Multiple monitors on one card black screen
kevin_robson
Post by kevin_robson »
I have a bttv capture card with single camera. With earlier versions I have always had 2 monitors for the one input, one set high sensitivity so I can check quickly for events and the other at lower sensitivity so it captures all movement but I don't have to check through it all.
On 1.24 it doesn't seem to want to work. If I disable either monitor the other works fine, but if I try to run them both at the same time both give me a black screen. Errors are below. I'm still using bttv version 1 for now as had other hassles with V2. Is this still possible or will I have to go back to 1.23? I tried setting ZM_CAPTURES_PER_FRAME to 2 but no different.
==> zmpkg.log <==
03/25/09 13:00:30.016803 zmpkg[7385].INF [Command: start]
==> zmdc.log <==
03/25/09 13:00:30.413132 zmdc[7397].INF [Server starting at 09/03/25 13:00:30]
tail: zmdc.sock: No such device or address
03/25/09 13:00:33.616229 zmdc[7397].INF ['zmc -d /dev/video0' starting at 09/03/25 13:00:33, pid = 7420]
03/25/09 13:00:33.831352 zmdc[7397].INF ['zma -m 1' starting at 09/03/25 13:00:33, pid = 7424]
03/25/09 13:00:34.029804 zmdc[7397].INF ['zmc -d /dev/video0' already running at 09/03/25 13:00:33, pid = 7420]
03/25/09 13:00:34.179287 zmdc[7397].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/25/09 13:00:34.179694 zmdc[7397].INF [Starting pending process, zmc -d /dev/video0]
03/25/09 13:00:34.184704 zmdc[7397].INF ['zmc -d /dev/video0' starting at 09/03/25 13:00:34, pid = 7430]
03/25/09 13:00:34.255961 zmdc[7397].INF ['zma -m 2' starting at 09/03/25 13:00:34, pid = 7432]
03/25/09 13:00:34.474277 zmdc[7397].INF ['zmfilter.pl' starting at 09/03/25 13:00:34, pid = 7437]
03/25/09 13:00:34.673118 zmdc[7397].INF ['zmaudit.pl -c' starting at 09/03/25 13:00:34, pid = 7441]
03/25/09 13:00:34.745842 zmdc[7397].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/25/09 13:00:34.893150 zmdc[7397].INF ['zmwatch.pl' starting at 09/03/25 13:00:34, pid = 7446]
03/25/09 13:00:35.160812 zmdc[7397].INF ['zmupdate.pl -c' starting at 09/03/25 13:00:35, pid = 7451]
==> zmfilter.log <==
03/25/09 13:00:34.888350 zmfilter[7437].INF [Scanning for events]
==> zmwatch.log <==
03/25/09 13:00:35.078005 zmwatch[7446].INF [Watchdog starting]
03/25/09 13:00:35.078430 zmwatch[7446].INF [Watchdog pausing for 30 seconds]
==> zmdc.log <==
03/25/09 13:00:39.023934 zmdc[7397].INF [Starting pending process, zmc -d /dev/video0]
03/25/09 13:00:39.025360 zmdc[7397].INF ['zmc -d /dev/video0' starting at 09/03/25 13:00:39, pid = 7464]
03/25/09 13:00:39.577038 zmdc[7397].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
^C
/var/log/messages
==> zmpkg.log <==
==> zmdc.log <==
==> zmwatch.log <==
==> zmdc.log <==
^C
kevin_robson
and if I out capture frames back to 1 I get slightly different output:
03/25/09 13:15:16.473572 zmdc[8434].INF [Server starting at 09/03/25 13:15:16]
==> zmpkg.log <==
03/25/09 13:15:16.078882 zmpkg[8422].INF [Command: start]
==> zmdc.log <==
03/25/09 13:15:19.670418 zmdc[8434].INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:19, pid = 8458]
03/25/09 13:15:19.882460 zmdc[8434].INF ['zma -m 1' starting at 09/03/25 13:15:19, pid = 8462]
03/25/09 13:15:20.074012 zmdc[8434].INF ['zmc -d /dev/video0' already running at 09/03/25 13:15:19, pid = 8458]
03/25/09 13:15:20.198933 zmdc[8434].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/25/09 13:15:20.199362 zmdc[8434].INF [Starting pending process, zmc -d /dev/video0]
03/25/09 13:15:20.204489 zmdc[8434].INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:20, pid = 8468]
03/25/09 13:15:20.297618 zmdc[8434].INF ['zma -m 2' starting at 09/03/25 13:15:20, pid = 8470]
03/25/09 13:15:20.494392 zmdc[8434].INF ['zmfilter.pl' starting at 09/03/25 13:15:20, pid = 8474]
03/25/09 13:15:20.699822 zmdc[8434].INF ['zmaudit.pl -c' starting at 09/03/25 13:15:20, pid = 8478]
03/25/09 13:15:20.725334 zmdc[8434].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/25/09 13:15:20.957916 zmdc[8434].INF ['zmwatch.pl' starting at 09/03/25 13:15:20, pid = 8482]
03/25/09 13:15:21.182120 zmdc[8434].INF ['zmupdate.pl -c' starting at 09/03/25 13:15:21, pid = 8488]
03/25/09 13:15:20.958869 zmfilter[8474].INF [Scanning for events]
==> zmwatch.log <==
03/25/09 13:15:21.176401 zmwatch[8482].INF [Watchdog starting]
03/25/09 13:15:21.176905 zmwatch[8482].INF [Watchdog pausing for 30 seconds]
==> zmdc.log <==
03/25/09 13:15:25.094758 zmdc[8434].INF [Starting pending process, zmc -d /dev/video0]
03/25/09 13:15:25.102292 zmdc[8434].INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:25, pid = 8500]
03/25/09 13:15:25.635753 zmdc[8434].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/25/09 13:15:35.035782 zmdc[8434].INF [Starting pending process, zmc -d /dev/video0]
03/25/09 13:15:35.037348 zmdc[8434].INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:35, pid = 8504]
03/25/09 13:15:35.558301 zmdc[8434].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
^C
Mar 25 13:15:16 wobble zmpkg[8422]: INF [Command: start]
Mar 25 13:15:16 wobble zmdc[8434]: INF [Server starting at 09/03/25 13:15:16]
Mar 25 13:15:19 wobble zmdc[8434]: INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:19, pid = 8458]
Mar 25 13:15:19 wobble zmdc[8458]: INF ['zmc -d /dev/video0' started at 09/03/25 13:15:19]
Mar 25 13:15:19 wobble zmc_dvideo0[8458]: INF [Debug Level = 0, Debug Log = <none>]
Mar 25 13:15:19 wobble zmc_dvideo0[8458]: INF [Starting Capture]
Mar 25 13:15:19 wobble zmc_dvideo0[8458]: ERR [Capture failure for frame 1: Invalid argument]
Mar 25 13:15:19 wobble zmc_dvideo0[8458]: ERR [Failed to post-capture monitor 1]
Mar 25 13:15:19 wobble zmdc[8434]: INF ['zma -m 1' starting at 09/03/25 13:15:19, pid = 8462]
Mar 25 13:15:19 wobble zmdc[8462]: INF ['zma -m 1' started at 09/03/25 13:15:19]
Mar 25 13:15:19 wobble zma_m1[8462]: INF [Debug Level = 0, Debug Log = <none>]
Mar 25 13:15:19 wobble zma_m1[8462]: INF [In mode 3/1, warming up]
Mar 25 13:15:20 wobble zmdc[8434]: INF ['zmc -d /dev/video0' already running at 09/03/25 13:15:19, pid = 8458]
Mar 25 13:15:20 wobble zmdc[8434]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Mar 25 13:15:20 wobble zmdc[8434]: INF [Starting pending process, zmc -d /dev/video0]
Mar 25 13:15:20 wobble zmdc[8468]: INF ['zmc -d /dev/video0' started at 09/03/25 13:15:20]
Mar 25 13:15:20 wobble zmdc[8434]: INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:20, pid = 8468]
Mar 25 13:15:20 wobble zmc_dvideo0[8468]: INF [Debug Level = 0, Debug Log = <none>]
Mar 25 13:15:20 wobble zmc_dvideo0[8468]: INF [Starting Capture]
Mar 25 13:15:20 wobble zmdc[8434]: INF ['zma -m 2' starting at 09/03/25 13:15:20, pid = 8470]
Mar 25 13:15:20 wobble zmdc[8470]: INF ['zma -m 2' started at 09/03/25 13:15:20]
Mar 25 13:15:20 wobble zma_m2[8470]: INF [Debug Level = 0, Debug Log = <none>]
Mar 25 13:15:20 wobble zma_m2[8470]: WAR [Waiting for capture daemon]
Mar 25 13:15:20 wobble zmc_dvideo0[8468]: ERR [Capture failure for frame 1: Invalid argument]
Mar 25 13:15:20 wobble zmc_dvideo0[8468]: ERR [Failed to post-capture monitor 1]
Mar 25 13:15:20 wobble zmdc[8434]: INF ['zmfilter.pl' starting at 09/03/25 13:15:20, pid = 8474]
Mar 25 13:15:20 wobble zmdc[8474]: INF ['zmfilter.pl' started at 09/03/25 13:15:20]
Mar 25 13:15:20 wobble zmdc[8478]: INF ['zmaudit.pl -c' started at 09/03/25 13:15:20]
Mar 25 13:15:20 wobble zmdc[8434]: INF ['zmaudit.pl -c' starting at 09/03/25 13:15:20, pid = 8478]
Mar 25 13:15:20 wobble zmdc[8482]: INF ['zmwatch.pl' started at 09/03/25 13:15:20]
Mar 25 13:15:20 wobble zmdc[8434]: INF ['zmwatch.pl' starting at 09/03/25 13:15:20, pid = 8482]
Mar 25 13:15:20 wobble zmfilter[8474]: INF [Scanning for events]
Mar 25 13:15:21 wobble zmwatch[8482]: INF [Watchdog starting]
Mar 25 13:15:21 wobble zmwatch[8482]: INF [Watchdog pausing for 30 seconds]
Mar 25 13:15:21 wobble zmdc[8434]: INF ['zmupdate.pl -c' starting at 09/03/25 13:15:21, pid = 8488]
Mar 25 13:15:21 wobble zmdc[8488]: INF ['zmupdate.pl -c' started at 09/03/25 13:15:21]
Mar 25 13:15:21 wobble zma_m2[8470]: INF [In mode 3/1, warming up]
Mar 25 13:15:25 wobble zmdc[8434]: INF [Starting pending process, zmc -d /dev/video0]
Mar 25 13:15:25 wobble zmdc[8500]: INF ['zmc -d /dev/video0' started at 09/03/25 13:15:25]
Mar 25 13:15:25 wobble zmdc[8434]: INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:25, pid = 8500]
Mar 25 13:15:25 wobble zmc_dvideo0[8500]: INF [Debug Level = 0, Debug Log = <none>]
Mar 25 13:15:25 wobble zmc_dvideo0[8500]: INF [Starting Capture]
Mar 25 13:15:25 wobble zmc_dvideo0[8500]: ERR [Capture failure for frame 1: Invalid argument]
Mar 25 13:15:25 wobble zmc_dvideo0[8500]: ERR [Failed to post-capture monitor 1]
Mar 25 13:15:25 wobble zmdc[8434]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Mar 25 13:15:35 wobble zmdc[8434]: INF [Starting pending process, zmc -d /dev/video0]
Mar 25 13:15:35 wobble zmdc[8434]: INF ['zmc -d /dev/video0' starting at 09/03/25 13:15:35, pid = 8504]
Mar 25 13:15:35 wobble zmdc[8504]: INF ['zmc -d /dev/video0' started at 09/03/25 13:15:35]
Mar 25 13:15:35 wobble zmc_dvideo0[8504]: INF [Debug Level = 0, Debug Log = <none>]
Mar 25 13:15:35 wobble zmc_dvideo0[8504]: INF [Starting Capture]
Mar 25 13:15:35 wobble zmc_dvideo0[8504]: ERR [Capture failure for frame 1: Invalid argument]
Mar 25 13:15:35 wobble zmc_dvideo0[8504]: ERR [Failed to post-capture monitor 1]
Mar 25 13:15:35 wobble zmdc[8434]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Mar 25 13:15:36 wobble zms[8506]: INF [Debug Level = 0, Debug Log = <none>]
Mar 25 13:15:36 wobble zms[8506]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Mar 25 13:15:36 wobble zms[8506]: WAR [Unable to store frame as shared memory invalid]
^C
zoneminder
Site Admin
Post by zoneminder »
Can you up the debug on zmc to maybe 5 for now and post the section of it before it exits?
Phil
kevin_robson
OK. This is from starting up clean and then clicking on one of the monitors.
I tried cutting out bits which I didn't think were important, but decided to try to paste it all instead. Lets see if the forum allows 400 odd lines ;)
cat all_debug.log
03/30/09 12:47:45.728927 zmfix[3753].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03753]
03/30/09 12:47:45.729453 zmfix[3753].DB1-zmfix.cpp/67 [Permissions on /dev/video0 are ok at 20666]
03/30/09 12:47:49.147725 zmc_dvideo0[3780].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03780]
03/30/09 12:47:49.148554 zmc_dvideo0[3780].DB1-zm_monitor.cpp/1708 [Got 2 monitors]
03/30/09 12:47:49.148657 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/103 [Opening video device /dev/video0]
03/30/09 12:47:49.148694 zmc_dvideo0[3780].DB2-zm_local_camera.cpp/109 [V4L2 support enabled, using V4L1 api]
03/30/09 12:47:49.148709 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/432 [Configuring picture attributes]
03/30/09 12:47:49.148729 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/439 [Old P:4]
03/30/09 12:47:49.148738 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/440 [Old D:24]
03/30/09 12:47:49.148746 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/441 [Old B:32768]
03/30/09 12:47:49.148755 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/442 [Old h:32768]
03/30/09 12:47:49.148763 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/443 [Old Cl:32768]
03/30/09 12:47:49.148771 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/444 [Old Cn:32768]
03/30/09 12:47:49.148790 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/481 [Configuring window attributes]
03/30/09 12:47:49.148800 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/490 [Old X:0]
03/30/09 12:47:49.148809 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/491 [Old Y:0]
03/30/09 12:47:49.148817 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/492 [Old W:320]
03/30/09 12:47:49.148825 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/493 [Old H:240]
03/30/09 12:47:49.148837 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/508 [Setting up request buffers]
03/30/09 12:47:49.148852 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/514 [vmb.frames = 8]
03/30/09 12:47:49.148860 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/515 [vmb.size = 17039360]
03/30/09 12:47:49.148868 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/517 [Setting up 8 frame buffers]
03/30/09 12:47:49.148896 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/539 [Configuring video source]
03/30/09 12:47:49.148913 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/547 [Old C:0]
03/30/09 12:47:49.148921 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/548 [Old F:0]
03/30/09 12:47:49.148929 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/549 [Old Fl:0]
03/30/09 12:47:49.148937 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/550 [Old T:2]
03/30/09 12:47:49.148963 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/565 [New X:0]
03/30/09 12:47:49.148972 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/566 [New Y:0]
03/30/09 12:47:49.148980 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/567 [New W:320]
03/30/09 12:47:49.148988 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/568 [New H:240]
03/30/09 12:47:49.148998 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/573 [New P:4]
03/30/09 12:47:49.149007 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/574 [New D:24]
03/30/09 12:47:49.149015 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/575 [New B:32768]
03/30/09 12:47:49.149023 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/576 [New h:32768]
03/30/09 12:47:49.149031 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/577 [New Cl:32768]
03/30/09 12:47:49.149040 zmc_dvideo0[3780].DB4-zm_local_camera.cpp/578 [New Cn:32768]
03/30/09 12:47:49.149048 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/581 [Setting up static colour tables]
03/30/09 12:47:49.149799 zmc_dvideo0[3780].DB1-zm_monitor.cpp/339 [monitor purpose=1]
03/30/09 12:47:49.149831 zmc_dvideo0[3780].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:49.170353 zmc_dvideo0[3780].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.172784 zmc_dvideo0[3780].DB1-zm_monitor.cpp/460 [Monitor Drive has function 3]
03/30/09 12:47:49.172811 zmc_dvideo0[3780].DB1-zm_monitor.cpp/461 [Monitor Drive LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:49.172821 zmc_dvideo0[3780].DB1-zm_monitor.cpp/462 [Monitor Drive IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:49.173447 zmc_dvideo0[3780].DB1-zm_zone.cpp/889 [Got 4 zones for monitor Drive]
03/30/09 12:47:49.173477 zmc_dvideo0[3780].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:49.173540 zmc_dvideo0[3780].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:49.173553 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:49.173562 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.173571 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:49.173579 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:49.173592 zmc_dvideo0[3780].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.173604 zmc_dvideo0[3780].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:55296, FB:3x5, MnFP:3317, MxFP:55296, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.175967 zmc_dvideo0[3780].DB5-zm_zone.cpp/918 [Parsing polygon 222,14 380,35 380,76 222,59]
03/30/09 12:47:49.175992 zmc_dvideo0[3780].DB3-zm_zone.cpp/758 [Parsing polygon string '222,14 380,35 380,76 222,59']
03/30/09 12:47:49.176002 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 222,14 from polygon string]
03/30/09 12:47:49.176011 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 380,35 from polygon string]
03/30/09 12:47:49.176020 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 380,76 from polygon string]
03/30/09 12:47:49.176028 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:49.176039 zmc_dvideo0[3780].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.176050 zmc_dvideo0[3780].DB1-zm_zone.cpp/50 [Initialised zone 4/Hedge1 - 1 - 159x63 - Rgb:ff0000, CM:3, MnAT:40, MxAT:0, MnAP:267, MxAP:3349, FB:5x5, MnFP:267, MxFP:3349, MnBS:267, MxBS:3349, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.176389 zmc_dvideo0[3780].DB5-zm_zone.cpp/918 [Parsing polygon 25,0 222,0 222,59 25,65]
03/30/09 12:47:49.176405 zmc_dvideo0[3780].DB3-zm_zone.cpp/758 [Parsing polygon string '25,0 222,0 222,59 25,65']
03/30/09 12:47:49.176414 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 25,0 from polygon string]
03/30/09 12:47:49.176423 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:49.176431 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:49.176440 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 25,65 from polygon string]
03/30/09 12:47:49.176449 zmc_dvideo0[3780].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.176458 zmc_dvideo0[3780].DB1-zm_zone.cpp/50 [Initialised zone 3/Road1 - 5 - 198x66 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.176863 zmc_dvideo0[3780].DB5-zm_zone.cpp/918 [Parsing polygon 222,0 383,0 380,32 222,13]
03/30/09 12:47:49.176878 zmc_dvideo0[3780].DB3-zm_zone.cpp/758 [Parsing polygon string '222,0 383,0 380,32 222,13']
03/30/09 12:47:49.176887 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:49.176896 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.176904 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 380,32 from polygon string]
03/30/09 12:47:49.176912 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 222,13 from polygon string]
03/30/09 12:47:49.176922 zmc_dvideo0[3780].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.176931 zmc_dvideo0[3780].DB1-zm_zone.cpp/50 [Initialised zone 5/Hedge2 - 5 - 162x33 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.177118 zmc_dvideo0[3780].DB1-zm_monitor.cpp/1810 [Loaded monitor 1(Drive), 4 zones]
03/30/09 12:47:49.177876 zmc_dvideo0[3780].DB1-zm_monitor.cpp/339 [monitor purpose=1]
03/30/09 12:47:49.177905 zmc_dvideo0[3780].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:49.197654 zmc_dvideo0[3780].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.200017 zmc_dvideo0[3780].DB1-zm_monitor.cpp/460 [Monitor AllEvents has function 3]
03/30/09 12:47:49.200039 zmc_dvideo0[3780].DB1-zm_monitor.cpp/461 [Monitor AllEvents LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:49.200048 zmc_dvideo0[3780].DB1-zm_monitor.cpp/462 [Monitor AllEvents IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:49.200557 zmc_dvideo0[3780].DB1-zm_zone.cpp/889 [Got 1 zones for monitor AllEvents]
03/30/09 12:47:49.200580 zmc_dvideo0[3780].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:49.200589 zmc_dvideo0[3780].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:49.200598 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:49.200607 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.200615 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:49.200624 zmc_dvideo0[3780].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:49.200635 zmc_dvideo0[3780].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.200645 zmc_dvideo0[3780].DB1-zm_zone.cpp/50 [Initialised zone 2/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:82944, FB:3x3, MnFP:3317, MxFP:82944, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.202914 zmc_dvideo0[3780].DB1-zm_monitor.cpp/1810 [Loaded monitor 2(AllEvents), 1 zones]
03/30/09 12:47:49.202936 zmc_dvideo0[3780].INF-zmc.cpp/186 [Starting Capture]
03/30/09 12:47:49.203168 zmc_dvideo0[3780].DB2-zm_local_camera.cpp/1065 [Priming capture]
03/30/09 12:47:49.203201 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 0]
03/30/09 12:47:49.205062 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 1]
03/30/09 12:47:49.207252 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 2]
03/30/09 12:47:49.209520 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 3]
03/30/09 12:47:49.211691 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 4]
03/30/09 12:47:49.213869 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 5]
03/30/09 12:47:49.216008 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 6]
03/30/09 12:47:49.218240 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1102 [Queuing frame 7]
03/30/09 12:47:49.220382 zmc_dvideo0[3780].DB2-zm_local_camera.cpp/1117 [Pre-capturing]
03/30/09 12:47:49.220432 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1185 [Capturing]
03/30/09 12:47:49.220440 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1242 [Capturing 1 frames]
03/30/09 12:47:49.220448 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1245 [Syncing frame 0]
03/30/09 12:47:49.333098 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1265 [Captured 0 for channel 0]
03/30/09 12:47:49.333136 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1270 [Doing format conversion]
03/30/09 12:47:49.333863 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1575 [Assigning image]
03/30/09 12:47:49.334464 zmc_dvideo0[3780].DB2-zm_local_camera.cpp/1583 [Post-capturing]
03/30/09 12:47:49.334490 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1603 [Requeueing frame 0]
03/30/09 12:47:49.334514 zmc_dvideo0[3780].DB2-zm_local_camera.cpp/1117 [Pre-capturing]
03/30/09 12:47:49.334525 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1185 [Capturing]
03/30/09 12:47:49.334533 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1575 [Assigning image]
03/30/09 12:47:49.335079 zmc_dvideo0[3780].DB2-zm_local_camera.cpp/1583 [Post-capturing]
03/30/09 12:47:49.335105 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/1603 [Requeueing frame 1]
03/30/09 12:47:49.335167 zmc_dvideo0[3780].ERR-zm_local_camera.cpp/1606 [Capture failure for frame 1: Invalid argument]
03/30/09 12:47:49.335434 zmc_dvideo0[3780].ERR-zmc.cpp/265 [Failed to post-capture monitor 1]
03/30/09 12:47:49.335563 zmc_dvideo0[3780].DB3-zm_local_camera.cpp/644 [Unmapping video buffers]
03/30/09 12:47:49.347655 zma_m1[3784].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03784]
03/30/09 12:47:49.348409 zma_m1[3784].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
03/30/09 12:47:49.349226 zma_m1[3784].DB1-zm_monitor.cpp/339 [monitor purpose=2]
03/30/09 12:47:49.349260 zma_m1[3784].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:49.349390 zma_m1[3784].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.351836 zma_m1[3784].DB1-zm_monitor.cpp/460 [Monitor Drive has function 3]
03/30/09 12:47:49.351862 zma_m1[3784].DB1-zm_monitor.cpp/461 [Monitor Drive LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:49.351871 zma_m1[3784].DB1-zm_monitor.cpp/462 [Monitor Drive IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:49.352338 zma_m1[3784].DB1-zm_monitor.cpp/1583 [Reloading linked monitors for monitor Drive, '2']
03/30/09 12:47:49.352374 zma_m1[3784].DB3-zm_monitor.cpp/1624 [Found linked monitor id 2]
03/30/09 12:47:49.352383 zma_m1[3784].DB1-zm_monitor.cpp/1646 [Linking to 1 monitors]
03/30/09 12:47:49.352393 zma_m1[3784].DB1-zm_monitor.cpp/1652 [Checking linked monitor 2]
03/30/09 12:47:49.352778 zma_m1[3784].DB1-zm_monitor.cpp/1671 [Linking to monitor 2]
03/30/09 12:47:49.353315 zma_m1[3784].DB1-zm_zone.cpp/889 [Got 4 zones for monitor Drive]
03/30/09 12:47:49.353349 zma_m1[3784].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:49.353363 zma_m1[3784].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:49.353374 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:49.353383 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.353392 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:49.353401 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:49.353414 zma_m1[3784].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.353425 zma_m1[3784].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:55296, FB:3x5, MnFP:3317, MxFP:55296, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.355819 zma_m1[3784].DB5-zm_zone.cpp/918 [Parsing polygon 222,14 380,35 380,76 222,59]
03/30/09 12:47:49.355842 zma_m1[3784].DB3-zm_zone.cpp/758 [Parsing polygon string '222,14 380,35 380,76 222,59']
03/30/09 12:47:49.355852 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 222,14 from polygon string]
03/30/09 12:47:49.355861 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 380,35 from polygon string]
03/30/09 12:47:49.355870 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 380,76 from polygon string]
03/30/09 12:47:49.355878 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:49.355889 zma_m1[3784].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.355900 zma_m1[3784].DB1-zm_zone.cpp/50 [Initialised zone 4/Hedge1 - 1 - 159x63 - Rgb:ff0000, CM:3, MnAT:40, MxAT:0, MnAP:267, MxAP:3349, FB:5x5, MnFP:267, MxFP:3349, MnBS:267, MxBS:3349, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.356248 zma_m1[3784].DB5-zm_zone.cpp/918 [Parsing polygon 25,0 222,0 222,59 25,65]
03/30/09 12:47:49.356264 zma_m1[3784].DB3-zm_zone.cpp/758 [Parsing polygon string '25,0 222,0 222,59 25,65']
03/30/09 12:47:49.356274 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 25,0 from polygon string]
03/30/09 12:47:49.356283 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:49.356291 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:49.356299 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 25,65 from polygon string]
03/30/09 12:47:49.356309 zma_m1[3784].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.356319 zma_m1[3784].DB1-zm_zone.cpp/50 [Initialised zone 3/Road1 - 5 - 198x66 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.356852 zma_m1[3784].DB5-zm_zone.cpp/918 [Parsing polygon 222,0 383,0 380,32 222,13]
03/30/09 12:47:49.356878 zma_m1[3784].DB3-zm_zone.cpp/758 [Parsing polygon string '222,0 383,0 380,32 222,13']
03/30/09 12:47:49.356888 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:49.356897 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.356905 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 380,32 from polygon string]
03/30/09 12:47:49.356914 zma_m1[3784].DB3-zm_zone.cpp/796 [Got coordinate 222,13 from polygon string]
03/30/09 12:47:49.356924 zma_m1[3784].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.356934 zma_m1[3784].DB1-zm_zone.cpp/50 [Initialised zone 5/Hedge2 - 5 - 162x33 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.357111 zma_m1[3784].DB1-zm_monitor.cpp/2457 [Loaded monitor 1(Drive), 4 zones]
03/30/09 12:47:49.357131 zma_m1[3784].INF-zma.cpp/99 [In mode 3/1, warming up]
03/30/09 12:47:49.357348 zma_m1[3784].DB4-zm_monitor.cpp/1052 [RI:40, WI: 0, PF = 0, RM = 40, Step = 1]
03/30/09 12:47:49.914068 zma_m1[3784].DB4-zm_monitor.cpp/1052 [RI:40, WI: 0, PF = 0, RM = 40, Step = 1]
03/30/09 12:47:55.233670 zma_m1[3784].DB4-zm_monitor.cpp/1052 [RI:40, WI: 0, PF = 0, RM = 40, Step = 1]
03/30/09 12:48:01.130621 zma_m1[3784].INF-zm_signal.cpp/43 [Got signal 15 (Terminated), exiting]
03/30/09 12:47:49.697861 zmc_dvideo0[3790].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03790]
03/30/09 12:47:49.698633 zmc_dvideo0[3790].DB1-zm_monitor.cpp/1708 [Got 2 monitors]
03/30/09 12:47:49.698728 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/103 [Opening video device /dev/video0]
03/30/09 12:47:49.698761 zmc_dvideo0[3790].DB2-zm_local_camera.cpp/109 [V4L2 support enabled, using V4L1 api]
03/30/09 12:47:49.698776 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/432 [Configuring picture attributes]
03/30/09 12:47:49.698795 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/439 [Old P:4]
03/30/09 12:47:49.698804 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/440 [Old D:24]
03/30/09 12:47:49.698812 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/441 [Old B:32768]
03/30/09 12:47:49.698820 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/442 [Old h:32768]
03/30/09 12:47:49.698828 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/443 [Old Cl:32768]
03/30/09 12:47:49.698836 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/444 [Old Cn:32768]
03/30/09 12:47:49.698855 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/481 [Configuring window attributes]
03/30/09 12:47:49.698865 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/490 [Old X:0]
03/30/09 12:47:49.698873 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/491 [Old Y:0]
03/30/09 12:47:49.698881 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/492 [Old W:320]
03/30/09 12:47:49.698889 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/493 [Old H:240]
03/30/09 12:47:49.698902 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/508 [Setting up request buffers]
03/30/09 12:47:49.698916 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/514 [vmb.frames = 8]
03/30/09 12:47:49.698924 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/515 [vmb.size = 17039360]
03/30/09 12:47:49.698933 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/517 [Setting up 8 frame buffers]
03/30/09 12:47:49.698960 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/539 [Configuring video source]
03/30/09 12:47:49.698974 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/547 [Old C:0]
03/30/09 12:47:49.698982 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/548 [Old F:0]
03/30/09 12:47:49.698990 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/549 [Old Fl:0]
03/30/09 12:47:49.698998 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/550 [Old T:2]
03/30/09 12:47:49.699022 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/565 [New X:0]
03/30/09 12:47:49.699030 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/566 [New Y:0]
03/30/09 12:47:49.699038 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/567 [New W:320]
03/30/09 12:47:49.699046 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/568 [New H:240]
03/30/09 12:47:49.699056 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/573 [New P:4]
03/30/09 12:47:49.699064 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/574 [New D:24]
03/30/09 12:47:49.699072 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/575 [New B:32768]
03/30/09 12:47:49.699079 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/576 [New h:32768]
03/30/09 12:47:49.699087 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/577 [New Cl:32768]
03/30/09 12:47:49.699095 zmc_dvideo0[3790].DB4-zm_local_camera.cpp/578 [New Cn:32768]
03/30/09 12:47:49.699103 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/581 [Setting up static colour tables]
03/30/09 12:47:49.699826 zmc_dvideo0[3790].DB1-zm_monitor.cpp/339 [monitor purpose=1]
03/30/09 12:47:49.699858 zmc_dvideo0[3790].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:49.713064 zmc_dvideo0[3790].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.715536 zmc_dvideo0[3790].DB1-zm_monitor.cpp/460 [Monitor Drive has function 3]
03/30/09 12:47:49.715563 zmc_dvideo0[3790].DB1-zm_monitor.cpp/461 [Monitor Drive LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:49.715573 zmc_dvideo0[3790].DB1-zm_monitor.cpp/462 [Monitor Drive IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:49.716152 zmc_dvideo0[3790].DB1-zm_zone.cpp/889 [Got 4 zones for monitor Drive]
03/30/09 12:47:49.716200 zmc_dvideo0[3790].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:49.716264 zmc_dvideo0[3790].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:49.716277 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:49.716287 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.716296 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:49.716304 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:49.716318 zmc_dvideo0[3790].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.716329 zmc_dvideo0[3790].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:55296, FB:3x5, MnFP:3317, MxFP:55296, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.718690 zmc_dvideo0[3790].DB5-zm_zone.cpp/918 [Parsing polygon 222,14 380,35 380,76 222,59]
03/30/09 12:47:49.718714 zmc_dvideo0[3790].DB3-zm_zone.cpp/758 [Parsing polygon string '222,14 380,35 380,76 222,59']
03/30/09 12:47:49.718725 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 222,14 from polygon string]
03/30/09 12:47:49.718734 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 380,35 from polygon string]
03/30/09 12:47:49.718742 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 380,76 from polygon string]
03/30/09 12:47:49.718750 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:49.718761 zmc_dvideo0[3790].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.718771 zmc_dvideo0[3790].DB1-zm_zone.cpp/50 [Initialised zone 4/Hedge1 - 1 - 159x63 - Rgb:ff0000, CM:3, MnAT:40, MxAT:0, MnAP:267, MxAP:3349, FB:5x5, MnFP:267, MxFP:3349, MnBS:267, MxBS:3349, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.719112 zmc_dvideo0[3790].DB5-zm_zone.cpp/918 [Parsing polygon 25,0 222,0 222,59 25,65]
03/30/09 12:47:49.719138 zmc_dvideo0[3790].DB3-zm_zone.cpp/758 [Parsing polygon string '25,0 222,0 222,59 25,65']
03/30/09 12:47:49.719147 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 25,0 from polygon string]
03/30/09 12:47:49.719156 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:49.719164 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:49.719173 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 25,65 from polygon string]
03/30/09 12:47:49.719183 zmc_dvideo0[3790].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.719211 zmc_dvideo0[3790].DB1-zm_zone.cpp/50 [Initialised zone 3/Road1 - 5 - 198x66 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.719639 zmc_dvideo0[3790].DB5-zm_zone.cpp/918 [Parsing polygon 222,0 383,0 380,32 222,13]
03/30/09 12:47:49.719665 zmc_dvideo0[3790].DB3-zm_zone.cpp/758 [Parsing polygon string '222,0 383,0 380,32 222,13']
03/30/09 12:47:49.719675 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:49.719683 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.719691 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 380,32 from polygon string]
03/30/09 12:47:49.719700 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 222,13 from polygon string]
03/30/09 12:47:49.719710 zmc_dvideo0[3790].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.719721 zmc_dvideo0[3790].DB1-zm_zone.cpp/50 [Initialised zone 5/Hedge2 - 5 - 162x33 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.719901 zmc_dvideo0[3790].DB1-zm_monitor.cpp/1810 [Loaded monitor 1(Drive), 4 zones]
03/30/09 12:47:49.720621 zmc_dvideo0[3790].DB1-zm_monitor.cpp/339 [monitor purpose=1]
03/30/09 12:47:49.720654 zmc_dvideo0[3790].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:49.763476 zmc_dvideo0[3790].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.765826 zmc_dvideo0[3790].DB1-zm_monitor.cpp/460 [Monitor AllEvents has function 3]
03/30/09 12:47:49.765851 zmc_dvideo0[3790].DB1-zm_monitor.cpp/461 [Monitor AllEvents LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:49.765860 zmc_dvideo0[3790].DB1-zm_monitor.cpp/462 [Monitor AllEvents IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:49.766394 zmc_dvideo0[3790].DB1-zm_zone.cpp/889 [Got 1 zones for monitor AllEvents]
03/30/09 12:47:49.766425 zmc_dvideo0[3790].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:49.766435 zmc_dvideo0[3790].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:49.766445 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:49.766455 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.766464 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:49.766472 zmc_dvideo0[3790].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:49.766485 zmc_dvideo0[3790].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.766496 zmc_dvideo0[3790].DB1-zm_zone.cpp/50 [Initialised zone 2/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:82944, FB:3x3, MnFP:3317, MxFP:82944, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.768772 zmc_dvideo0[3790].DB1-zm_monitor.cpp/1810 [Loaded monitor 2(AllEvents), 1 zones]
03/30/09 12:47:49.768798 zmc_dvideo0[3790].INF-zmc.cpp/186 [Starting Capture]
03/30/09 12:47:49.768997 zmc_dvideo0[3790].DB2-zm_local_camera.cpp/1065 [Priming capture]
03/30/09 12:47:49.769017 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 0]
03/30/09 12:47:49.771073 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 1]
03/30/09 12:47:49.773257 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 2]
03/30/09 12:47:49.775433 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 3]
03/30/09 12:47:49.777760 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 4]
03/30/09 12:47:49.779895 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 5]
03/30/09 12:47:49.782010 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 6]
03/30/09 12:47:49.784070 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1102 [Queuing frame 7]
03/30/09 12:47:49.786295 zmc_dvideo0[3790].DB2-zm_local_camera.cpp/1117 [Pre-capturing]
03/30/09 12:47:49.786368 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1185 [Capturing]
03/30/09 12:47:49.786378 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1242 [Capturing 1 frames]
03/30/09 12:47:49.786386 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1245 [Syncing frame 0]
03/30/09 12:47:49.893142 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1265 [Captured 0 for channel 0]
03/30/09 12:47:49.893169 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1270 [Doing format conversion]
03/30/09 12:47:49.893818 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1575 [Assigning image]
03/30/09 12:47:49.894266 zmc_dvideo0[3790].DB2-zm_local_camera.cpp/1583 [Post-capturing]
03/30/09 12:47:49.894290 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1603 [Requeueing frame 0]
03/30/09 12:47:49.894317 zmc_dvideo0[3790].DB2-zm_local_camera.cpp/1117 [Pre-capturing]
03/30/09 12:47:49.894325 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1185 [Capturing]
03/30/09 12:47:49.894333 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1575 [Assigning image]
03/30/09 12:47:49.894784 zmc_dvideo0[3790].DB2-zm_local_camera.cpp/1583 [Post-capturing]
03/30/09 12:47:49.894799 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/1603 [Requeueing frame 1]
03/30/09 12:47:49.894848 zmc_dvideo0[3790].ERR-zm_local_camera.cpp/1606 [Capture failure for frame 1: Invalid argument]
03/30/09 12:47:49.894950 zmc_dvideo0[3790].ERR-zmc.cpp/265 [Failed to post-capture monitor 1]
03/30/09 12:47:49.894998 zmc_dvideo0[3790].DB3-zm_local_camera.cpp/644 [Unmapping video buffers]
03/30/09 12:47:49.759483 zma_m2[3792].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03792]
03/30/09 12:47:49.760245 zma_m2[3792].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
03/30/09 12:47:49.760993 zma_m2[3792].DB1-zm_monitor.cpp/339 [monitor purpose=2]
03/30/09 12:47:49.761028 zma_m2[3792].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:49.761099 zma_m2[3792].ERR-zm_monitor.cpp/434 [Shared data not initialised by capture daemon]
03/30/09 12:47:49.899422 zma_m2[3796].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03796]
03/30/09 12:47:49.900133 zma_m2[3796].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
03/30/09 12:47:49.900930 zma_m2[3796].DB1-zm_monitor.cpp/339 [monitor purpose=2]
03/30/09 12:47:49.900966 zma_m2[3796].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:49.901099 zma_m2[3796].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:49.903576 zma_m2[3796].DB1-zm_monitor.cpp/460 [Monitor AllEvents has function 3]
03/30/09 12:47:49.903601 zma_m2[3796].DB1-zm_monitor.cpp/461 [Monitor AllEvents LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:49.903610 zma_m2[3796].DB1-zm_monitor.cpp/462 [Monitor AllEvents IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:49.904045 zma_m2[3796].DB1-zm_monitor.cpp/1583 [Reloading linked monitors for monitor AllEvents, '2']
03/30/09 12:47:49.904077 zma_m2[3796].DB3-zm_monitor.cpp/1624 [Found linked monitor id 2]
03/30/09 12:47:49.904088 zma_m2[3796].DB1-zm_monitor.cpp/1646 [Linking to 1 monitors]
03/30/09 12:47:49.904098 zma_m2[3796].DB1-zm_monitor.cpp/1652 [Checking linked monitor 2]
03/30/09 12:47:49.904474 zma_m2[3796].DB1-zm_monitor.cpp/1671 [Linking to monitor 2]
03/30/09 12:47:49.904918 zma_m2[3796].DB1-zm_zone.cpp/889 [Got 1 zones for monitor AllEvents]
03/30/09 12:47:49.904949 zma_m2[3796].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:49.904963 zma_m2[3796].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:49.904974 zma_m2[3796].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:49.904983 zma_m2[3796].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:49.904992 zma_m2[3796].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:49.905001 zma_m2[3796].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:49.905014 zma_m2[3796].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:49.905024 zma_m2[3796].DB1-zm_zone.cpp/50 [Initialised zone 2/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:82944, FB:3x3, MnFP:3317, MxFP:82944, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:49.907424 zma_m2[3796].DB1-zm_monitor.cpp/2457 [Loaded monitor 2(AllEvents), 1 zones]
03/30/09 12:47:49.907455 zma_m2[3796].INF-zma.cpp/99 [In mode 3/1, warming up]
03/30/09 12:47:49.907668 zma_m2[3796].DB4-zm_monitor.cpp/1052 [RI:40, WI: 0, PF = 0, RM = 40, Step = 1]
03/30/09 12:47:55.244616 zma_m2[3796].DB4-zm_monitor.cpp/1052 [RI:40, WI: 0, PF = 0, RM = 40, Step = 1]
03/30/09 12:48:01.126551 zma_m2[3796].INF-zm_signal.cpp/43 [Got signal 15 (Terminated), exiting]
03/30/09 12:47:54.133245 zms[3823].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03823]
03/30/09 12:47:54.133430 zms[3823].DB1-zms.cpp/92 [Query: mode=jpeg&monitor=1&scale=100&maxfps=5&buffer=1000&connkey=429842&rand=1238413673]
03/30/09 12:47:54.134076 zms[3823].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
03/30/09 12:47:54.134825 zms[3823].DB1-zm_monitor.cpp/339 [monitor purpose=0]
03/30/09 12:47:54.134857 zms[3823].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:54.134910 zms[3823].WAR-zm_monitor.cpp/439 [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
03/30/09 12:47:54.135081 zms[3823].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:54.137507 zms[3823].DB1-zm_monitor.cpp/460 [Monitor Drive has function 3]
03/30/09 12:47:54.137522 zms[3823].DB1-zm_monitor.cpp/461 [Monitor Drive LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:54.137531 zms[3823].DB1-zm_monitor.cpp/462 [Monitor Drive IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:54.137549 zms[3823].DB1-zm_monitor.cpp/2457 [Loaded monitor 1(Drive), 0 zones]
03/30/09 12:47:54.137641 zms[3823].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:5, BFPS:0, EFPS:0, FM:1]
03/30/09 12:47:54.137663 zms[3823].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
03/30/09 12:47:54.137686 zms[3823].DB2-zm_monitor.cpp/3334 [Checking swap image location]
03/30/09 12:47:54.137697 zms[3823].DB3-zm_monitor.cpp/3335 [Checking swap image path]
03/30/09 12:47:54.137738 zms[3823].DB3-zm_monitor.cpp/2858 [Swap path '/tmp/zmswap-m1/zmswap-q429842' missing, creating]
03/30/09 12:47:54.137812 zms[3823].DB2-zm_monitor.cpp/3356 [Assigning temporary buffer]
03/30/09 12:47:54.141847 zms[3823].DB2-zm_monitor.cpp/3359 [Assigned temporary buffer]
03/30/09 12:47:54.141953 zms[3823].DB3-zm_stream.cpp/115 [Scaling by 100, zooming by 100 = magnifying by 100(100)]
03/30/09 12:47:54.141965 zms[3823].DB3-zm_stream.cpp/119 [Last scaling by 100, zooming by 100 = magnifying by 100(100)]
03/30/09 12:47:54.141975 zms[3823].DB3-zm_stream.cpp/122 [Base image width = 384, height = 288]
03/30/09 12:47:54.141983 zms[3823].DB3-zm_stream.cpp/125 [Virtual image width = 384, height = 288]
03/30/09 12:47:54.141991 zms[3823].DB3-zm_stream.cpp/128 [Last virtual image width = 384, height = 288]
03/30/09 12:47:54.141999 zms[3823].DB3-zm_stream.cpp/131 [Actual image width = 384, height = 288]
03/30/09 12:47:54.142007 zms[3823].DB3-zm_stream.cpp/134 [Last actual image width = 384, height = 288]
03/30/09 12:47:54.142015 zms[3823].DB3-zm_stream.cpp/137 [Display image width = 384, height = 288]
03/30/09 12:47:54.142023 zms[3823].DB3-zm_stream.cpp/140 [Last display image width = 384, height = 288]
03/30/09 12:47:54.142031 zms[3823].DB3-zm_stream.cpp/143 [Send image width = 384, height = 288]
03/30/09 12:47:54.142039 zms[3823].DB3-zm_stream.cpp/146 [Last send image width = 384, height = 288]
03/30/09 12:47:54.142047 zms[3823].DB3-zm_stream.cpp/164 [Real image width = 384, height = 288]
03/30/09 12:47:54.147385 zms[3823].WAR-zm_monitor.cpp/3523 [Unable to store frame as shared memory invalid]
03/30/09 12:47:55.147510 zms[3823].DB3-zm_stream.cpp/115 [Scaling by 100, zooming by 100 = magnifying by 100(100)]
03/30/09 12:47:55.147544 zms[3823].DB3-zm_stream.cpp/119 [Last scaling by 100, zooming by 100 = magnifying by 100(100)]
03/30/09 12:47:55.147560 zms[3823].DB3-zm_stream.cpp/122 [Base image width = 384, height = 288]
03/30/09 12:47:55.147575 zms[3823].DB3-zm_stream.cpp/125 [Virtual image width = 384, height = 288]
03/30/09 12:47:55.147588 zms[3823].DB3-zm_stream.cpp/128 [Last virtual image width = 384, height = 288]
03/30/09 12:47:55.147601 zms[3823].DB3-zm_stream.cpp/131 [Actual image width = 384, height = 288]
03/30/09 12:47:55.147615 zms[3823].DB3-zm_stream.cpp/134 [Last actual image width = 384, height = 288]
03/30/09 12:47:55.147628 zms[3823].DB3-zm_stream.cpp/137 [Display image width = 384, height = 288]
03/30/09 12:47:55.147707 zms[3823].DB3-zm_stream.cpp/140 [Last display image width = 384, height = 288]
03/30/09 12:47:55.147723 zms[3823].DB3-zm_stream.cpp/143 [Send image width = 384, height = 288]
03/30/09 12:47:55.147737 zms[3823].DB3-zm_stream.cpp/146 [Last send image width = 384, height = 288]
03/30/09 12:47:55.147750 zms[3823].DB3-zm_stream.cpp/164 [Real image width = 384, height = 288]
03/30/09 12:47:55.156339 zms[3823].WAR-zm_monitor.cpp/3518 [Unable to store frame as timestamp invalid]
03/30/09 12:47:55.656444 zms[3823].DB3-zm_stream.cpp/115 [Scaling by 100, zooming by 100 = magnifying by 100(100)]
03/30/09 12:47:55.656483 zms[3823].DB3-zm_stream.cpp/119 [Last scaling by 100, zooming by 100 = magnifying by 100(100)]
03/30/09 12:47:55.656500 zms[3823].DB3-zm_stream.cpp/122 [Base image width = 384, height = 288]
03/30/09 12:47:55.656514 zms[3823].DB3-zm_stream.cpp/125 [Virtual image width = 384, height = 288]
03/30/09 12:47:55.656528 zms[3823].DB3-zm_stream.cpp/128 [Last virtual image width = 384, height = 288]
03/30/09 12:47:55.656541 zms[3823].DB3-zm_stream.cpp/131 [Actual image width = 384, height = 288]
03/30/09 12:47:55.656554 zms[3823].DB3-zm_stream.cpp/134 [Last actual image width = 384, height = 288]
03/30/09 12:47:55.656568 zms[3823].DB3-zm_stream.cpp/137 [Display image width = 384, height = 288]
03/30/09 12:47:55.656581 zms[3823].DB3-zm_stream.cpp/140 [Last display image width = 384, height = 288]
03/30/09 12:47:55.656594 zms[3823].DB3-zm_stream.cpp/143 [Send image width = 384, height = 288]
03/30/09 12:47:55.656607 zms[3823].DB3-zm_stream.cpp/146 [Last send image width = 384, height = 288]
03/30/09 12:47:55.656620 zms[3823].DB3-zm_stream.cpp/164 [Real image width = 384, height = 288]
03/30/09 12:47:55.665162 zms[3823].WAR-zm_monitor.cpp/3523 [Unable to store frame as shared memory invalid]
03/30/09 12:51:55.671510 zms[3823].INF-zm_signal.cpp/43 [Got signal 15 (Terminated), exiting]
03/30/09 12:51:55.671668 zms[3823].DB1-zm_monitor.cpp/3542 [Cleaning swap files from /tmp/zmswap-m1/zmswap-q429842]
03/30/09 12:51:55.671776 zms[3823].DB1-zm_monitor.cpp/3570 [Can't glob '/tmp/zmswap-m1/zmswap-q429842/*.*': 3]
03/30/09 12:47:55.059629 zmc_dvideo0[3825].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03825]
03/30/09 12:47:55.060309 zmc_dvideo0[3825].DB1-zm_monitor.cpp/1708 [Got 2 monitors]
03/30/09 12:47:55.060395 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/103 [Opening video device /dev/video0]
03/30/09 12:47:55.060427 zmc_dvideo0[3825].DB2-zm_local_camera.cpp/109 [V4L2 support enabled, using V4L1 api]
03/30/09 12:47:55.060440 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/432 [Configuring picture attributes]
03/30/09 12:47:55.060459 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/439 [Old P:4]
03/30/09 12:47:55.060467 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/440 [Old D:24]
03/30/09 12:47:55.060475 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/441 [Old B:32768]
03/30/09 12:47:55.060483 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/442 [Old h:32768]
03/30/09 12:47:55.060491 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/443 [Old Cl:32768]
03/30/09 12:47:55.060499 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/444 [Old Cn:32768]
03/30/09 12:47:55.060518 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/481 [Configuring window attributes]
03/30/09 12:47:55.060528 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/490 [Old X:0]
03/30/09 12:47:55.060536 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/491 [Old Y:0]
03/30/09 12:47:55.060544 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/492 [Old W:320]
03/30/09 12:47:55.060551 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/493 [Old H:240]
03/30/09 12:47:55.060564 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/508 [Setting up request buffers]
03/30/09 12:47:55.060577 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/514 [vmb.frames = 8]
03/30/09 12:47:55.060586 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/515 [vmb.size = 17039360]
03/30/09 12:47:55.060594 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/517 [Setting up 8 frame buffers]
03/30/09 12:47:55.060617 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/539 [Configuring video source]
03/30/09 12:47:55.060631 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/547 [Old C:0]
03/30/09 12:47:55.060639 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/548 [Old F:0]
03/30/09 12:47:55.060647 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/549 [Old Fl:0]
03/30/09 12:47:55.060655 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/550 [Old T:2]
03/30/09 12:47:55.060678 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/565 [New X:0]
03/30/09 12:47:55.060686 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/566 [New Y:0]
03/30/09 12:47:55.060694 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/567 [New W:320]
03/30/09 12:47:55.060702 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/568 [New H:240]
03/30/09 12:47:55.060712 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/573 [New P:4]
03/30/09 12:47:55.060720 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/574 [New D:24]
03/30/09 12:47:55.060728 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/575 [New B:32768]
03/30/09 12:47:55.060735 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/576 [New h:32768]
03/30/09 12:47:55.060743 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/577 [New Cl:32768]
03/30/09 12:47:55.060751 zmc_dvideo0[3825].DB4-zm_local_camera.cpp/578 [New Cn:32768]
03/30/09 12:47:55.060759 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/581 [Setting up static colour tables]
03/30/09 12:47:55.061389 zmc_dvideo0[3825].DB1-zm_monitor.cpp/339 [monitor purpose=1]
03/30/09 12:47:55.061410 zmc_dvideo0[3825].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:55.072956 zmc_dvideo0[3825].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:55.075412 zmc_dvideo0[3825].DB1-zm_monitor.cpp/460 [Monitor Drive has function 3]
03/30/09 12:47:55.075425 zmc_dvideo0[3825].DB1-zm_monitor.cpp/461 [Monitor Drive LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:55.075434 zmc_dvideo0[3825].DB1-zm_monitor.cpp/462 [Monitor Drive IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:55.076068 zmc_dvideo0[3825].DB1-zm_zone.cpp/889 [Got 4 zones for monitor Drive]
03/30/09 12:47:55.076093 zmc_dvideo0[3825].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:55.076152 zmc_dvideo0[3825].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:55.076164 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:55.076173 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:55.076182 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:55.076200 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:55.076212 zmc_dvideo0[3825].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:55.076222 zmc_dvideo0[3825].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:55296, FB:3x5, MnFP:3317, MxFP:55296, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:55.078574 zmc_dvideo0[3825].DB5-zm_zone.cpp/918 [Parsing polygon 222,14 380,35 380,76 222,59]
03/30/09 12:47:55.078585 zmc_dvideo0[3825].DB3-zm_zone.cpp/758 [Parsing polygon string '222,14 380,35 380,76 222,59']
03/30/09 12:47:55.078595 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 222,14 from polygon string]
03/30/09 12:47:55.078604 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 380,35 from polygon string]
03/30/09 12:47:55.078612 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 380,76 from polygon string]
03/30/09 12:47:55.078621 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:55.078630 zmc_dvideo0[3825].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:55.078640 zmc_dvideo0[3825].DB1-zm_zone.cpp/50 [Initialised zone 4/Hedge1 - 1 - 159x63 - Rgb:ff0000, CM:3, MnAT:40, MxAT:0, MnAP:267, MxAP:3349, FB:5x5, MnFP:267, MxFP:3349, MnBS:267, MxBS:3349, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:55.078965 zmc_dvideo0[3825].DB5-zm_zone.cpp/918 [Parsing polygon 25,0 222,0 222,59 25,65]
03/30/09 12:47:55.078975 zmc_dvideo0[3825].DB3-zm_zone.cpp/758 [Parsing polygon string '25,0 222,0 222,59 25,65']
03/30/09 12:47:55.078985 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 25,0 from polygon string]
03/30/09 12:47:55.078993 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:55.079002 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 222,59 from polygon string]
03/30/09 12:47:55.079010 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 25,65 from polygon string]
03/30/09 12:47:55.079019 zmc_dvideo0[3825].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:55.079029 zmc_dvideo0[3825].DB1-zm_zone.cpp/50 [Initialised zone 3/Road1 - 5 - 198x66 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:55.079419 zmc_dvideo0[3825].DB5-zm_zone.cpp/918 [Parsing polygon 222,0 383,0 380,32 222,13]
03/30/09 12:47:55.079430 zmc_dvideo0[3825].DB3-zm_zone.cpp/758 [Parsing polygon string '222,0 383,0 380,32 222,13']
03/30/09 12:47:55.079439 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 222,0 from polygon string]
03/30/09 12:47:55.079447 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:55.079456 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 380,32 from polygon string]
03/30/09 12:47:55.079464 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 222,13 from polygon string]
03/30/09 12:47:55.079474 zmc_dvideo0[3825].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:55.079483 zmc_dvideo0[3825].DB1-zm_zone.cpp/50 [Initialised zone 5/Hedge2 - 5 - 162x33 - Rgb:000000, CM:0, MnAT:0, MxAT:0, MnAP:0, MxAP:0, FB:0x0, MnFP:0, MxFP:0, MnBS:0, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:55.079641 zmc_dvideo0[3825].DB1-zm_monitor.cpp/1810 [Loaded monitor 1(Drive), 4 zones]
03/30/09 12:47:55.080271 zmc_dvideo0[3825].DB1-zm_monitor.cpp/339 [monitor purpose=1]
03/30/09 12:47:55.080295 zmc_dvideo0[3825].DB1-zm_monitor.cpp/346 [mem.size=13272232]
03/30/09 12:47:55.092386 zmc_dvideo0[3825].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/30/09 12:47:55.094724 zmc_dvideo0[3825].DB1-zm_monitor.cpp/460 [Monitor AllEvents has function 3]
03/30/09 12:47:55.094736 zmc_dvideo0[3825].DB1-zm_monitor.cpp/461 [Monitor AllEvents LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/30/09 12:47:55.094745 zmc_dvideo0[3825].DB1-zm_monitor.cpp/462 [Monitor AllEvents IBC = 40, WUC = 25, pEC = 30, PEC = 30, EAF = 5, FRI = 1000, RBP = 7, FM = 0]
03/30/09 12:47:55.095300 zmc_dvideo0[3825].DB1-zm_zone.cpp/889 [Got 1 zones for monitor AllEvents]
03/30/09 12:47:55.095323 zmc_dvideo0[3825].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 383,0 383,287 0,287]
03/30/09 12:47:55.095332 zmc_dvideo0[3825].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 383,0 383,287 0,287']
03/30/09 12:47:55.095342 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/30/09 12:47:55.095351 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 383,0 from polygon string]
03/30/09 12:47:55.095359 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 383,287 from polygon string]
03/30/09 12:47:55.095368 zmc_dvideo0[3825].DB3-zm_zone.cpp/796 [Got coordinate 0,287 from polygon string]
03/30/09 12:47:55.095379 zmc_dvideo0[3825].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/30/09 12:47:55.095389 zmc_dvideo0[3825].DB1-zm_zone.cpp/50 [Initialised zone 2/All - 1 - 384x288 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3317, MxAP:82944, FB:3x3, MnFP:3317, MxFP:82944, MnBS:2211, MxBS:0, MnB:1, MxB:0, OF: 0]
03/30/09 12:47:55.097680 zmc_dvideo0[3825].DB1-zm_monitor.cpp/1810 [Loaded monitor 2(AllEvents), 1 zones]
03/30/09 12:47:55.097694 zmc_dvideo0[3825].INF-zmc.cpp/186 [Starting Capture]
03/30/09 12:47:55.097865 zmc_dvideo0[3825].DB2-zm_local_camera.cpp/1065 [Priming capture]
03/30/09 12:47:55.097879 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 0]
03/30/09 12:47:55.099742 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 1]
03/30/09 12:47:55.101769 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 2]
03/30/09 12:47:55.103783 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 3]
03/30/09 12:47:55.105812 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 4]
03/30/09 12:47:55.107823 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 5]
03/30/09 12:47:55.109850 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 6]
03/30/09 12:47:55.111876 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1102 [Queuing frame 7]
03/30/09 12:47:55.113938 zmc_dvideo0[3825].DB2-zm_local_camera.cpp/1117 [Pre-capturing]
03/30/09 12:47:55.113997 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1185 [Capturing]
03/30/09 12:47:55.114006 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1242 [Capturing 1 frames]
03/30/09 12:47:55.114014 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1245 [Syncing frame 0]
03/30/09 12:47:55.213473 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1265 [Captured 0 for channel 0]
03/30/09 12:47:55.213513 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1270 [Doing format conversion]
03/30/09 12:47:55.214300 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1575 [Assigning image]
03/30/09 12:47:55.214729 zmc_dvideo0[3825].DB2-zm_local_camera.cpp/1583 [Post-capturing]
03/30/09 12:47:55.214757 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1603 [Requeueing frame 0]
03/30/09 12:47:55.214790 zmc_dvideo0[3825].DB2-zm_local_camera.cpp/1117 [Pre-capturing]
03/30/09 12:47:55.214805 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1185 [Capturing]
03/30/09 12:47:55.214818 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1575 [Assigning image]
03/30/09 12:47:55.215289 zmc_dvideo0[3825].DB2-zm_local_camera.cpp/1583 [Post-capturing]
03/30/09 12:47:55.215318 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/1603 [Requeueing frame 1]
03/30/09 12:47:55.215386 zmc_dvideo0[3825].ERR-zm_local_camera.cpp/1606 [Capture failure for frame 1: Invalid argument]
03/30/09 12:47:55.215657 zmc_dvideo0[3825].ERR-zmc.cpp/265 [Failed to post-capture monitor 1]
03/30/09 12:47:55.215817 zmc_dvideo0[3825].DB3-zm_local_camera.cpp/644 [Unmapping video buffers]
kevin_robson
Post by kevin_robson »
Did the logs show any obvious problems to anyone?
