Page 1 of 1
mjpeg from ZM to touchscreen
Posted: Wed Mar 11, 2009 7:17 pm
by johndpar
I have a touchscreen (AMX) that can display mjpeg video if I can give it a URL.
Is this possible with ZM?
I'm a newbie and before I invest too much time in ZM I'm just checking oiut some of its capabilities. I've trawled this forum and the wiki but not found any clues yet.
Many thanks
John
Posted: Wed Mar 11, 2009 10:38 pm
by allanE
It should be possible. ZM is simply feeding jpegs to an apache server. something like
www"your server"/cgi-zm/zms?mode=single&monitor=2&scale=100&maxfps=5
this would give you 5fps at full scale for the second monitor in the list.
The actual code would vary slightly based on how your system is set up but that works on mine.
Allan
Posted: Wed Mar 11, 2009 10:58 pm
by johndpar
Thanks Allan - I'll go ahead and give it a try.
Regards
John
Posted: Thu Mar 12, 2009 1:47 am
by Blazer
This should work:
http://YourServer/zm/index.php?view=wat ... &scale=100
Note that mid=2, the 2 would be replaced with the id of the monitor you wish to watch.
