ZM 1.24.1 FastForwarding fix
Posted: Sun Apr 05, 2009 8:19 am
This is a similar patch I made for Zoneminder 1.23.3 (http://www.zoneminder.com/forums/viewtopic.php?t=12111).
Fast forwarding/rewinding was very slow if your view events recorded in a low frame rate while you have a high frame rate set in the bandwidth options (WEB_H_VIDEO_MAXFPS, WEB_M_VIDEO_MAXFPS, or WEB_L_VIDEO_MAXFPS). On top of being slow, fast forwarding and rewinding tended to excessively skip frames which makes it really easy to skip over something important.
The patch bellow makes improves the fast-forward/rewind while only skipping frames when the playback speed X event FPS exceeds your bandwidth frame rate limit.
Index: src/zm_event.cpp
--- src/zm_event.cpp (revision 2846)
+++ src/zm_event.cpp (working copy)
@@ -1327,10 +1327,12 @@
// If we are streaming and this frame is due to be sent
if ( ((curr_frame_id-1)%frame_mod) == 0 )
- delta_us = (unsigned int)(frame_data->delta * 1000000);
- if ( effective_fps < base_fps )
- delta_us = (delta_us * base_fps)/effective_fps;
- send_frame = true;
+ delta_us = (unsigned int)(frame_data->delta * 1000000);
+ if ( replay_rate != ZM_RATE_BASE )
+ delta_us = (delta_us*ZM_RATE_BASE)/abs(replay_rate);
+ if( frame_mod > 1 )
+ delta_us *= frame_mod;
+ send_frame = true;
else if ( step != 0 )
