I installed 1.24.1 version , i have 2 rtsp cameras (HITRON ESS540) but a i cant see any image from cameras with remote rtsp option, the logs with debug level 7 show:
02/24/09 04:19:37.507607 zmc_m1[10079].INF-zm_debug.c/292 [New Debug Level = 7, New Debug Log = /tmp/zm_debug.log.10079]
02/24/09 04:19:38.271291 zmc_m1[10079].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
02/24/09 04:19:38.273138 zmc_m1[10079].DB1-zm_thread.cpp/240 [Creating thread]
02/24/09 04:19:38.273419 zmc_m1[10079].DB2-zm_rtsp.cpp/187 [RTSP Local SSRC is 6b8b4567]
02/24/09 04:19:38.273470 zmc_m1[10079].DB1-zm_thread.cpp/276 [Starting thread]
02/24/09 04:19:38.273742 zmc_m1[10081].DB2-zm_thread.cpp/252 [Invoking thread]
02/24/09 04:19:38.274207 zmc_m1[10079].DB1-zm_thread.cpp/297 [Started thread 10081]
02/24/09 04:19:38.276476 zmc_m1[10079].DB1-zm_monitor.cpp/338 [monitor purpose=1]
02/24/09 04:19:38.276537 zmc_m1[10079].DB1-zm_monitor.cpp/345 [mem.size=9217192]
02/24/09 04:19:38.325559 zmc_m1[10079].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
02/24/09 04:19:38.328530 zmc_m1[10079].DB1-zm_monitor.cpp/458 [Monitor New has function 2]
02/24/09 04:19:38.328590 zmc_m1[10079].DB1-zm_monitor.cpp/459 [Monitor New LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
02/24/09 04:19:38.328638 zmc_m1[10079].DB1-zm_monitor.cpp/460 [Monitor New IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
02/24/09 04:19:38.329970 zmc_m1[10079].DB1-zm_zone.cpp/889 [Got 1 zones for monitor New]
02/24/09 04:19:38.330041 zmc_m1[10079].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 319,0 319,239 0,239]
02/24/09 04:19:38.330104 zmc_m1[10079].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 319,0 319,239 0,239']
02/24/09 04:19:38.330193 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
02/24/09 04:19:38.330243 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 319,0 from polygon string]
02/24/09 04:19:38.330290 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 319,239 from polygon string]
02/24/09 04:19:38.330338 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 0,239 from polygon string]
02/24/09 04:19:38.330392 zmc_m1[10079].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
02/24/09 04:19:38.330469 zmc_m1[10079].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0, OF: 0]
02/24/09 04:19:38.333004 zmc_m1[10079].DB1-zm_monitor.cpp/2457 [Loaded monitor 1(New), 1 zones]
02/24/09 04:19:38.333098 zmc_m1[10079].INF-zmc.cpp/186 [Starting Capture]
02/24/09 04:19:38.390300 zmc_m1[10079].DB2-zm_remote_camera_rtsp.cpp/112 [Waiting for sources]
02/24/09 04:19:38.519947 zmc_m1[10081].DB2-zm_rtsp.cpp/137 [Assigned RTP port range is 40200-40499]
02/24/09 04:19:38.520199 zmc_m1[10081].DB2-zm_rtsp.cpp/44 [Sending RTSP message: SETUP rtsp://172.16.0.3:70701 RTSP/1.0
Transport: RTP/AVP;unicast;client_port=40200-40201
CSeq: 1
02/24/09 04:19:38.522547 zmc_m1[10081].DB2-zm_rtsp.cpp/70 [Received RTSP response: RTSP/1.0 404 Stream Not found
CSeq: 1
(42 bytes)]
02/24/09 04:19:38.522747 zmc_m1[10081].ERR-zm_rtsp.cpp/90 [Unexpected response code 404, text is 'Stream Not found']
02/24/09 04:19:38.522917 zmc_m1[10081].DB2-zm_thread.cpp/263 [Exiting thread, status 0xffffffff]
02/24/09 04:19:48.460649 zmc_m1[10079].FAT-zm_remote_camera_rtsp.cpp/118 [No RTSP sources]
02/24/09 04:19:48.461876 zmc_m1[10079].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
02/24/09 04:19:48.462127 zmc_m1[10079].ERR-zm_signal.cpp/84 [Signal address is (nil), from 0x5d2402]
02/24/09 04:19:48.462746 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: [0x5d2402]]
02/24/09 04:19:48.462854 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: [0x5d2402]]
02/24/09 04:19:48.462960 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(gsignal+0x50) [0x9c5d10]]
02/24/09 04:19:48.463058 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(abort+0x101) [0x9c7621]]
02/24/09 04:19:48.463159 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x8055709]]
02/24/09 04:19:48.463253 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x807d2a9]]
02/24/09 04:19:48.463653 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804c54d]]
02/24/09 04:19:48.463756 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x9b2dec]]
02/24/09 04:19:48.463859 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc(__gxx_personality_v0+0x381) [0x804c011]]
02/24/09 04:19:48.463963 zmc_m1[10079].INF-zm_signal.cpp/125 [Backtrace complete, please execute the following command for more information]
02/24/09 04:19:48.511417 zmc_m1[10079].INF-zm_signal.cpp/126 [addr2line -e /usr/local/bin/zmc(__gxx_personality_v0+0x381) 0x5d2402 0x5d2402 0x9c5d10 0x9c7621 0x8055709 0x807d2a9 0x804c54d 0x9b2dec 0x804c011]
I can see good images with vlc media player.
I tried with alternate method ffmpeg but i just see a distorted and bad picture image
Im running centos 5.2
Please help me...
dasa
no images with rtsp option
About to head out the door, but if you PM me the info I'll add it to my online VPS server for testing. I won't put it public so no worries on that. I'll just make you a login if it works. The only camera I tested with rtsp was the camera blue cherry let me try and it worked perfect. I've also included the ffmpeg patch in my 1.24.1 DVD so I'd be curious to see if the username and password issue has been fixed, atleast that's what I think that patch was for.
