Page 1 of 1
montage view show the same camera
Posted: Sat Mar 21, 2009 9:44 am
by mmi
i have install zm by:
http://www.zoneminder.com/wiki/index.ph ... ozola-0.7)
everything is ok but on montage view is only one camera
more clear:
i have:
/dev/video0 (1)
/dev/video0 (2)
/dev/video0 (3)
on montage i have /dev/video0 (2) three times
not one with /dev/video0 (1), one /dev/video0 (2) and one /dev/video0 (3)
thanks for help
and error
Posted: Sat Mar 21, 2009 9:54 am
by mmi
also when i delete a camera i got this error
Warning: Cannot modify header information - headers already sent by (output started at /var/www/includes/actions.php:1235) in /var/www/includes/functions.php on line 99
hmm
Posted: Sat Mar 21, 2009 10:02 am
by mmi
now i see the problem
on all /dev/video0 (0) /dev/video0 (1) /dev/video0 (2)
i have the same camera not only in montage,
if i open one by one is the same camera on all
the captura card is pico2000 with settings from wiki
solved
Posted: Sat Mar 21, 2009 12:31 pm
by mmi
solved:
increase ZM_CAPTURES_PER_FRAME to 2 instead of 1
** SOLVED** , agree
Posted: Sat Mar 28, 2009 5:56 am
by henriquejf
Yeah, SOLVED (mmi, you´re a genious !)
to clarify, IMHO, a ** tip to BTTV users under 1.24.1 ** (same sittuations on SVN install under ubuntu 8.10 vanilla and excelent´s rmelin 1.24.1 livecd)
If you own a BTTV or similar card that shares 4 inputs in one chip, for example, and experience multiple monitors unstable or
** MONITORS SHOWING THE SAME IMAGES **
even that channels are correctly configured, you have to change CAPTURES_PER_FRAME under options>config tab accordingly; I set mine to 4 instead of 1 and had my 4 cheap cameras working as they should;
also, I managed to configure them using V4L2, using NTSC-M format, and RGB565 pallete, 320*240; On general tabs, use maximum fps 2 and alarm maximum 2 ;
finally, somebody already noticed (and advised the developers) that the presets for BTTV are missing many gaps and informing incorrect ones; they´ve already noticed that the problem may be seen in the preset table on the database; so I suggest you dont use presets for bttv until 1.24.2;
I cant express how I appreciate this software and its developers; hope to make a donation soon if everything goes fine ! consider U 2 !
Posted: Tue Mar 31, 2009 2:46 am
by tomatongo
I solved it on CentOS unchecking V4L_MULTI_BUFFER, now I have the same behaviour than 1.23.3 . I use V4Lv1
Thanks!!
