I have an RTSP camera with the following URL:
rtsp://admin:admin@192.168.0.60/live/mpeg4
So what are the setting?
Remote Host Name: admin:admin@192.168.0.60
Remote Host Port: 80
Remote Host Path: /live/mpeg4
Remote Host SubPath: ?????
What means "Remote Host SubPath"?
- zoneminder
- Site Admin
- Contact:
It depends on the camera, whate Make/Model is it?
The subpath is the part of the query that is used to select the video or audio track and is returned in the result to the SDP query however ffmpeg hides all that and it is impossible to get access at present. If you can get an image with ffplay and run a WireShark trace it will be more obvious. You could try using /trackID= as that seems to be fairly common.
Phil
The camera is an Avtech AV201
http://www.zoneminder.com/forums/viewto ... 7226#47226
I will test with wireshark, but run ok with quicktime.
I will back with results
