Events are all garbled only for the first camera ZM 1.24.1
vigrond
Post by vigrond »
When I click on my first camera, the event numbers are all gobbled. Only the ones with actual duration numbers play back, otherwise the video is black.
I run a quadcore 4GB RAM with 64-bit ubuntu server 8.07. All the cameras are the same (Trendnet IP-301s), but only the first one does this. Settings for each camera are identical.
As you can see, the date goes back to 1969 randomly, it was a good year but still. Time resets back to 3:00pm. Time durations are all over the place.
Id Name Time Secs Frames Score
6026 New Event 2009-03-17 09:01:53 0.00 null/null 0/0 X
6021 Event-6021 1969-12-31 16:00:00 0.00 29/1 100/100 X
6020 Event-6020 2009-03-17 09:01:04 8234850.89 21/1 3/3 X
6009 Event-6009 2009-03-17 08:58:39 61.57 168/76 9/22 X
6002 Event-6002 2009-03-17 08:56:04 25.12 107/46 6/16 X
5993 Event-5993 1969-12-31 16:00:00 -8235265.17 61/1 100/100 X
5992 Event-5992 1969-12-31 16:00:00 0.00 23/1 100/100 X
5991 Event-5991 2009-03-17 08:53:44 8235291.46 24/4 3/4 X
5986 Event-5986 1969-12-31 16:00:00 0.00 19/1 100/100 X
5985 Event-5985 2009-03-17 08:51:56 8235399.69 11/1 4/4 X
5969 Event-5969 2009-03-17 08:40:55 603.66 26/6 18/93 X
5945 Event-5945 2009-03-17 08:30:30 603.77 26/5 22/93 X
5943 Event-5943 1969-12-31 16:00:00 -8236720.88 21/1 100/100 X
5927 Event-5927 1969-12-31 16:00:00 0.00 21/1 100/100 X
5926 Event-5926 2009-03-17 08:09:51 8237924.16 13/3 27/65 X
5925 Event-5925 1969-12-31 16:00:00 -8237930.81 21/1 100/100 X
5911 Event-5911 1969-12-31 16:00:00 0.00 21/1 100/100 X
5910 Event-5910 2009-03-17 07:59:40 2.58 19/9 3/4 X
5894 Event-5894 1969-12-31 16:00:00 -8238620.86 21/1 100/100 X
5891 Event-5891 1969-12-31 16:00:00 0.00 20/1 100/100 X
any ideas?
Blazer
Post by Blazer »
That is odd! Did you upgrade your DB from a previous version? Is the local system time and timezone correct? Have you tried deleting that monitor and recreating it?
vigrond
Post by vigrond »
No on the upgrade, did a fresh install of everything. Local system time / zone are correct.
I'm now getting a 'server busy' on the IP cameras page. Going to try to reset the camera tomorrow and see if it fixes it. If not, then I will recreate it and see what happens.
