My export fails on certain monitors. I've tracked it down to missing softlinks on the 'events' directory. This is an install from RPM of 1.22.3 on fc8. It's an odd problem where the softlinks in the events directory keep disappearing. In events there are directories corresponding to monitor id. The softlinks are named after the monitor name and are necessary for the weblinks that are used when exporting. In my case, the softlinks are created immediately after monitors are added but disappear shortly after. Only the softlnks for the first and last monitior remain. I've tried deleting and adding all monitors again, always ending up with the first and last monitors having links. If I manually link, my links are deleted almost immediately.
This is weird.....any ideas?
