Unable to play back events - Apache socket_sendto failing
Posted: Sat Mar 14, 2009 1:25 pm
I'm stuck with this one... anyone got any clues?
ZM is showing live streams and recording events fine, and the events appear in the list under the live stream. However, when I click on an event to play it back, I get a window with the video controls at the bottom, event details at the top, but no video in the middle.
The video playback component just shows the event name and a little icon top left of its frame. Status line is stuck on "Transferring data from localhost" - presumably trying to connect to the stream? The URL it's trying to pull from, according to the properties, is:
http://localhost/cgi-bin/nph-zms?source ... 1237036260
Firebug is showing an error, "streamStatus is undefined -
http://localhost/zm/skins/classic/views/js/event.js , Line 46".
Apache's error_log has this kind of thing each time:
[Sat Mar 14 13:14:19 2009] [error] [client ::1] socket_sendto( /var/run/zm/zms-656990s.sock ) failed: No such file or directory, referer: http://localhost/zm/index.php?view=even ... 1=1&page=1
[Sat Mar 14 13:14:19 2009] [error] [client ::1] array (\n 0 => \n array (\n 'file' => '/srv/www/htdocs/zm/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /var/run/zm/zms-656990s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/srv/www/htdocs/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/srv/www/htdocs/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/zm/index.php?view=even ... 1=1&page=1
[Sat Mar 14 13:15:35 2009] [warn] [client ::1] Timeout waiting for output from CGI script /srv/www/cgi-bin/nph-zms, referer: http://localhost/zm/index.php?view=watch&mid=2
I've tried un-checking the "use Cambozola" option in config - makes no difference. Also tried this on IE7 browser as well as FF3, similar result at the browser and same Apache errors.
It looks like nph-zms is failing to open a socket. ZM and Apache both run as wwwrun/www and the perms on /var/run/zm would allow that user to write. There are usually a couple of zm files in there, including zm.pid and zmdc.sock, but whenever this happens, the socket mentioned in the Apache error log is not present in /var/run/zm.
What creates these sockets and tells nph-zms the socket path? Is there something I can do to track down why they're not being created?
Any suggestions welcome...
Thanks,
Jeff
Thanks,
Jeff
