I've been trying to install from source on an ARM9 machine.
As far as I can tell, nobody before tried it.
Anyway, I have an Elro c800ip network camera, and it's compatible with D-Link 900 camera, so I guess it should work with ZoneMinder.
I chose to install ZoneMinder on my cracked Western Digital MyBook World Edition, which is a network storage device that runs on Linux and has a gumstix1151 motherboard with ARM9 CPU at 400MHz.
Anyway, after days of installing prerequisites for ZM on the machine (it takes 18 hours to compile mysql
[root@MyBookWorld zoneminder]# make
make all-recursive
make[1]: Entering directory `/shares/internal/stanke/zoneminder'
Making all in src
make[2]: Entering directory `/shares/internal/stanke/zoneminder/src'
make[3]: Entering directory `/shares/internal/stanke/zoneminder'
make[3]: Leaving directory `/shares/internal/stanke/zoneminder'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/lib/include -I/opt/lib/include -Wall -Wno-sign-compare -fno-inline -I/opt/lib/include -frepo -g -O2 -c -o zmc.o zmc.cpp
In file included from zmc.cpp:27:
zm_signal.h:24:22: execinfo.h: No such file or directory
In file included from zm_monitor.h:27,
from zmc.cpp:28:
zm_image.h:29:18: zlib.h: No such file or directory
In file included from zm_jpeg.h:22,
from zm_image.h:34,
from zmc.cpp:28:
jinclude.h:20:55: jconfig.h: No such file or directory
In file included from zm_image.h:34,
from zmc.cpp:28:
zm_jpeg.h:23:21: jpeglib.h: No such file or directory
zm_jpeg.h:24:20: jerror.h: No such file or directory
from zmc.cpp:28:
zm_jpeg.h:29: error: field `pub' has incomplete type
zm_jpeg.h:35: error: variable or field `zm_jpeg_error_exit' declared void
zm_jpeg.h:35: error: `j_common_ptr' was not declared in this scope
zm_jpeg.h:36: error: variable or field `zm_jpeg_emit_message' declared void
zm_jpeg.h:36: error: `j_common_ptr' was not declared in this scope
zm_jpeg.h:36: error: expected primary-expression before "int"
zm_jpeg.h:36: error: initializer expression list treated as compound expression
zm_jpeg.h:39: error: variable or field `jpeg_mem_src' declared void
zm_jpeg.h:39: error: `j_decompress_ptr' was not declared in this scope
zm_jpeg.h:39: error: expected primary-expression before "const"
zm_jpeg.h:39: error: expected primary-expression before "int"
zm_jpeg.h:39: error: initializer expression list treated as compound expression
zm_jpeg.h:40: error: variable or field `jpeg_mem_dest' declared void
zm_jpeg.h:40: error: `j_compress_ptr' was not declared in this scope
zm_jpeg.h:40: error: `JOCTET' was not declared in this scope
zm_jpeg.h:40: error: `outbuffer' was not declared in this scope
zm_jpeg.h:40: error: expected primary-expression before "int"
zm_jpeg.h:40: error: initializer expression list treated as compound expression
from zmc.cpp:28:
zm_image.h:82: error: ISO C++ forbids declaration of `jpeg_compress_struct' with no type
zm_image.h:82: error: expected `;' before '*' token
zm_image.h:83: error: ISO C++ forbids declaration of `jpeg_decompress_struct' with no type
zm_image.h:83: error: expected `;' before '*' token
zm_image.h:93: error: ISO C++ forbids declaration of `JSAMPLE' with no type
zm_image.h:93: error: expected `;' before '*' token
zm_image.h:107: error: `JSAMPLE' has not been declared
zm_image.h:107: error: ISO C++ forbids declaration of `p_buffer' with no type
zm_image.h:116: error: ISO C++ forbids declaration of `JSAMPLE' with no type
zm_image.h:116: error: `JSAMPLE' declared as an `inline' field
zm_image.h:116: error: expected `;' before '*' token
zm_image.h:117: error: expected `;' before "inline"
zm_image.h:117: error: ISO C++ forbids declaration of `JSAMPLE' with no type
zm_image.h:117: error: `JSAMPLE' declared as an `inline' field
zm_image.h:117: error: expected `;' before '*' token
zm_image.h:119: error: expected `;' before "void"
zm_image.h:142: error: expected `,' or `...' before '*' token
zm_image.h:142: error: ISO C++ forbids declaration of `JOCTET' with no type
zm_image.h:143: error: expected `;' before '(' token
zm_image.h:145: error: expected `,' or `...' before '*' token
zm_image.h:145: error: ISO C++ forbids declaration of `Bytef' with no type
zm_image.h:146: error: expected `;' before '(' token
zm_image.h: In member function `void Image::CopyBuffer(const Image&)':
zm_image.h:129: error: `buffer' undeclared (first use this function)
zm_image.h:129: error: (Each undeclared identifier is reported only once for each function it appears in.)
zm_image.h:129: error: 'const class Image' has no member named 'buffer'
zm_image.h: In member function `Image& Image::operator=(const unsigned char*)':
zm_image.h:133: error: `buffer' undeclared (first use this function)
zm_image.h: In member function `void Image::Clear()':
zm_image.h:167: error: `buffer' undeclared (first use this function)
make[2]: *** [zmc.o] Error 1
make[2]: Leaving directory `/shares/internal/stanke/zoneminder/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/shares/internal/stanke/zoneminder'
make: *** [all] Error 2
Because it took me 3 days just to get the ./configure to run.
thanks,
Milosh
