Just want to repeat me experiences with gentoo
First:
I stoped zoneminder synced package list removed 1.23.3 version of zoneminder, and reinstalled the new version of ffmpeg
/etc/init.d/zoneminder stop
emerge --sync
emerge --unmerge zoneminder
emerge ffmpeg
emerge gcc
backup mysql from phpmyadmin
(although I did not need it)
Third:
I read the manual for am 3 times trying to find what to "./configure" it with (yes i missed the section on compiling twice)
Anyways I ended up with
./configure --with-mysql --with-ffmpeg=/usr/bin/ffmpeg --with-webuser=apache --with-webgroup=apache --with-webdir=/var/www/zoneminder/htdocs/ --with-cgidir=/var/www/zoneminder/htdocs/cgi-bin/ --enable-mmap=no
make install
Forth:
Changed zm.conf so it would connect to the db
nano /usr/local/etc/zm.conf
Used zmupdate which failed (i dont know why)
So used php my admin to run the zoneminder database update sql.
Fifth:
Checked to see if events came up and i could make videos.
Everything worked as expected and even mpeg streaming worked correctly
Started zm
Sixth:
Modified zmtrigger as shown HERE
restarted zoneminder
ENDNOTES:
Seams much faster than before
Mpeg Streaming never worked for me before this.
Compiling is easier than I predicted for a complex programs as this
scales much better in cell phone(blackberry anyways)
Thanks ZoneMinder community for helping get me started with zoneminder and getting things set up in 1.23.3 version.
