Moving to SVN from 1.24.0 and back?
kwire
Post by kwire »
I am currently running version 1.24.0 and I want to update to the SVN version of ZoneMinder.
I am a beginner but I want to be able to switch back to 1.24.0 if I fail miserably in my first SVN attempt, so can somebody review my planned steps?
Note: Both the Apache and MySQL Servers are running and the ZoneMinder Server is stopped.
1 ) Make a MySQL backup of the zm Catalog (database)
2 ) Open a Konsole window.
3 ) Log in as root.
4 ) Navigate to the directory where I installed ZoneMinder 1.24.0 (~/<my_user_name>/Development/ZM/ZoneMinder-1.24.0)
5 ) Execute this:
make uninstall
6 ) Quit root
7 ) Navigate to ~/<my_user_name>/Development/ZM
8 ) Execute this:
svn co http://svn.zoneminder.com/svn/zm/trunk zm_svn  (This will put the SVN in ~/<my_user_name>/Development/ZM/zm_svn)
9 ) Navigate to zm_svn (cd zm_svn)
10 ) Execute this:
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-libarch=lib64 ZM_SSL_LIB=openssl --with-ffmpeg=/usr/local
11 ) login as root
12 ) Execute these:
make
make install
13 ) Quit root
14 ) Execute this:
zmupdate.pl -f
15 ) Execute this:
zmpkg.pl start
Now I probably will never want or need to go back to the original 1.24.0, but just in case I do here are the steps I would follow.
Stop the ZoneMinder server, then do these steps...
1 ) Restore my previous MySQL backup that I made in step 1 above
3 ) Log in as root.
4 ) Navigate to the directory where I installed ZoneMinder SVN (~/<my_user_name>/Development/ZM/zm_svn)
5 ) Execute this:
make uninstall
6 ) Quit root
7 ) Navigate to the directory where I installed ZoneMinder 1.24.0 (~/<my_user_name>/Development/ZM/ZoneMinder-1.24.0)
8 ) Execute this:
9 ) login as root
10 ) Execute these:
make
make install
11 ) Quit root
12 ) Execute this:
zmpkg.pl start
And bingo I should be back to 1.24.0...
Does it look good?
Thanks for your time, Keith
curtishall
Re: Moving to SVN from 1.24.0 and back?
Post by curtishall »
Technically you should backup the mysql database prior to installing from SVN:
mysqldump --add-drop-database --create-options -u mysqluser -ppassword zmdatabase >> zm-1.2.4-pre-svn.dump
If you had to revert back to 1.24.0 you should:
Run 'make uninstall' in the 1.24.0-svn tree. Technically _shouldn't_ be needed however if a new file gets throw into svn and not in 1.24.0-stable you don't want extra files laying around
Then 'make install' in the 1.24.0-non-svn tree
And lastly restore the database with mysql -u mysqluser -ppassword zmdatabase < zm-1.2.4-pre-svn.dump
You shouldn't need to run zmupdate.pl -f
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
kwire
Post by kwire »
Thanks Curtis,
Just to be clear when you say
you are talking about if you are going back from SVN to Stable correct?
Keith
curtishall
kwire wrote:Thanks Curtis,
Keith
Correct..if you need to go back to stable from SVN just make install from 1.24.0 (stable) and restore the database you do not need to run zmupdate.pl -f
Curtis Hall
Bluecherry
