I'm using debian lenny and I have compiled zm 1.23 debian's source package. After configuration now it works well but I can use just with m-jpeg. I can't use stream.
I installed the binary ffmpeg from apt-get and other software dependencies for zm compilation. then I did the compilation of zm 1.23
Is it some hint for troubleshooting zm's stream ?
ZM can't stream video
analog cameras
I'm using only analog cameras. They have 420L each.volkan2k wrote:try this one
you have to set the camera resolution and the monitior resolution at the same one
You have to download the file (wget http://www.zoneminder.com/fileadmin/dow ... bozola.jar)
after this, copy the file to the zoneminder directory (cp cambozola.jar /var/www/zm/)
then reboot the linux and when you access zm console on IE, go to "options". on "images" tab, set ZM_CAN_STREAM > auto, ZM_STREAM_METHOD > jpeg, ZM_OPT_CAMBOZOLA > true and ZM_PATH_CAMBOZOLA > cambozola.jar
this should work...
this should work...
