Hardware requirements for 12 analog cams
Posted: Fri Feb 27, 2009 2:57 pm
My customer wants a system with 12 analog cams.
I proposed a system with a 500 GB HD, 2GB RAM DDR2 800MHz
Based on the spreadsheet from the ZM Wiki I calculate 500 GB will be enough for a 12 cam system with 12 up to 15fps each at resolution 320X240
the boards I plan to use are http://store.bluecherry.net/Provideo_PV ... pv-149.htm
and
http://store.bluecherry.net/Provideo_PV ... _8port.htm
Maybe I could use a similar model with audio support but is not mandatory.
I won't use motion detection.
Does anyone have any idea about hardware requirements for a system like this ?
and
