Panasonic BL-C1 Setup Help, Please
Posted: Mon Mar 02, 2009 7:41 pm
I'm trying to set up a Panasonic BL-C1 to record motion detection. So far I am having limited success. My setup uses openSUSE 11.1 and a ZoneMinder 1.24.1 rpm from one of the listed repositories.
My basic settings are as follows:
So far, so good. The streaming is perfect, and the camera doesn't record anything until it does, indeed, sense some motion (usually me, waving frantically!). The problem is, once it has started recording, it never stops. The camera goes into alarm state and never leaves.
Now, I don't know whether this is a problem with zoneminder, or a problem with my setup, though I suspect it to be the latter. I've trawled through the documentation and have found very little about actually configuring my camera. For example, it says in the docs to limit the frame rate on the camera for an ip cam, yet I cannot find a way to do this on the BL-C1's config pages, nor do I know if this is necessary. I don't know whether I should be setting up the motion detection on the camera, or whether that is just for use with the camera's internal program and zma will be doing the hard work, so long as the machine is receiving the images. I would be very grateful for some pointers - I feel I am so close, but I can't get any closer!
Thanks.
host: username:password@ip_address
remote host path: /nphMotionJpeg?Resolution=320x240&Quality=Standard
Thanks.
