no images with rtsp option
Posted: Tue Feb 24, 2009 11:39 am
I installed 1.24.1 version , i have 2 rtsp cameras (HITRON ESS540) but a i cant see any image from cameras with remote rtsp option, the logs with debug level 7 show:
02/24/09 04:19:37.507607 zmc_m1[10079].INF-zm_debug.c/292 [New Debug Level = 7, New Debug Log = /tmp/zm_debug.log.10079]
02/24/09 04:19:38.271291 zmc_m1[10079].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
02/24/09 04:19:38.273138 zmc_m1[10079].DB1-zm_thread.cpp/240 [Creating thread]
02/24/09 04:19:38.273419 zmc_m1[10079].DB2-zm_rtsp.cpp/187 [RTSP Local SSRC is 6b8b4567]
02/24/09 04:19:38.273470 zmc_m1[10079].DB1-zm_thread.cpp/276 [Starting thread]
02/24/09 04:19:38.273742 zmc_m1[10081].DB2-zm_thread.cpp/252 [Invoking thread]
02/24/09 04:19:38.274207 zmc_m1[10079].DB1-zm_thread.cpp/297 [Started thread 10081]
02/24/09 04:19:38.276476 zmc_m1[10079].DB1-zm_monitor.cpp/338 [monitor purpose=1]
02/24/09 04:19:38.276537 zmc_m1[10079].DB1-zm_monitor.cpp/345 [mem.size=9217192]
02/24/09 04:19:38.325559 zmc_m1[10079].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
02/24/09 04:19:38.328530 zmc_m1[10079].DB1-zm_monitor.cpp/458 [Monitor New has function 2]
02/24/09 04:19:38.328590 zmc_m1[10079].DB1-zm_monitor.cpp/459 [Monitor New LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
02/24/09 04:19:38.328638 zmc_m1[10079].DB1-zm_monitor.cpp/460 [Monitor New IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
02/24/09 04:19:38.329970 zmc_m1[10079].DB1-zm_zone.cpp/889 [Got 1 zones for monitor New]
02/24/09 04:19:38.330041 zmc_m1[10079].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 319,0 319,239 0,239]
02/24/09 04:19:38.330104 zmc_m1[10079].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 319,0 319,239 0,239']
02/24/09 04:19:38.330193 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
02/24/09 04:19:38.330243 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 319,0 from polygon string]
02/24/09 04:19:38.330290 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 319,239 from polygon string]
02/24/09 04:19:38.330338 zmc_m1[10079].DB3-zm_zone.cpp/796 [Got coordinate 0,239 from polygon string]
02/24/09 04:19:38.330392 zmc_m1[10079].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
02/24/09 04:19:38.330469 zmc_m1[10079].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0, OF: 0]
02/24/09 04:19:38.333004 zmc_m1[10079].DB1-zm_monitor.cpp/2457 [Loaded monitor 1(New), 1 zones]
02/24/09 04:19:38.333098 zmc_m1[10079].INF-zmc.cpp/186 [Starting Capture]
02/24/09 04:19:38.390300 zmc_m1[10079].DB2-zm_remote_camera_rtsp.cpp/112 [Waiting for sources]
02/24/09 04:19:38.519947 zmc_m1[10081].DB2-zm_rtsp.cpp/137 [Assigned RTP port range is 40200-40499]
02/24/09 04:19:38.520199 zmc_m1[10081].DB2-zm_rtsp.cpp/44 [Sending RTSP message: SETUP rtsp://172.16.0.3:70701 RTSP/1.0
Transport: RTP/AVP;unicast;client_port=40200-40201
CSeq: 1
02/24/09 04:19:38.522547 zmc_m1[10081].DB2-zm_rtsp.cpp/70 [Received RTSP response: RTSP/1.0 404 Stream Not found
CSeq: 1
(42 bytes)]
02/24/09 04:19:38.522747 zmc_m1[10081].ERR-zm_rtsp.cpp/90 [Unexpected response code 404, text is 'Stream Not found']
02/24/09 04:19:38.522917 zmc_m1[10081].DB2-zm_thread.cpp/263 [Exiting thread, status 0xffffffff]
02/24/09 04:19:48.460649 zmc_m1[10079].FAT-zm_remote_camera_rtsp.cpp/118 [No RTSP sources]
02/24/09 04:19:48.461876 zmc_m1[10079].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
02/24/09 04:19:48.462127 zmc_m1[10079].ERR-zm_signal.cpp/84 [Signal address is (nil), from 0x5d2402]
02/24/09 04:19:48.462746 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: [0x5d2402]]
02/24/09 04:19:48.462854 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: [0x5d2402]]
02/24/09 04:19:48.462960 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(gsignal+0x50) [0x9c5d10]]
02/24/09 04:19:48.463058 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(abort+0x101) [0x9c7621]]
02/24/09 04:19:48.463159 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x8055709]]
02/24/09 04:19:48.463253 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x807d2a9]]
02/24/09 04:19:48.463653 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804c54d]]
02/24/09 04:19:48.463756 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x9b2dec]]
02/24/09 04:19:48.463859 zmc_m1[10079].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc(__gxx_personality_v0+0x381) [0x804c011]]
02/24/09 04:19:48.463963 zmc_m1[10079].INF-zm_signal.cpp/125 [Backtrace complete, please execute the following command for more information]
02/24/09 04:19:48.511417 zmc_m1[10079].INF-zm_signal.cpp/126 [addr2line -e /usr/local/bin/zmc(__gxx_personality_v0+0x381) 0x5d2402 0x5d2402 0x9c5d10 0x9c7621 0x8055709 0x807d2a9 0x804c54d 0x9b2dec 0x804c011]
I can see good images with vlc media player.
I tried with alternate method ffmpeg but i just see a distorted and bad picture image
Im running centos 5.2
Please help me...
dasa
CSeq: 1
CSeq: 1
(42 bytes)]
Please help me...
dasa
