missing the file zm_update-1.24.0.sql (under svn)
Normando
Post by Normando »
with the content:
-- There are no updates from a 1.24.0 database to 1.24.1
I suposse the are no changes from 1.24.0 to 1.24.1 db.
cordel
Post by cordel »
The file is there else you would have an error instead, should be labeled as the previous version "zm_update_1.24.0.sql".
But yes, there are no updates.
Normando
Post by Normando »
I have download zm and yes, the file is there, but not through svn. I suppose svn hold the last files. The same for /web/includes/config.php, /web/scripts.
And viceversa, PelcoP.pm, zmconfgen.pl, stamp.h exist under svn but not into the release 1.24.1
zoneminder
Site Admin
Post by zoneminder »
I forgot to add the 1.24.0 DB update to SVN. That should be corrected now.
There will be a number of files that exist only in SVN or in the tarball. Certain files I need to keep track of but are used only to prepare the distribution, e.g. zmconfgen.pl which generates configuration files. Likewise files that aren't ready for primetime yet (PelcoP.pm). Also many of the .in files are now in SVN, this is to make sure people can build ZM from the SVN distro without needing all the development tools. Most of these files are autogenerated and until recently have been uncontrolled.
Phil
