Mar 29 20:27:43 nemoserver zmdc[24000]: INF ['zmc -d /dev/video0' started at 09/03/29 20:27:43]
Mar 29 20:27:43 nemoserver zmc_dvideo0[24000]: INF [Debug Level = 0, Debug Log = <none>]
Mar 29 20:27:43 nemoserver zmc_dvideo0[24000]: INF [Starting Capture]
Mar 29 20:27:43 nemoserver zmc_dvideo0[24000]: ERR [Capture failure for frame 0: Device or resource busy]
Mar 29 20:27:43 nemoserver zmc_dvideo0[24000]: ERR [Failed to prime capture of initial monitor]
Mar 29 20:27:43 nemoserver zmdc[23978]: INF [Can't find child with pid of '24000']
Mar 29 20:27:43 nemoserver zmdc[23978]: INF ['zmc -d /dev/video0' starting at 09/03/29 20:27:43, pid = 24000]
lspci | grep Bt878 |qq(-dom,mar29-)qj
00:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 02)
00:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 02)
xawtv -hwscan |qq(-dom,mar29-)qj
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.26-1-686)
looking for available devices
port 65-65
type : Xvideo, image scaler
name : ATI Radeon Video Overlay
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video (Jetway TV/Capture
flags: overlay capture tuner
zmu -d /dev/video0 -q -v
Video Capabilities
Name: BT878 video (Jetway TV/Capture
Type: 47
Can capture
Can tune
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 4096000
max total shared memory (kbytes) = 8192000
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 1007
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
