SOLVED!! zma exiting abnormally if using modect or mocord
limitlessent
Post by limitlessent »
This problem was solved by:
1.) removing all cameras from the zoneminder console
2.) deleting all events, images etc from the /var/www/html/zm/events dir 3.) dropping my zm mysql database.
4.) Re-creating the zm mysql database and granting appropriate permissions
5.) importing the zm_create.sql tables back into the newly created db
6.) Re-adding cameras and setting modect or mocord back on
I'm assuming my db must have gotten corrupt somehow but this seemed to take care of it.
Original post below
I'm running CentOS 5.2 & Zoneminder 1.24.1.
If I use all my cams on Monitor they work fine...
Cams are generic analog BNC cameras, connected to a PV-183 capture card obtained from Bluecherry.
If I put them on modect or mocord, my logs fill with these errors:
03/31/2009 21:55:29.876118 zmdc[14877].INF ['zma -m 16' starting at 09/03/31 21:55:29, pid = 15362]
03/31/2009 21:55:31.842874 zmdc[14877].ERR ['zma -m 13' exited abnormally, exit status 11]
03/31/2009 21:55:32.123850 zmdc[14877].ERR ['zma -m 14' exited abnormally, exit status 11]
03/31/2009 21:55:32.375015 zmdc[14877].ERR ['zma -m 16' exited abnormally, exit status 11]
03/31/2009 21:55:40.105429 zmdc[14877].INF ['zma -m 13' starting at 09/03/31 21:55:40, pid = 15367]
03/31/2009 21:55:40.371415 zmdc[14877].INF ['zma -m 14' starting at 09/03/31 21:55:40, pid = 15371]
03/31/2009 21:55:40.639404 zmdc[14877].INF ['zma -m 16' starting at 09/03/31 21:55:40, pid = 15375]
03/31/2009 21:55:42.637629 zmdc[14877].ERR ['zma -m 13' exited abnormally, exit status 11]
03/31/2009 21:55:42.931215 zmdc[14877].ERR ['zma -m 14' exited abnormally, exit status 11]
Once I changed those cams back to Monitor, the errors stop.
What would cause that? Any ideas?
I followed instructions exactly from the Wiki for CentOS.
I get live feed fine if I click on a camera name but cannot get any sort of motion detection to work. No events have ever shown up (I'm assuming because of those errors in the logs every time I turn on modect or mocord).
Any help is greatly appreciated.
cordel
Post by cordel »
Turn debug to 5 and limit to zma_ post what you get.
limitlessent
Here's what I got:
03/31/09 23:59:22.961046 zma_m16[16432].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.16432]
03/31/09 23:59:22.961741 zma_m16[16432].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
03/31/09 23:59:22.963745 zma_m16[16432].DB1-zm_monitor.cpp/338 [monitor purpose=2]
03/31/09 23:59:22.963782 zma_m16[16432].DB1-zm_monitor.cpp/345 [mem.size=36865192]
03/31/09 23:59:22.963894 zma_m16[16432].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
03/31/09 23:59:22.975065 zma_m16[16432].DB1-zm_monitor.cpp/458 [Monitor Front_Walkway has function 3]
03/31/09 23:59:22.975109 zma_m16[16432].DB1-zm_monitor.cpp/459 [Monitor Front_Walkway LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
03/31/09 23:59:22.975132 zma_m16[16432].DB1-zm_monitor.cpp/460 [Monitor Front_Walkway IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
03/31/09 23:59:22.976259 zma_m16[16432].DB1-zm_monitor.cpp/1583 [Reloading linked monitors for monitor Front_Walkway, '10,11,12,13,14,15,17']
03/31/09 23:59:22.976304 zma_m16[16432].DB3-zm_monitor.cpp/1624 [Found linked monitor id 10]
03/31/09 23:59:22.976327 zma_m16[16432].DB3-zm_monitor.cpp/1624 [Found linked monitor id 11]
03/31/09 23:59:22.976350 zma_m16[16432].DB3-zm_monitor.cpp/1624 [Found linked monitor id 12]
03/31/09 23:59:22.976384 zma_m16[16432].DB3-zm_monitor.cpp/1624 [Found linked monitor id 13]
03/31/09 23:59:22.976406 zma_m16[16432].DB3-zm_monitor.cpp/1624 [Found linked monitor id 14]
03/31/09 23:59:22.976429 zma_m16[16432].DB3-zm_monitor.cpp/1624 [Found linked monitor id 15]
03/31/09 23:59:22.976451 zma_m16[16432].DB3-zm_monitor.cpp/1624 [Found linked monitor id 17]
03/31/09 23:59:22.976476 zma_m16[16432].DB1-zm_monitor.cpp/1646 [Linking to 7 monitors]
03/31/09 23:59:22.976551 zma_m16[16432].DB1-zm_monitor.cpp/1652 [Checking linked monitor 10]
03/31/09 23:59:22.976893 zma_m16[16432].DB1-zm_monitor.cpp/1676 [Can't link to monitor 10, invalid id, function or not enabled]
03/31/09 23:59:22.976923 zma_m16[16432].DB1-zm_monitor.cpp/1652 [Checking linked monitor 11]
03/31/09 23:59:22.977093 zma_m16[16432].DB1-zm_monitor.cpp/1676 [Can't link to monitor 11, invalid id, function or not enabled]
03/31/09 23:59:22.977158 zma_m16[16432].DB1-zm_monitor.cpp/1652 [Checking linked monitor 12]
03/31/09 23:59:22.977317 zma_m16[16432].DB1-zm_monitor.cpp/1676 [Can't link to monitor 12, invalid id, function or not enabled]
03/31/09 23:59:22.977347 zma_m16[16432].DB1-zm_monitor.cpp/1652 [Checking linked monitor 13]
03/31/09 23:59:22.977538 zma_m16[16432].DB1-zm_monitor.cpp/1671 [Linking to monitor 13]
03/31/09 23:59:22.977571 zma_m16[16432].DB1-zm_monitor.cpp/1652 [Checking linked monitor 14]
03/31/09 23:59:22.977744 zma_m16[16432].DB1-zm_monitor.cpp/1671 [Linking to monitor 14]
03/31/09 23:59:22.977772 zma_m16[16432].DB1-zm_monitor.cpp/1652 [Checking linked monitor 15]
03/31/09 23:59:22.977932 zma_m16[16432].DB1-zm_monitor.cpp/1676 [Can't link to monitor 15, invalid id, function or not enabled]
03/31/09 23:59:22.977962 zma_m16[16432].DB1-zm_monitor.cpp/1652 [Checking linked monitor 17]
03/31/09 23:59:22.978119 zma_m16[16432].DB1-zm_monitor.cpp/1676 [Can't link to monitor 17, invalid id, function or not enabled]
03/31/09 23:59:22.978532 zma_m16[16432].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Front_Walkway]
03/31/09 23:59:22.978567 zma_m16[16432].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 639,0 639,479 0,479]
03/31/09 23:59:22.978595 zma_m16[16432].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 639,0 639,479 0,479']
03/31/09 23:59:22.978621 zma_m16[16432].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
03/31/09 23:59:22.978644 zma_m16[16432].DB3-zm_zone.cpp/796 [Got coordinate 639,0 from polygon string]
03/31/09 23:59:22.978668 zma_m16[16432].DB3-zm_zone.cpp/796 [Got coordinate 639,479 from polygon string]
03/31/09 23:59:22.978691 zma_m16[16432].DB3-zm_zone.cpp/796 [Got coordinate 0,479 from polygon string]
03/31/09 23:59:22.978718 zma_m16[16432].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
03/31/09 23:59:22.978793 zma_m16[16432].DB1-zm_zone.cpp/50 [Initialised zone 16/All - 4 - 640x480 - Rgb:ff0000, CM:3, MnAT:40, MxAT:0, MnAP:49152, MxAP:0, FB:5x5, MnFP:36864, MxFP:0, MnBS:30720, MxBS:0, MnB:1, MxB:0, OF: 0]
03/31/09 23:59:22.988044 zma_m16[16432].DB1-zm_monitor.cpp/2457 [Loaded monitor 16(Front_Walkway), 1 zones]
03/31/09 23:59:22.988080 zma_m16[16432].INF-zma.cpp/99 [In mode 3/1, warming up]
03/31/09 23:59:22.988172 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:21, WI: 28, PF = 7, RM = 33, Step = 2]
03/31/09 23:59:22.991105 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:23, WI: 28, PF = 5, RM = 35, Step = 2]
03/31/09 23:59:22.993624 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:25, WI: 28, PF = 3, RM = 37, Step = 1]
03/31/09 23:59:22.996205 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:26, WI: 28, PF = 2, RM = 38, Step = 1]
03/31/09 23:59:22.998716 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:27, WI: 28, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:23.039797 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:28, WI: 29, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:23.185425 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:29, WI: 30, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:23.330388 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:30, WI: 31, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:23.475374 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:31, WI: 32, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:23.620364 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:32, WI: 33, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:23.765359 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:33, WI: 34, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:23.910371 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:34, WI: 35, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:24.055332 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:35, WI: 36, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:24.199302 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:36, WI: 37, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:24.344296 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:37, WI: 38, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:24.488282 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:38, WI: 39, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:24.633282 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:39, WI: 0, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:24.778176 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:0, WI: 1, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:24.923148 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:1, WI: 2, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:25.068157 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:2, WI: 3, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:25.213230 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:3, WI: 4, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:25.358223 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:4, WI: 5, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:25.503204 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:5, WI: 6, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:25.648193 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:6, WI: 7, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:25.793113 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:7, WI: 8, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:25.938105 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:8, WI: 9, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:26.083080 zma_m16[16432].DB4-zm_monitor.cpp/1051 [RI:9, WI: 10, PF = 1, RM = 39, Step = 1]
03/31/09 23:59:26.087617 zma_m16[16432].DB3-zm_monitor.cpp/2673 [Checking preclusive zone All]
03/31/09 23:59:26.087991 zma_m16[16432].DB4-zm_zone.cpp/150 [Checking alarms for zone 16/All in lines 0 -> 479]
03/31/09 23:59:26.088021 zma_m16[16432].DB5-zm_zone.cpp/152 [Checking for alarmed pixels]
03/31/09 23:59:26.088833 zma_m16[16432].DB5-zm_zone.cpp/214 [Got 3404 alarmed pixels, need 49152 -> 0, avg pixel diff 61]
03/31/09 23:59:26.088872 zma_m16[16432].DB1-zm_monitor.cpp/83 [link.mem.size=872]
03/31/09 23:59:26.088924 zma_m16[16432].DB3-zm_monitor.cpp/125 [Can't shmget link memory: No such file or directory]
03/31/09 23:59:26.088969 zma_m16[16432].INF-zm_signal.cpp/72 [Got signal 11 (Segmentation fault), crashing]
03/31/09 23:59:26.089034 zma_m16[16432].ERR-zm_signal.cpp/84 [Signal address is 0x44, from 0x8075bd7]
03/31/09 23:59:26.089438 zma_m16[16432].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zma [0x8075bd7]]
03/31/09 23:59:26.089503 zma_m16[16432].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zma [0x8075bd7]]
03/31/09 23:59:26.089546 zma_m16[16432].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zma [0x804cb2a]]
03/31/09 23:59:26.089587 zma_m16[16432].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x61edec]]
03/31/09 23:59:26.089628 zma_m16[16432].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zma(__gxx_personality_v0+0x3f9) [0x804c7d1]]
03/31/09 23:59:26.089670 zma_m16[16432].INF-zm_signal.cpp/125 [Backtrace complete, please execute the following command for more information]
03/31/09 23:59:26.089743 zma_m16[16432].INF-zm_signal.cpp/126 [addr2line -e /usr/local/bin/zma(__gxx_personality_v0+0x3f9) 0x8075bd7 0x8075bd7 0x804cb2a 0x61edec 0x804c7d1]
cordel
Post by cordel »
Suggests that something is off with zmc. Switch debug to zmc_ and see what you have.
Looks like you have some linked monitors miss configured as will by the looks of it.
limitlessent
Loads and loads of this:
04/01/09 02:06:58.462708 zmc_dvideo7[18513].DB2-zm_local_camera.cpp/1186 [Pre-ca
pturing]
04/01/09 02:06:58.462735 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1192 [Captur
ing]
04/01/09 02:06:58.462758 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1247 [Captur
ing 1 frames]
04/01/09 02:06:58.462790 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1250 [Syncin
g frame 5]
04/01/09 02:06:58.462843 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1268 [Captur
ed 5 for channel 0]
04/01/09 02:06:58.462865 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1273 [Doing
format conversion]
04/01/09 02:06:58.463630 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1579 [Assign
ing image]
04/01/09 02:06:58.465113 zmc_dvideo7[18513].DB2-zm_local_camera.cpp/1587 [Post-c
apturing]
04/01/09 02:06:58.465150 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1645 [Requeu
eing frame 5]
04/01/09 02:06:58.606697 zmc_dvideo7[18513].DB2-zm_local_camera.cpp/1186 [Pre-ca
pturing]
04/01/09 02:06:58.606724 zmc_dvideo7[18513].DB3-zm_local_camera.cpp/1192 [Captur
ing]
but not errors that I see...
limitlessent
Ok... I deleted my mysql db and totally started over.
I re-created the db and imported the initial zm_create.sql into it.
I've added 3 cameras back and set them for modect.
So far the only errors I see are in zmdc.log... they appear to just be warnings but how do I fix these:
04/01/2009 12:10:14.066928 zmdc[23010].WAR [Can't find process with command of 'zma -m']
04/01/2009 12:10:32.034708 zmdc[23010].WAR [Can't find process with command of 'zmc -d /dev/video2']
04/01/2009 12:10:32.522552 zmdc[23010].WAR [Can't find process with command of 'zma -m 3']
