Invalid Jpeg Structure...failed to capture
I'm testing a new 1.24.1 install against an existing 1.23.x install. On the new one, I am receiving the following messages (only one test IP cam installed)
zmc_m1[7908]: ERR [Invalid JPEG file structure: two SOI markers]
zmc_m1[7908]: ERR [Unable to decode jpeg]
zmc_m1[7908]: ERR [Failed to capture image from monitor 1 (0/1)]
zmdc[5323]: ERR ['zmc -m 1' exited abnormally, exit status 255]
I also get the following:
Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
[Unable to store frame as shared memory invalid]
For shared memor, what is the most recent calculation? Although I didn't think it would be an issue for only one test cam.
On the 1.23.xinstallation, the messages do not happen, even with the same IP cam.
Using RHEL5.3
Just installed ffmpeg from the ffmpeg site
Any suggestions on where to look to resolve this? It seems to be capturing with motion-detect, but I'm not sure if the results are complete.
Thanks in advance.
Joel
Using RHEL5.3
Thanks in advance.
Joel
Welcome to my world. I get this same issue on CentOS 5.2/5.3, and Fedora Core 10 (see my post http://www.zoneminder.com/forums/viewtopic.php?t=13252). It acts like a libjpeg issue, but Zoneminder 1.23.x (even 1.22.x) works fine on the same machines. I have yet to figure it out
I also noted that the jpeg errors were frequent but random, and everytimg zmc crashes, zm restarts it, so it will work for a bit, and capture several frames, then zmc gets the jpeg error, crashes, repeat.
I switched to ffmpeg ver 0.5 instead of using an svn build. It did not have any effect on the jpeg decode errors, (in case wondering, yes I recompiled/reinstalled zm afterwards) so again this acts like a libjpeg problem, yet ZM 1.23.3 and even an rpm version of 1.22.3 work fine on the same server. So strange!
By the way, for the 1.23.3 "make install", it can't find ffmpeg/avformat.h and swscale.h, although they both exist. How do I specify the location? (They are in /usr/local/include/libavformat/avformat.h and /usr/local/include/libswscale/libswscale.h
I had a tough enough time making the 1.24.1 compile and I just can't find the option....
Thanks again
Thanks again
Add "--with-ffmpeg=/usr/local" to your ./configure statement
Also, if you installed ffmpeg to /usr/local/bin, do not forget to add /usr/local/lib to your ld config. To do so I created a file called "ffmpeg.conf" in /etc/ld.so.conf.d, which contains a single line that says "/usr/local/lib", after which you run the "ldconfig" command. This enables the installed zm binaries that are in /usr/local/bin to find the ffmpeg libs that are in /usr/local/lib.
Unable to decode JPEG
And the problem with JPEG?
Did anyone resolve it?
Jpeg problem
I also have the corrupt jpeg problem with 1.24 and from what I can tell it seems to be related to ip cameras, in my case Dlink 5300. I have another remote monitor to a local camera from another computer and don't see the issue. I did not have the jpeg problem in 1.23.
Regular Expressions
Cordel, Thanks for the suggestion!
So far regular expressions seems to have solved my problem with two SOI headers and my ip cam.
