USB cameras that are still available to buy that work
Posted: Tue Mar 03, 2009 3:35 pm
Hi there
From reading here:
http://www.zoneminder.com/wiki/index.ph ... d_hardware
It seems that lots of the USB cameras that are natively supported by Linux and thus by ZM are old and can no longer be purchased.
This is not always the case, by chance, I bought a WebCam for use with a Asus WL-500G (a router that has 2 USB ports) and the WebCam works with ZM. It is a Trust Mini Webcam WB-1200p. However, the resolution is lousy and only good for monitoring a room.
I was wondering if anyone has any experience with recently available Webcams, that you can still buy online and that will defo work with ZM??
I have three Webcams currently, a wierd Chinese webcam that I bought in China. I had it working with ZM 1.23 on Debian, but I just can't get it to work on ZM 1.24.1 on Ubuntu. zmu sees the camera, but which ever option I choose in console, the LED light for the camera comes on briefly, then it dies and I see this in syslog:
Mar 3 15:28:11 server zmc_dvideo2[21690]: INF [Debug Level = 0, Debug Log = <none>]
Mar 3 15:28:11 server zmc_dvideo2[21690]: INF [Starting Capture]
Mar 3 15:28:12 server zmc_dvideo2[21690]: ERR [Failed to set picture attributes: Invalid argument]
Mar 3 15:28:12 server zmdc[18743]: ERR ['zmc -d /dev/video2' exited abnormally, exit status 255]
I also have a Microsoft Lifecam that uses the uvc drivers, but zmu doesn't even see the camera and I get the same message in syslog:
Mar 3 15:33:01 server zmdc[18743]: INF [Starting pending process, zmc -d /dev/video1]
Mar 3 15:33:01 server zmdc[22358]: INF ['zmc -d /dev/video1' started at 09/03/03 15:33:01]
Mar 3 15:33:01 server zmdc[18743]: INF ['zmc -d /dev/video1' starting at 09/03/03 15:33:01, pid = 22358]
Mar 3 15:33:01 server zmc_dvideo1[22358]: INF [Debug Level = 0, Debug Log = <none>]
Mar 3 15:33:01 server zmc_dvideo1[22358]: INF [Starting Capture]
Mar 3 15:33:01 server zmc_dvideo1[22358]: ERR [Failed to set picture attributes: Invalid argument]
Mar 3 15:33:01 server zmdc[18743]: ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
Obviously I have the wrong settings for both, but I have tried all the combinations I can think of, and none work.
So, I was just wondering if some people could recommend some USB cameras that you can buy today, that are cheap and that will work with ZM?
Or is USB not the way to go since I see most people talking about capture cards?? But that seems a way more expensive way to me
From reading here:
