: 0
Whiteness: 0
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
So please, can enyone tell me if I made some bad setup, or could it be my hardware?
So to sum up, my first cam works, but only at a low resolution and second cam won't show video at eny resolutions, but they both works fine in Cheese for example.
Please help
