Hi all,
During the ./configure stage, I received the following warning:
configure: WARNING: ffmpeg/avformat.h: present but cannot be compiled
...check for missing prerequisite headers?
...see the Autoconf documentation
...section "Present But Cannot Be Compiled"
...proceeding with the preprocessor's result
...in the future, the compiler will take precedence
## Report this to support@zoneminder.com ##
checking for ffmpeg/avformat.h... yes
<snip>
This is Redhat EL5.3, ZM 1.24.1, and the following installed ffmpeg:
ffmpeg-0.4.9-0.9.20070530.el5.rf
ffmpeg-devel-0.4.9-0.9.20070530.el5.rf
ffmpeg-libpostproc-0.4.9-0.9.20070530.el5.rf
The make install shows a more specific error:
/usr/include/ffmpeg/avformat.h: In function ‘void av_init_packet(AVPacket*)’:
/usr/include/ffmpeg/avformat.h:62: error: ‘INT64_C’ was not declared in this scope
Any pointers on how to make this work, and, what might be the results if I continued to install ZM with this warning?
I could not find anything too closely related in the forums.
Thanks in advance,
Joel
Warning: ffmpeg/avformat.h present but cannot be compiled
ffmpeg -version
FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --enable-swscale --enable-gpl
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 0 / 52.20. 0
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libswscale 0. 7. 1 / 0. 7. 1
I think SVN is firewalled here, so I had to download the 0.5 source-code.
Heres my current one:
Weird that it printed the same stuff twice...I hate how flakey ffmpeg is, as far as every build is different from the last, which usually breaks stuff. I guess should stay away from the svn trunk builds. I am about to try an older build and see if it solves my problems.
# ffmpeg -version
FFmpeg version SVN-r17812, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-shared
built on Mar 4 2009 15:00:04, gcc: 4.3.2 20081105 (Red Hat 4.3.2-7)
FFmpeg SVN-r17812
